Gremreeper1967
Posts posted by Gremreeper1967
4 minutes ago, Overworked724 said:
If you are checking with a spare piece of planking, and the run of the plank looks OK on the faired piece, you should be OK. Just from looking at it, it looks alright. But you won't really know until you need to bend the strip around the corner and see how it lays. Looking good though!
Thanks overworked724! That's going to be a very tight bend in that area.
- JpR62, GrandpaPhil, WalrusGuy and 1 other
4
- GrandpaPhil, gieb8688, Edwardkenway and 3 others
6
- Chuck Seiler and mtaylor
2
I am building the US Brig Syren and according to Chuck's plans the bullwarks are supposed to be 1/8" in top and 5/32" at the deck when all of the ports are framed. I however have gone a bit to far, I am a 1/16" to thin and still have a bit of framing and sanding to do. My question is, do I add to the bullwarks and then finish at the 1/8 and 5/32 or sand my framing down to the 1/16"?
It has been slow going but I now have the bulkheads in and the blocks. I am now working on fairing the frame. I did run into a spot of trouble with the two bow blocks and had to fabricate two new ones.
What does everyone use to fair their frames? I'm using a hand sander that is about three inches long and one inch wide.
- gieb8688, CiscoH, GrandpaPhil and 1 other
4
- GrandpaPhil, Edwardkenway, clearway and 3 others
6
- VTHokiEE, Edwardkenway and GrandpaPhil
3
I have the Model Shipways US Brig Syren coming in and I plan to start it in about a month. I was hoping any members that has completed this kit could advise me of anything I may need to upgrade or add to the model so I can get it pre-ordered. Thank you in advance for your time.
- GrandpaPhil and Edwardkenway
2
2 hours ago, VTHokiEE said:
There are a lot of good options; but I’m not to familiar with a historically accurate pirate kit. Have you looked at Amati’s Victory line, Vanguard’s Speedy, MarisStella’s Ontario? If none strike your fancy they may provide some direction for additional suggestions.
I guess I should have mentioned, I don't think I will go about Amati kit due to them not responding to any of my messages. But I will take a look, thank you
1 hour ago, mtaylor said:
So many questions... guns? no guns? Masts or engine power? If masts, how many? What era? Help us out... so many models, so little time.
Mtaylor, no engine power, so masts and the number first not matter, there era is not that important and I'm not a big fan of gun ports but a few is not a deal breaker. I'm looking for a model of a REAL ship, the one I am doing now is not modeled from an actual ship. Prefer POB, I don't want to try POF with this kit as I want it to be a center piece. A pirate ship would please my wife. It HAS to be historically accurate with good instructions, and a will put together kit. I hope this helps. I am not in a hurry to purchase as I still have to finish the one I'm working on.
US Brig Syren by Gremreeper1967 - Model Shipways - 1/64 scale
I've started tree nailing with one side done except for sanding. I have opted for using wood for the tree nails over filler.
