mikegr
Members-
Everything posted by mikegr
PE may look marginally better. What makes the difference between a nice model and a great one is that 5% extra detail. However i have to agree that this may not be an issue. There are many ways to overcome missing details or improve appearance. For example great paintwork can be critical. But can be of no importance at all Take a look at this is fine artwork based on superb painting which is beyond critisism. However looking at this handmade masterpiece it is easily understood that painting is of little if no importance. For me considering the fact that this is made only with basic tools in hand and not even putty for corrections, i believe painting would only damage the model
Cap San Diego by mikegr - 1/160
mikegr replied to mikegr's topic in - Build logs for subjects built 1901 - Present Day
So basically I got the wood hardener product. It is a transparent liquid with water consistency and smells like glue for plastic models. I decided to do the "jam" test. I cut balsa 1 mm thick in about 32x10 piece. I coated with it with one layer then a second one after some hours (balsa absorbed it really quick). Another same dimension piece was given a couple of layers of one ingredient epoxy.A third one was coated twice with polyester.Each one was given tested with a 200gr weight on it. One the right corner you can see the product (hardener, epoxy, polyester). As you can see the first piece had a min distance of 5.5 cm from the table, the 2nd about 6.5 cm and the 3rd one 6cm. That means the epoxyfied balsa was the most rigid of all. Or at least, epoxy is as good as a wood hardener. Note that polyester was well absorbed but wood remained sticky means that wasn't dried, perhaps more catalyst should have been applied, not sure if that plays any role.
I have applied several layers of thick primer and sand it. It got an almost smooth surface. Then I applied a coat of car body filler liquid, bought in a bottle. It is a bit more easy to work with and gives a fine smooth finish. I applied several coats each time less amount of it. I used glaze putty to fill in small holes. There's a lot of work to be done yet. -
It is a bit sad that there's no interest for making a model of this fine ship. Thats why I decided to built my own. I have finished filling the hull, thick coated with acrylic putty and sanded. Too much dust but this was sanded down easily in 30 min. In some areas the layer was thinner and polystyrene was exposed. This time I put bit if wood filler locally for quick dry. After done with it I will give several layers of thick acrylic layer, gesso style.This will create an extra protective layer and smoothen the surface for the final car body filler application. Like I did with my experimental Alfa class project. -
the last accident literally smashed my hopes for an easier work on shaping the hull. Giving the perfect shape is crucial for the appearance of the model. However I will need a great amount of filler (added weight) and a lot of extra sanding work. Under these circumstances I realized one thing: The project Cap San Diego is over... Why? Because Cap San Diego Lite is on. Learning from the rookie lessons I already started the process of a new hull with different approach. With better materials and lighter as the previous one would require a big amount of filler. Keel will be made from 4mm plywood instead of 8 so I can work easily the sharp bow and the round stern. Bulkheads are made of 2-2.5 mm wood instead of 3. For main deck a strong wood less than 1mm thick will be used instead of the 2.5 mm MDF which proved too heavy and problematic (don't forget I use paper model plans so I need to to adjust wood thickness according to plans. -
I found it also on a domestic seller, kind unusual. About 100usd per half gallon. I also found this, it comes at 500 ml can. If does what promises might be a solution. https://bormawachs.com/dettaglio_new.php?idprod=0641&cat1=2&lang=2 A friend who owns hardware store, gave me some polyester, he insist that soak the wood in it, will solve my problem. I get i will do some experiments and if doesn't work i will buy a specialized product.
Even talking about static models i am concerned about weight distribution, for an unknown reason i want my projects to be built not top heavy. Maybe later decide to make an R/C project. For frame and bulkheads i would use a thicker and strong wood. But everything from main deck and above must be lightweight and durable. For smaller superstructure parts i have a lot of options. Aluminum, styrene and balsa sheets will do just fine. But for main deck that can be from 50 to 100+cm long i would rather use something strong but also flexible so it can keep up with the curves of the hull. Carbon fibre is expensive only if used extensively, making my own sheets is possible. Besides ordering high quality wood from Europe is 60€+ minimum shipping even for minimum order cause of the item dimensions. So at the moment i need either to improve what i have and learn how to use it functionally or need to find substantial materials.
I am based in Greece. Best access to wood is from North Europe, mostly Germany. Shipping though can be prohibited because of their size and the recently increased rates. Note that i work on modern ships so "quality wood" appearance is not an issue for me. In contrast, i have to convert all wood texture to a totally smooth surface before paint. I also avoid to use styrene for large surface parts, i prefer wood. From my theoritical research one way to reinforce big and thin surfaces is by adding cloth and polyester at the back side of them, of course i need to experiment as i haven't use resin/liquid polyester before
I am looking for thin but durable wood sheets to make some parts like longer main decks etc. I found only one supplier selling quality wood like lime, walnut, birch Air plywood from 0.4mm thick. But he's somewhat far. So at the moment only balsa is quite available around. While its easy to work with it is sometimes too fragile especially if less than 1.5 mm thick.
