Mirabell61
Everything posted by Mirabell61
  1. thanks for sharing that information Bob, i do hope that the workers will do a splended job on Wavertree`s restoration on that old iron hulled cargo sail ship. Also I`m very pleased that the Peking will be brought home to Hamburg instead of being scrapped, she also will be restorated and moored at the new planed Hamburg Harbour Museum... Nils
  2. Excellent work on the upper planking Bob, so clean and accurate, well done Nils
  3. Thanks Nenad, as Mark said, this sort of thing probably hapened to all of us once... I hope to see the progress on your CS, you always come up with interesting ideas for producing details.... Cheers, Nils
  4. Thank you very much, Mark, John (Neptune), and John (Jim Lad), and all the "likes", Nice words Mark, I`m doing something else, before fixing the shrouds.... John, (Neptune) I saw, that you undertook a real deep dive into the log...., thanks for your interest, I`m pleased you enjoyed it, you`re very welcome to stay tuned... John, (Jim Lad) thanks for the compliment..., I`m also happy to see the feedback from my Australian fellow-builders (other side of globe...) Nils
  5. Hello Johann, thank you very much for your nice compliment...... In the moment I`m still a bit frustrated due to my own fault accident with damaging the foremast lines and shrouds, so I`m doing (planking) the deck, which will take several days to do.... Viele Grüsse Nils
  6. Thanks Patrick, have now leart "by heart" to more more carefully ....... Am now studying fitting out of promenade deckhousing windows, doors, portholes, stairway to upper and lower decks, etc...... Also made a prototype of the boat`s davit with tapered (stepped) ends, from 2mm down to 0,8 mm diam. The upper end is 1,5 mm and anealed and flattend at the end and bored for the davit block (boat-tackle) Nils
  7. Update Started with the coamings for the promenade decks super structure. It`s going to be a "longer" session. After that the railing will be put on. On 26th May this project was under way for the first 12 months. Had a little shock yesterday when I was a bit uncautioius in turning around, standing sidewise of the modeling table, and by mistake knocking my arm against the foremast from half back stb. side. This overstressed the shrouds and backstays so much that I probably shall have to replace these. , the mast stayed straight. Will be some fiddely repair work, but it could have come even worse, was my thought ...., anyway that`s an event that drops one`s attitude to zero for the moment Nils the middle gap in the front of the promenade deck has been closed here the contours of the super structure can be seen (mahagony) here the deck is started with 2 mm wide and 0,8 mm thick pine stripes (pencil caulking of the plank edges) the promenade deck will have the same appeal as the forecastle- and the waist deck
  8. Hi Siggi, looks like this is going to be a wonderful planking job on your barge..... Nils
  9. Thanks for your explanation Micheal, I think now I understand what you are going for.... You`re building a sort of a dummy removable "plug-network", an interesting technique..... Can hardly wait to see your Buffalo engine running Nils
  10. A nice set up for the build Michael, Trust you will be keeping the bulkheads in place later on. Are the stringers going to be sunk in flush in the bulkheads ? Looks like it will be a nice (and large) tucker boat. Is your self made engine built to drive the boat later on... Nls
  11. Bruce, your CWM is a wonderful build of a whaler working ship. Excellent handcraft work and a pleasure to explore the details... Nils
  12. Many thanks to Bob, Mark, Patrick and Michael, much appreciated comments... and all the "likes".... Bob, I think that around 1900 the people were not as tall as todays, so 1:160 scale will be acceptable Mark, the experience with the steel cables is from usage on my tall ships, where there are so many shrouds and backstays to keep under tension (turnbuckle screws) thanks Patrick, pleased you like it... Michael, sometimes I`m not pleased with the first result, but it`s most times worth a second try... Nils
  13. the deckhouse looks beautiful Bob, also love those drainpipes ... Nils
  14. Many thanks Bob and Denis, for your nice compliments and all the "likes".... for the button clicks I`ve changed the ratline color, as the other thread was a bit pale... In lack of crew figurines in scale 1:144 here are some samples in railway "N" scale (1:160), trust they will do as well....although a tiny bit too small in hight Nils
  15. Hi Carl, the shrouds and backstays are from flexibel 7-fold zinc-galvanized steel chord with a total thicknes of 0,3 mm diam. (normaly used for wire controlled model aircraft). After some weeks they get a bit darker when they oxidize. The ratlines are polyester thread Nils
  16. Keith, that`s the way I like models being built, beautiful lines, excellent handcraft work and clean planking...... very well done ! Nils
  17. Update starting foremast ratlines, determining the line thicknesses.... Nils this gallows is just a little dummy setup to determine the line thicknesses the shrouds and backstays are from flexibel 7-fold galvanized steel chord with a total thicknes of 0,3 mm diam. (normaly used for wire controlled model aircraft) the turnbuckle srews are the smallest I could find ( M1 left / right thread) the upper shroud distances are given by the 4 slots in the top`s spreader the slotrings for deck fastening are soldered at the joint, in order to prevent opening the ratlines thickness is chosen to 0,2 mm thread in scale (the actual would be ( 144 x 0,2 = 28, 8 mm diam.)
  18. Thank you Carl, you`re right with the fitting out alongside the fitting out quay, but most of that would have been the luxurious fitting out and furnishing of the saloons, which I can skip...... Nils
