Posts posted by xodar461
I would like to know if any builder out there who have completed Amati's Revenge 1577 kit have any spare lanterns that were not used during construction. I am adding light to the interior of the model and I would like to have a few more than the ten supplied. Here is a photo :
Here is what I am doing.. The LED flickers to simulate a flame.
Send me a PM if you have any to spare
Thanks,
Jeff
More decks now planked and installed. Main gun deck, bow deck, raised lower deck and rear deck. I decided to use a softer graphite pencil (#9) to simulate the caulking as a standard #2 was a bit light (note the difference between the main gun deck and the other decks at this level).
The bow deck was partially planked and then installed as it has to be bent to insert down the frames. Grating frames are left open for now. Still not sure if i want to use the etched brass. The next pic shows more beams in place to support the upper decks as well as the aft most frame #14 now installed with the bare upper stern deck. Beams 6B, &b are half frames with support columns. This is one piece in the kit and the support column was not that good.
Here is one from the kit and my replacement. The foot of the handmade column is longer than the kit as the beam sits in a square hole in the main deck. If the foot of the column was as short as the kits version, the round part of the columns would end at the deck. I made one that way before i realized that this would not be a good look
Here they are installed:
A ladder is installed from the main to the lower deck:
And finally, a few pics of the whipstaff assembly, capstan and rear gallery deck planking. The tiller arm is temporarily inserted to show how the whipstaff will connect to the rudder.
So far no more surprises. The gaps in the planking on the side galleries are to allow fitting of the side patterns. It will be important to get them correctly positioned as they determine the height of the gunports from the deck. I will show some pics with a few cannons in a future post. I also plan to fill the bow and stern with basswood that will allow for a better purchase of the hull planks. I also plan to install some lighting in the lower decks as all this work will be invisible one the upper decks are in place and the hull is planked. The kit comes with some PE brass lanterns and I hope to be able to put the light in them and run the wires through the frames and out near the keel. Here is a link to show the the kind of light i am taking about:
https://www.modeltrainsoftware.com/flickering-led.html
I will have to work out the lighting details before i progress much further with the build.
Jeff
- mtbediz, CaptainSteve, zappto and 8 others
- 11
An interesting issue arose when i fitted the main deck after planking. It seems that the central part of frame 4 is too high. Before doing anything drastic, time to figure out what, if anything, may have gone wrong. here is a pic to show the details
the red arrow shows how much the frame is off. If not corrected, the main deck will not seat correctly onto frames 2,3. there are 2 decks that are fitted above this one and the alignment of those 2 seemed correct when I dry fitted them. Also, where frame 4 meets the bearding line seems OK too (yellow arrow). Here is a shot of the plan
Looks OK here too. this is how the deck is seated with nothing done. Red arrows show the gap.
As I could find nothing wrong with the alignment of the overlying decks or with frame 4 at the rabbet, I have to assume that the frame is off by a few mm in the area of the yellow circle - so this is what I trimmed down.
now deck is seated perfectly along frames 2-4. hopefully I don't have to modify anything else as the upper decks go in.
This is the planked main deck, not yet sealed with poly
Jeff
- mtbediz, Bill Morrison, puckotred and 6 others
- 9
After the frames have been attached, the first deck to place is the orlop. Although the manual shows this as 1 piece, the kit splits the deck down the middle for 2 pieces - much easier to fit this way. The deck is planked off the model and then glued onto the frames. The hatch coamings and gratings are then fitted. As others have pointed out, the gratings are photo-etched brass and not wood. One problem with replacing them with wood is that the grating openings may not be to scale - often they are too big. As this deck is deep within the ship, it won't be too visible anyway so I'll decide later if I want to change out to wood for the upper decks. here are pics of the deck pre and post application of satin poly. I think the gratings are acceptable.
Also note that I have decided to not use treenails to the deck. At this scale they would be barely visible anyway.
- Old Collingwood, Archi, hexnut and 6 others
- 9
Here the frames have all been fitted and glued. Only one frame glued at a time and the false decks were used to maintain correct alignment. The frames were also tapered at the bow an stern.
Note that frame 1 extends pretty far below the curve of the false keel. This is because a slot is present to fit the stem. In order to get an idea of the true curve here, i fitted a think piece of scrap wood to the keel as you can see in the next 2 pics. This area is not well seen in any of the photos in the manual and one may think that more material need to be removed from frame 1. Nothing worse than finding out later that too much wood was removed!
- mtbediz, puckotred, Bill Morrison and 3 others
- 6
To start, I test fitted all the bulkheads onto the false keel. Nothing is mentioned in the manual re: cutting a rabbet but i decided to proceed. The stern has to be trimmed down otherwise it will be wider than the rudder post when the planking is placed. The lowest extent of each frame was marked and the rabbet was cut from was below the frame. Here is a pic from the stern:
And here is the rabbet from frames 7-9.
- Archi, CaptainSteve, puckotred and 2 others
- 5
The kit was well packaged and after inventory, I don't seem to be missing anything. The fitting seems decent enough though the blocks will have to go as they seem to be the standard kit block that are too square. There is a lot of photo etched brass with this kit, including the gratings. The backbone of the kit is made from something called MDF (medium density fiberboard). Had to look this up as I have never worked with it. Another type of wood that I had not heard of before is dibetou ( From the web: The heartwood is bronze orange-brown, with gum lines causing black streaks or lines. The grain is usually interlocked, but is sometimes straight, texture moderately fine to fine). It seems to have a rather delicate grain so I'll have to be extra careful in removing parts from the pallet so as not to split the part along the grain. Here is a photo:
- Bill Morrison, CaptainSteve and zappto
- 3
Greetings. This is my first attempt at a build log, though it is far from being my first ship. Having recently finished HMS Kingfisher by LSS (see gallery), the Revenge caught my eye and I decided to have a go of it. For those of you who decide to follow along, please note that my work on models can be sporadic at times. I will try to post updates as I complete each page or 2 of the manual. Kit was ordered from Ages of Sail and here is what comes in the box.
- Bill Morrison, Archi, Robin Lous and 2 others
- 5
Nice work on the Sopwith. I built this model a few years back as a break from ships and like you, wanted to put a scale figure in the display. I can't really carve, so when looking on line all I came up with at anything close to the correct scale was a WW1 US soldier. If you search for this "verlinden 120mm WW1 soldier" you will find some available on eBay. Here's a few pics to show what I did with it. I think it is an acceptable alternative to a pilot and gives a good sense of the airplane's size.
Jeff
Revenge 1577 by xodar461 - FINISHED - Amati - Scale 1:64
Past few weeks have been spent installing the below deck lanterns. I decided to add a light to each one to hopefully illuminate some of the work done in the lower decks. The light s are 1.8 mm orange LED that flicker to simulate a flame. To hang the lanterns a hole is drilled in the corresponding beam with some support wood on either side as the hole will weaken the beam. I then gouged a small trough in the beam to fit the wiring. The wires were then run through the beam and down a trough in the frame to exit beneath the lower deck. The photos illustrate some of the work.
Below is an LED test fitted through the beam and frame
A close up on one lantern:
Wiring complete for this one:
Multiple lights installed. lots of wires!
A total of 10 lanterns and 4 LED "torches" will be installed. All can be run with a nine volt battery.
Jeff
