Everything posted by Veszett Roka
Apart from this is really need research, i don't think that sponge thing. Ancient Romans were surrounded the Mediterranean where natural sponges was plenty. But in cold seas this feature should prove damn expensive, and sailors weren't so refined to allow themselves such luxury. I guess they clean their parts once a day, maybe twice a week? Bathing by saltwater, using a bucket, no more.
Oh thats smart. I always did the shrouds first, one by one, then attach the crows nest or crosstree - but your method is more efficient than mine.
If i remember well, someone built a ship from the same era which named Pelican and renamed later to Golden Hind (i know the differences though ) So at the forecastle's bottom holes (pun intended) would be sufficient i guess. The only difference that Mary Rose's sailors could enjoy the heads in rain as they are covered by the forecastle.
Looking good Bill! How you will install the shrouds? The forestay(s) is quite simple, but i think the shrouds should go around the mast like Dafi's Victory?
Yes Bill, this is the old Airfix model, the 'Special Edition' version of the kit. I built her 30+ years ago. I did really enjoy the build, and was a great success to compare my model to the original in Wasamuseet, Stockholm.
I think the sequence is differs for every model, regarding the scale, the shrouds, etc. My general sequence is to erect the mast, add lower level shrouds, then lower yard with its attached ropes (footropes, parrals), add yardlifts, then attach sails with its ropes. Then next level shrouds, yard, sail up to the top. But this is general practice only, sometimes i have to follow a different path if the scale is too small and better the result if i build the mast separately with sails, then put it into the hull in one piece and attach the standing rigging and running rigging thereafter. My 1:250 Cutty Sark built this latter way, the 1:144 Wasa built by the first method. Both have furled sails. Now i'm following the bottom-to-top mode building the 1:150 Pamir. Please consider that smaller scales tends to have more ropes and details missing, thus easier to build.
The double hinged arm is a very elegant solution. About the captain, i guess the friction between the push rods and the captain's wooden base cause that iffynes. If i'm right, a dome cap could solve it like this: But anyways, i'm admired.
At this exact position, PAMIR had a clamp to hold the cargo cranes boom secured during voyages. A bit differently installed, but PASSAT still have those clamps, however the crane boom has already been removed - the crane itself is the white mushroom far left on the picture. When i was on PEKING, she hadn't even cranes installed, but that was prior her restoration, based on the pictures that cranes still missing. Pic below is from PASSAT, note that the handrails have removable sections there. Also note that those fittings are looking aft, but same clamps was installed for the forward crane booms too - i wasn't able to find pictures for that part. However this is not proving that the fitting on Herzogin Cecilie has the same purpose. This one looks like a fairlead and the handrail is the same all along.
You can connect the hatch to the captain's shaft with two bumpers (or even a single), thus the captain can open a hatch en-route to the flybridge and close it after he is down already. I believe it is just matter of space inside the tower or in the hull. Brilliant work!
Sign in status is controlled by HTML cookies - those are tiny codes which downloaded to your computer, and when you log in to the site, your computer sends back the code which proves that you're already logged in. Therefore if that cookie is missing, the site will think that you didn't yet logged in, transfers you to the username-password page, and upon the succesful login will deliver the cookie. The cookie will be sent to your computer only if the "remember me" option ticked in. Now two things. First, those cookies has expiration time, and the site admins can set shorter or longer periods, how long those codes are valid. Once a cookie ran out of this time, the site will sense that your login has expired and request a new login to deliver the new code. Second, your browser could be set to delete cookies after exit - mine (Firefox) is set this way, so i have to login every time too. Different kind of browsers have different settings, but all has this option under the security section.
Try to use them for the open ports, carefully carve their openings into the hull. With this you will not risk the fittings on the covers. If you not satisfied with the openings you can cover the "hole" later and can try to remove the hardware then. Heat them carefully, this will melt the glue and you can easily remove the metal parts from wood. As for other topic regarding plastic or wood for me the considerable key is the size and scale. For instance an 1mm (sorry, cannot tell in imperial scale, maybe 1/16 or less) stanchion is equal of 15 cm (5.8 in) in my usual 1:150 scale. This is quite a thick pole, isn't it? You cannot made it from wood, but easily from plastic. Contrary, a 3 mm thick plywood door would mean a 45 cm thick one in scale, probably a size of a real rudder. However, wood models have uncomparable beauty which you cannot mimic by different material. Varnished wood is unbeatable at any way.
Hi Bill, i would vote for option (D), which is to cut some veneer squares and attach them to the appropriate positions. Then glue the needed hardware on top. This will give a slightly protrudient hatch cover, but not as thick as the original wood hatches. If you want to flush the wood (or veneer) covers into the hull, you should use a precise chisel - you might fabricate one from a cheap small screwdriver for instance, the only thing is that it need to be very sharp.
I'm jelaous Daniel. What an experience and joy, i was instanly fallen in love with this old lady. Interesting to see that the footropes made from stainless bowdens and the wideners (salings in german term) were made from 10*10 cm square steel
This is a complete mini-model Nils, i would definitely keep it after molding use. Excellent!
- 307 replies
- lightship
- Feuerschiff Elbe 1
No any special reason Keith, just exchanging techniques and experiences. My particular reason is the Pamir 1:150 model, which has the polystyrene (cookie box) windows, but i'm unsatisfied the result due the thickness of the portholes. You can see the 'glass' only when looking into portholes dead straight. At least i know they are in... And Nils' approach with solid transparent rod insert would be better for me too. However, my 1:350 Titanic bridge had same transparent windows with suitable results - that one has full strip inside the bridge and the borders, storm boards etc. are printed/cutout on a paper strip and that paper strip covers the inner side of the bridge.
- 307 replies
- lightship
Yes, i encountered this also. So i'm using very thin two sided adheshive tapes at the windows edges, or Revell Contacta Professional glue (butylacetate) - depends on the scale and material. If i don't want the interior be visible i cover the inner side with matte adheshive tape (Cellux). Now i will try the silicone rod.
- 307 replies
- lightship
