Mirabell61
Everything posted by Mirabell61
  1. Many thanks Bob and Denis, for your nice compliments and all the "likes".... for the button clicks I`ve changed the ratline color, as the other thread was a bit pale... In lack of crew figurines in scale 1:144 here are some samples in railway "N" scale (1:160), trust they will do as well....although a tiny bit too small in hight Nils
  2. Hi Carl, the shrouds and backstays are from flexibel 7-fold zinc-galvanized steel chord with a total thicknes of 0,3 mm diam. (normaly used for wire controlled model aircraft). After some weeks they get a bit darker when they oxidize. The ratlines are polyester thread Nils
  3. Keith, that`s the way I like models being built, beautiful lines, excellent handcraft work and clean planking...... very well done ! Nils
  4. Update starting foremast ratlines, determining the line thicknesses.... Nils this gallows is just a little dummy setup to determine the line thicknesses the shrouds and backstays are from flexibel 7-fold galvanized steel chord with a total thicknes of 0,3 mm diam. (normaly used for wire controlled model aircraft) the turnbuckle srews are the smallest I could find ( M1 left / right thread) the upper shroud distances are given by the 4 slots in the top`s spreader the slotrings for deck fastening are soldered at the joint, in order to prevent opening the ratlines thickness is chosen to 0,2 mm thread in scale (the actual would be ( 144 x 0,2 = 28, 8 mm diam.)
  5. Thank you Carl, you`re right with the fitting out alongside the fitting out quay, but most of that would have been the luxurious fitting out and furnishing of the saloons, which I can skip...... Nils
  6. thank you so much for your nice compliment Lawrence, during checking out the run of the shrouds and backstays with preliminary sewing thread, I just noticed that there should be 6 turnbuckle screws (instead of 5) on each side, so warm up the blackening acid once again.... Nils
  7. Hi David, no resistance soldering involved. Soldering done by means of mini gastorch and soldering iron. For preparation pls. ref. to scetch.... All will be primered and painted.... Nils
  8. Thank you very much Martin, as already mentioned to Bob, there will be a walkbridge between promenade- and forecastle deck. As far as I know this could be used by passengers and crew to move around..... In some pics (Norway Heritage, for KWdG) it shows this bridge in simple gangway character, so I`m not sure if not perhaps this position was only the resting place for the ships own gangway during travel..... Nils this pic found and borrowed from the web.... width 6 mm, railing hight 8 mm telescope support for adjusting the correct hight
  9. Ed, that anchor is beautiful, also the surface treatment of the brass material Nils
  10. Thank you very much Bob for your nice comment Bob, there is a little walk bridge that connects the promenade deck with the forecastle deck. I trust its better that this that would have to go on first, otherwise there is no sufficiant access for mountung it, when the shrouds are in the way Nils
  11. thanks Patrick, good idea with the salt spray and streaks of rust, I may take it up later on......, for crew and passengers it`s not so easy with the suitable scale, but I`ve been gathering typical "turn of the century" passengers and crew members, for sailors and officers I recently found some nice figures in scale 1:144 from North Star Models Nils
  12. Update cleats on forecastle deck edge, mounting of spare anchor, and fastening of five turnbuckle screws per side, for the shrouds (M1 threads, left / right) and foremast backstays Nils
  13. Many thanks to Gerhard, Grant, Patrick John, Mark, Daniel, and all the "likes" for those much appreciated and kind comments....., I`ll be looking to rig the foremast and it`s shrouds next Nils
  14. Igor, the fish look frightening realistic, very nice work you`re surely bringing that theme to life........ Nils
  15. update build log part 33 here is a little update on the forecastle stairways, the cargo hatches, the medium sized cargo derrick and the anchor handling crane........ Nils
  16. congrats to that lovely built barge Druxey, a very beautiful model... Nils
