mikegr
Everything posted by mikegr
  1. I made a 3/4 fiberglass case The taller caser in Yamashiro reflects the higher bridge and masts. Yamashiro vs PoW. A possible scenario than never happened
  2. I am building my first project from a card model to wood and there are some things to be considered for a successful make. Spare plans is a must. I already ruined a complete hull(for other reason) so i restart now. One key factor is to adjust thickness of wood accordingly. For example if you use a 3 mm wood for deck you need to calculate this to the total hull height (as paper deck has almost 0 thickness). Otherwise you need to use thin woods. There are quite thin and strong woods to work with starting at just 0.4 mm. However they are not available in many countries and the cost is considerable. Balsa below 1.5mm thick is very fragile unless you harden it with chemicals, like resin or other.
  3. this is a fantastic built. Did you cut the 1.5mm wide wood pieces by yourself or have them cut at the shop?
  4. Japanese WW2 ships are unbeatable in details if you can handle them. Competition in 1/700 has lead the companies to offer products almost identical to 1/350 scale. This is very welcomed for us. Of course this has lead to some overscale like rivets and porthole frames. But at the end, its up to the builder. It is a hobby for personal recreation and he is the one who needs to feel comfortable with the outcome.
  5. nice clean work. Hull looks not easy for a beginner. I suggest you work with balsa than MDF for plating the hull as the latter has some issues with humidity and need some special treatment. Balsa is the no1 alternative for us that our modelling wood market is restricted.
  6. I was thinking to cover the hull with thin aluminum 0.20 mm stripes then use automotive filler. This would reduce the sanding and shaping hull time. As i started the process i decide either to enlarge the metal pieces to reduce work load or skip it at all and go straight to smooth the hull using car body filler, sanding and repeat the process unit I get the desired effect. Which I did. It would be proved a disastrous decision. Even hull didn't have any great imperfections, it took around half kilo of filler to cover it all. Then after a few minutes the hull area between frames collapsed. I have seen this happen on another project while using rubber adhesive glue. Probably catalyst heated polystyrene and forced it to shrink. I added locally some acrylic putty to fill the gaps. Even it was easy to work with, body filler on the other hand is not. So working with hard and soft ingredient at the same time is not an option. Another layer of car body filler will do the job although this would require lots of extra sanding effort plus will increase even more the weight of the hull.
  7. Great build. is this a resin kit collection on the background?
  8. Done. POW training her turrets during heavy swell. Not the thick rigging from rear mast top to stern. I put it here temporary to correct the mast top forward inclination cause by elastic rigging. Lessons learned: 1. Always control its tension when use elastic rigging with fragile masts. 2. Best CA glue simply can't compete with soldering in strength if you want to make brass mast.
  9. I think the lower rope on the first pic is a bit more realistic.
  10. I covered the sides with painted balsa and did some test fittings before adding final details
  11. A set back on my scratchbuilt consumed most of my free time so I left behind on this. I used expanded polystyrene on this so I can dig in easily. Give it 3-4 layers of primer and paint. Added a heavy coat of gel and waiting for it to dry at for 24-48 hours.
  12. Looks like Bismarck in big scales is a very popular model.
  13. how does this react to plexiglass? Does it keep it clear or make it whitish? Professionals are using a chloroform based glue which keeps the plastic 100% transparent. But this is extremely hard to be found and usually comes to 1 kg bottle sold for 60-80 euros.
  14. Nowadays kits in 1:700 are so advanced that can be almost comparable in details to their biggest cousins.
  15. I remember this kit at 90's There was a toy store on my way to school had it along with Matchbox Seasprite as well as few other kits. Price was approx 10$. Finally I built it in 1/600. I have to say those double hangars made the ship look too tall. Definitely not the most handsome model, at least in my eyes. Maybe in waterline version looks better.
  16. I done with weathering. These ships on photos seems to have issues with their paint so I did a lot of chipping. Unfortunately after some corrections sea bed proved a bit small unless model will be displayed anchored. I will make a new one with a different method.
  17. I finished rigging added rails and whatever boats I could found as I have missed a couple. Took the pic with light near the bright wall so 0.05 mm elastic rigging can be visible. Anchor chains and weathering are left for tomorrow.
  18. The Asian channel owner makes elite builds. The sea bed is top world class, comparing to Flodberg and Katseas creations. However require more materials and its more complicated to be built.
  19. I am in a hurry to finish it by this Sunday at least the model if not the sea bed. I glued almost everything except few pieces left as well as rails on main deck. I did also deck weathering. After gluing parts, rigging and weathering. I do rigging first before works comes first , then pleasure(rigging is boring).
