mikegr
Members-
Everything posted by mikegr
by the way here is what Flyhawk offer: A full PE kit but no wooden deck. The details in plastic though have gone to another level https://www.britmodeller.com/forums/index.php?/topic/235097428-flyhawk-1700-hms-hood/
- 225 replies
- I Love Kit
- Hood
sorry for not finding time of painting my basement walls. As "the master of wood said" : Life is too short and models to many to make. And sorry to thread starter for the off topic
Reconstruction can be fun. I do the same although I take a break nowadays. I have many to choose from about 34 models, from tiny subs to fleet carriers.
How you managed to twist the stairs of the PE ladders?
- 225 replies
- I Love Kit
- Hood
In EU this is a typical wide available product. https://www.nonpaints.com/en/colormatic-1k-epoxy-primer-in-aerosol In US you may need an alternative.
- 225 replies
- I Love Kit
- Hood
Not sure about availability in your area. Car painting products are all high quality. Also i use one ingredient car filler, P1000 Liquid. Superfine, great apply and easy to sand.
- 225 replies
- I Love Kit
- Hood
I use epoxy car primer. It comes in spray cans with adjustable flow. It covers all shinny metal surfaces and dries in 15-20 minutes.
- 225 replies
- I Love Kit
- Hood
I had to speed up my work cause of my 3 weeks leave. I finished the basics of the model while some finishing details will be added upon return. So after making the base using two sheets of 4mm plywood I coated it with wood primer and several layers of dark ocean blue. Then added the epoxy. As time was running out,after only 8 hours I coated the surface with medium gel giving the light waving effect. Note that the gel hasn't dried completely, therefore sea looks a bit wavy, white will turn into clear later.Next time I will try the more time consuming method of hairdryer(using hairdryer to make waves when resin starts to get solid). I make the wakes with acrylic putty and toothpick. Same for waterline plus mix of PVA+cotton. Will paint it over with white acrylic upon return to make a more visible effect.
- 14 replies
- O-class destroyer
- Tamiya
The assembly is finished, managed to use 90% 0f PE parts some were too tiny to be used. I sprayed the kit with light grey. I will do shading, weathering, and rigging.Also will make a wooden base and a sea bed with epoxy.
- 14 replies
- O-class destroyer
- Tamiya
Ι have started using PE parts from stern to bow. Depth charge frames (some damage couldn't be avoided) rails, mast and guns.
- 14 replies
- O-class destroyer
- Tamiya
I have built many 1/700 kits 25 years ago. Now I rebuilt them one by one. The last built was Yamashiro.
I made 2 20mm single guns with the shields. Another one was lost and the last one was over sprayed with primer and is beyond repair. Looks like I'm going to use 2 of those included in the kit. They will look like 40mm ones as they are bigger but i guess i can live with that😁
- 14 replies
- O-class destroyer
- Tamiya
Fiberglass a boat Hull
mikegr replied to Riotvan88's topic in Building, Framing, Planking and plating a ships hull and deck
a nice step by step action by a modeler which i consider quite advanced even using simple materials http://www.shipmodels.info/mws_forum/viewtopic.php?f=75&t=8912&start=20 -
Trumpeter's plastic is a bit average but for the price paid is quite acceptable. This and the growing variety of models puts the company in a good way.
- 225 replies
- I Love Kit
- Hood
Trumpeter Scharnhorst Battlecruiser 1/200 is coming soon.
mikegr replied to yvesvidal's topic in Plastic model kits
They are getting bigger. From 1/350 to 1/250 and lately 1/200 -
Because barrels are cylinder shaped unlike PE parts which are flat. In 1/700 you can buy extra brass barrels for big caliper guns. Smaller caliber guns are sold as a whole, as an extra upgrade. The ones in the kit were a single piece with the gun house so i couldnt use them.
- 14 replies
- O-class destroyer
- Tamiya
I made the 4" guns. Each one is comprised of 4 pieces. The gun tower, the base, the canister and the barrel which is not included so I made some from 0.4 mm rod
- 14 replies
- O-class destroyer
- Tamiya
Nice I was looking for some details on that kit So basically it Trumpeter model with Pontos PE plus wooden deck. Sounds like a really good deal for 40€ including shipping.
- 225 replies
- I Love Kit
- Hood
A straightforward assembly. One hour work including drilling of portholes. Time to look at PE parts starting from the cannons.
- 14 replies
- O-class destroyer
- Tamiya
Back to the small scale for a while. I bought this Tamiya kit for 9€. Like the German Z class kit of the same company it has two models. I'm going to built one including some PE from an ex eBay seller. Probably in light grey adding the seabed.
- 14 replies
- O-class destroyer
- Tamiya
