Papa
Everything posted by Papa
  1. Thanks. She has been done for a while. I just neglected to post a photo.
  2. The Morgan is essentially finished. One little line to trim when I get around to it.
  3. I have one last belaying point to tie up and put a rope loop on. The model has been in my study for months now and I just can’t get the enthusiasm to clean up that last pin. It looks great as is and one has to look closely to see the loose line. Also I should probably add some more gear in the whale boats. I just totally lost interest. ps, the untied line is for the cutting stage.
  4. We had an oopsie while rigging the main braces and knocked off the dolphin striker and associated rigging. One step forward two steps backward. A new striker is in place and waiting for the riggers.
  5. Boom and gaff are in. Now I am tying ratlines, my least favorite part of rigging.
  6. The belaying key labels on my Gjoa sail plan are all in English except for one pin labeled ørefiken. I assume this is Norwegian as Gjoa was a Norwegian ship. Can someone translate this for me? Google translate isn’t helpful. It says it means cuff or slap on the face. thanks
  7. The main mast is in and some of the bowsprit rigging is in place
  8. The remaining deck houses are in place. Next step will be masts and rigging .
  9. Excellent work as always John. Sometimes I wonder what the point is of planking a hull that is smoothed to look like a solid hull and then painted. Seems like one has gone to a lot of hard work that is then hidden from view. Ron
  10. David, you say you are in the Boston area. I grew up in Saugus, MA and lived on Robinson st.    Small world
  11. The hatch was not too difficult other than cutting accurate miters on 1/16 x 1/16 strip wood. That cabin was a problem. The kit provided a solid block of wood that matched the overall dimensions but I struggled with the window frames. Eventually I decided to make them from cards stock and I was lucky enough to have some brass rings in my parts box that were a good fit for the portholes.
  12. I purchased the kit on eBay quite a few years ago. I am not sure if these pins were original or not. They may be too nice for the period of the kit.
  13. The deck furnishings are coming along. I didn’t have a wood thin enough to bend for the roofs of the WCs and the companion way, so I made them out of card stock. Now that it is posted I see a gap between the wall and roof on the starboard WC. Have to fix that.
  14. Finally returning to Gjoa after a bout of Covid. My first even! Constructing the WCs
  15. I have installed the anchor windlass, the rudder, and constructed a skylight. The latter was tricky because of its small size
  16. Gjoa was built in 1872; This log was mistakenly place in the 1801 to 1850 section rather than 1851 to 1900. How do I fix that?
  17. I had to redo the stern. Stupidity caused me to omit the opening for the tiller. I also finished the pin rails.
  18. Gjoa was used by Roald Amundsen to traverse the North West Passage from 1903 to 1906. She was built in 1872 and used as a herring fisher until Amundsen purchased her in 1901. This kit is an old Model Shipways “yellow box” kit that I purchased on eBay several years ago. These kits have minimal instructions and just a few parts: a machine shaped solid hull, some blocks for deck houses that are never the right size, dowels for masts and yards, and a bag of metal fittings. I worked on the kit off and on over the last several years but failed to take any photos. Once I finished the paper model of the liner United States I decided to attack the Gjoa seriously. Attached are a few photos showing the construction of the cap rails and the pin rails. For the cap rails I traced the out line of the bulwarks onto a piece of sheet wood, widened the line to the cap rail width, leaving plenty of extra wood. The rough rails were then glued in place and shaped to fit. The pin rails were done similarly with lots of test fitting with final shaping after they were glued in place. In the photo the port side pin rail has just been glued .
  19. My only experience is with the United States. And it is a waterline model. To be clear about your question: no plans or parts below the waterline
  20. These winches for my United States liner are at the limit of my vision
