DaveBaxt
Everything posted by DaveBaxt
  1. Nice one . I have already fitted the blocks to the yards. As far as the instructions, only one block required. However as I am not carrying any sails so should I be ok or will I need to change them as I believe the book by Petersson and yourself to be correct. Thanks again for your help. Best regards Dave
  2. I am not sure about Aluminium. Maybe can with silver solder but don,t believe the fumes are too healthy but that could be when welding. Maybe better to use brass if you want to solder. Personally I would go with what Tim has suggested as he has made a very neat job and would think it would be strong enough. Perhaps some expert can step in here if they have experience with soldering aluminium. Sorry if this is not much help
  3. Thank you Gregory for your quick reply. This looks to be the same as the box art. By the way I am still waiting for my book 'The History of ship Models' which I ordered from ebay. Unfortunately I just found out its coming from India so will still have to wait another few weeks yet! Just noticed on the picture you have sent me, those British 18th centuary lifts ,the blocks on the end of the yards look to be double blocks and this is confirmed by the book I have ' Rigging period ship models' That looks to be a bit tricky how is that done? can you use one of those blocks that look like a violin or similar. Was this also to reduce the amount of weight required to change the angle of the yards? Best regards Dave
  4. Bounty Amati I understand that the height of the yards are different when sails are furled or unfurled. However what is the position when there are no sails. The drawing only shows the position when sails are raised. The box art ( without sails )shows that the lower main yards are raised, the top yards and top gallant yards are lowered on both fore and main masts. The mizzen mast is the same but only has two yards lower yard which is raised and the top yard is lowered.
  5. Once again Tim thank you for giving me that Tip and what a great idea it is using the aluminium tubing. I have had a look at a Cornwall Ship models shop here in the uk and they stock a number of different sizes of aluminium tubing and does not look too expensive so will definately get some of this for my next model I build. I eventually got the hang of using the copper strip however it is far from perfect and no where near as good as your yards. However I think I will move onto the rigging again and follow the previous sequence you gave me earler. Best regards Dave
  6. Yeah I also thought a serving machine was the way to go but I had a few problems sourcing the parts to make one . So I decided to buy the Serv O matic made by Chuck . Received the parts and managed to build it within a day. In the mean time I have been putting together the Yards which I have now completed. Here are a few photos of the yards. I am now planning on going back to the rigging, starting with the stays. AS yet I still need to re do a number of stays, hoping I will do a better jib with the serving machine.Thanks again for your input. Best regards Dave
  7. I would have thought the aluminium would be much easier to work with than brass but could be wrong. I have also noticed with my kit that a lot of the dowels are under sized quit a bit. Mainly on the smaller stuff, for example when the drawing says 4 mm the dowel is 3.5mm , Next time I will check the kit at the start and perhaps buy the next size up for that particular spar.
  8. Wow, you are even nearer to Cook than my self. I live in the <North East and have visited those areas you have just mentioned many times. Regards the Endeavour and Bounty being similar .I think you are correct, however I am using the Bounty as a learning curve and have made lots of mistakes, some I have managed to do again, others I have had to leave. Hopefully I will have better luck with the Endeavour. Regarding the Bounty. Please follow Tim Moores Blog , Although a different manufacturer again , it is a fantastic model and he is very helpfull as is very many people on this forum.
  9. Cheers Tim that is definately something that I would look at in future builds. I don,t fancy making all those yards ggain. I wish now I had looked at your blog before continueing further. Just for the record Tim . How did you join the wire and tubing together and also what are you using to black the aluminium? Thanks once again for your input. Best regards Dave
  10. I have been considering the Endeavour for some time as I have some interest in Captain Cook who lived not too far from me, However I also like the look of the Snake. Good luck with your Bounty I am sure with your experience she will look great. I think the main problem I had with building the hull with the Amati kit was the supply of 6mm x 1.5 mm Walnut for the first layer of planking which needed a lot of soaking and heating to get the planks to go around the bow and all had to be tapered too. I understand the Endeavors first layer of planking is lime,which I think is easier to bend into shape but I have not used it.
  11. Great looking job. I especially like the look of the copper bottom and wonder if they came with the kit? I am thinking of trying caldercraft for my next model. Are you happy with the instructions and materials. Best regards Dave
  12. Welcome aboard and thank you for your kind words. I hope you have better instructions with your Caldercraft kit.than with my Amati one.I have heard that Caldrcraft are one of the better manufacturers out there although the Amati kit seemed to be pretty good stuff . Keep us posted and let us know how you get on. I have now finished putting together my seiizing machine and I am now ready to continue with the rigging once I have completed the yards. Hopefully not too long now, although I found it difficult to attach the thin dowels which sit on top of the yards and make the yards wider. The copper strips were difficult to bend to the correct shape and make a neat job. Perhaps next time I should try and think about some kind of jig.
  13. Yes good point I decided after taking the advice on this board to keep a bottle of acetone on hand in an emergency. I have tried different set times and as you say, it takes a bit of practice. Once again thank you for your input
  14. Trod I am no expert but it seems to me that it is an age old argument and you will get lots of different answers. I try to use it as little as possible but found it great for metal to wood. In some situations where timing is important I am now using an accelerator so once you get your piece held into position then Zap it with a bit of CA accelerator and your done. I try to use as little as possible and use those thin nozzles ( mainly to stop the end of the CA container blocking up) you can buy a 100 for a few pounds sterling on Amazon and just throw the end away after about a week. I do not use CA on the hull but many do. I have tried a few different ways but I think you just have to see whats best for you. This is only my second ship and find practice make perfect . I already made a better job of planking the second time around. I am currently using CA glue on my rigging knots but thinking of changing tack and trying pva glue on them instead of CA as the knots and siezings are brittle rather than just stiff with the bees wax. Hope this helps Dave
  15. I would like to thank every one who has replied to my questions regarding what is to me a very complex subject, hopefully with your help I now understand a bit more .I think I will once again re do some of the rigging which there is not too much as I have caught it early enough. So really glad I asked the question before proceeding. As it happens I have decided to change tack slightly and build those yards whilst I wait for my servo o matic I have just ordered from chuck. Once I have received my serving machine I will continue with the rigging. Best regards Dave
  16. Ok I have now managed to serv a number of Stays by hand and its killing me. I generally have issues with back pain and serving the line is jsut adding to my problems. I have careful consideration and now I see that Chuck 's Servo O matic is now back on sale and postal issues due to the covid pandemic have now been resolved I have decided to by one. Whilst waiting for delivery I have changed tack and I will now make the yards and gaff. I have also been asking lots of questions about the colour of threads for standing rigging and have decided to go against what is in the instructions and go with the light brown inbetween the blocks on the standing rigging and stick with black between the hearts. Sorry no photos at present as having problems with uploading photos( slow internet speed at my end) I am now wondering do I go with lighter gauge threads as I go higher up ( standing rigging ?)
  17. Wow! This is more confusing than ever.Just when I thought I was getting there. So if I try to remember it for next time .Can I say for standing rigging anything that runs through a block and tackle or deadeyes is light brown/tan in colour. Any)thing else is a dark brown in colour ( black as I have loads of it) All running rigging is light brown in colour. Crow feet .Now surely that is also adjustable and would not normally be tarred and therefore light brown. Hoping I am correct but probably not . Sorry for slipping another question in regarding standing rigging . I am assuming that as the Stays ,Back stays and Shrouds go higher up the thread becomes thinner or I should stop assuming anything? Thanks again for taking your time to explain things to me Best regards Dave
  18. My mistake I di mean to say Lanyards honest haha. Ha so The hearts are Lanyards and block are tackle, what about dead eyes. I assumed the ropes between them were lanyards too ! Thanks for your input Popeye much appreciated, best regards
  19. The Stays in question are all of them .Including the back stays,however the ones I have done are the bowsprit, fore and main masts all of them have halyards of some diiscription , the ones on the Bowsprit have hearts with halyards the fore mast has hearts also with halyards between them. The main mast to the bowsprit also has hearts with halyards . I am assuming the ropes which link the hearts together are also halyards and require light tan thread . The Mizzen Stays and main preventer stays have blocks with halyards between. them. I have just spent a fortune buying black thread for the stays so rightly or wrongly I am sticking with black for the standing rigging which is tarred.. My next model I will perhaps change to dark brown. So it is as I thought the halyards need to be a light tan colour and not black as suggested by Amati. They really need to get there act together in my view. I don,t think it would be such a big task to change the halyards to light tan, so don,t mind doing it at some stage. Thanks Allan for clearing that up for me as you say I probably need the practice. Best regards Dave
  20. According to my instructions for the HMS Bounty There are a number of Halyards on the Stays which have black thread. I appreciate these are classed as standing rigging and therefore tarred. However my feeling is that as with the Halyards on the shrouds these are also classed as standing rigging but this section are not tarred and therefore a light colour and can be handled when required ( not sure why other than ropes stretch) Unfortunately I have already be fitting halyards to some of the stays on the bowsprit and have been fitting black thread. (following instructions) It is only now I have realized my possible mistake. Just for the record as this is my first build and have made many mistakes perhaps I should continue with the black for the stays as I really don,t want to go back and change all my hard work. Just for the record its the same situation with the Back Stays .Best regards Dave
  21. Just looking at your model to see how far you are on,Is that a solid hull or is the first layer of planking painted. The second layer of planking looks excellent,what sort is it? For the record my first and only other model was a Billings and I thought the fittings were excellent,although it was not what I would call a period ship like the Bounty. Good luck with your build and keep up the good work. Dave
  22. Thank you for your very kind words. Only one mod I can think of which is the port & stbd rails where the forward pin racks are fitted. Mind as I have had lots problems understanding the drawings and the instructions are not very clear either I have started copying some of Jerry's and Tims blogs of the Bounty and there are quite a few differences in the rigging I have also been studying a few books such as Rigging period ship models by Lennarth Petersson. Best regards Dave
  23. Mast completed and temporarily fitted . Started fitting the stays to the bowsprit and to the forward mast including the preventer stays. I have to get one of those automatic serving machines as doing the forward atays is giving me a pain between the shoulder blades. Here is a photo done prior to starting the rigging. I have attempted to fit all the blocks I feel is needed prior to assembly of the masts. At the moment all the masts are not glued into position. The colour of the lower mast are the ones on the front of the box and also what was supplied as the paint set for this particular model. Although probably not very authentic and possibly not to every ones taste but I kind of like the bright colours
