mikegr
Members-
Everything posted by mikegr
So I poured the resin. The intention was to form a light-medium wave. I used a hair dryer to form the waves. It was a bit early and resin wasnt thick yet so I spilled some, making a mess on the base. After some time using the gun up and down I let it rest. I repeated the process until the epoxy has thickened to the point that was stable even when i used the dryer almost touching the base. Next morning I discovered that epoxy was back 90% in the original form. Even looked solid while blowing it probably the slow curing time prevent it from holding its shape😕. Having no other option I used medium gel to make a bit rough sea. I have used it in the past and concluded that this reduces the resin transparency, which I don't like. So while I was satisfied with the model built regarding the time spent, the sea base was just a repeat of a previous attempt with nothing new to offer.
These fragile thin blades are surgical type. They are flexible and sharp but can break frequently.
- 33 replies
- tamiya
- king george v
Air brush vs paint & brush
mikegr replied to jefferyt's topic in Painting, finishing and weathering products and techniques
Obviously is hard to get enough experience to build a fine wooden model before you turn into retirement age. Unless you are into this for many years. Back to the airbrush matter, there are many videos on youtube. From few minutes to hours. It is a lot different world and need a lot of learning and experimentation. I bought a kit with mini compressor mostly for general painting and making wave effects on sea dioramas. For detail painting like miniatures an advanced set is required. -
I consider this class as the most appropriate for entry level into aircraft carrier scratch built. Its not easy but the absence of side openings at the hull can reduce time work considerably. I have Gambier Bay plans consider to built in 1/144.
- 126 replies
- Thetis Bay
- Finished
- (and 4 more)
I found at last some info online and some pics of a nice finished model so I had the chance to add some details. I scratch built a communication loop antenna. Apart from fragile PE parts i have to work with weathered plastics. One piece of wing broke off just while sanding it. Air group has landed and antennas too. Only one was rigged for today.
welcome aboard. both ships Victory and Bismarck were legendary ships and deserve a place in the modeler's corner. The decision is yours.
I finish weathering the deck. I had to remove the arresting cables put the white stripes and install them again. Kinda foolish.Correct planning is useful apart modeling skills. There suppose to be a circle but I don't have it neither I'm good enough to airbrush one, I can't afford a second deck disaster. This is going to be a heavy weathered rusty dog of war.
too many modelers use bottles to stick their parts for painting . Maybe i should follow .
Cap San Diego by mikegr - 1/160
mikegr replied to mikegr's topic in - Build logs for subjects built 1901 - Present Day
I have finished the hull to the polishing point. However during hard sanding I noticed vertical surface cracks at the point where main deck lowers and meet the aft deck. Even I had fortified this joint that wasn't enough to make up for the absense of a unified deck and planking. Also some filler peel off appeared in some areas. Another lesson learned. Under these circumstances, laid up of a 3rd hull seemed inevitable. After consideration and online study I decided to to risk and try a new for me technique. Wrapping the hull in fiberglass. To make it a bit more rigid and avoid another two week season of sanding I chose an extra light fiber mat, 30gr per sqm heavy. I gave it 3 layers. 5 would be better but I was afraid of extra resin causing problems with foam again. I will probably do the rest work after at least 24 to 48 hours. -
So I got some video suggestion from youtube lately Is this kit the most difficult indeed? Maybe some one else may have other opinion? I would like to hear your thoughts.
Traditional Humbrol enamel (01)has worked fine for me. I used it with brush only, no thinner. I have no experience with airbrush
I have sold this problem by using high quality autobody epoxy primer. But I use it on spray and even it has flow regulator needs careful handling and proper spraying distance as it may flood the tiny parts. Also it may cover the parts numbers on sprues.
You may consider using gel CA for rapid PE gluing wherever this needed like masts etc...
So many stuff for a tiny model. Good luck. Size doesn't matter. Can be impressive as much as its bigger cousins.
Realistic Water
mikegr replied to taylormade's topic in Painting, finishing and weathering products and techniques
This is Chris Flodberg indeed a full time artist. Along with Katseas my favorite sea base builders in 1/700 and 1/350. https://www.chrisflodberg.com/maritime. There is also a concentration of methods by builder on this forum http://www.shipmodels.info/mws_forum/viewtopic.php?f=4&t=37923 -
Realistic Water
It depends what you want to represent. The epoxy materials referred above are a good option. Note that if you want to make waves you need extra materials like acrylic gel or even plaster, depends on reality factors like boat speed, weather and scale. -
Not much progress I just feel the need to update. Deck sticker added. I marked the arresting gears. First I used marker and ruler. Attempt was disastrous because the surface wasn't smooth as it looked. I hope parking a couple of aircrafts would cover it somehow. For the rest, I used paintbrush hair painted with black marker.
