Meriadoc Brandybuck
Posts posted by Meriadoc Brandybuck
Hello,
An update on standing rigging.
The first tier of shrouds and stays has been finalized (ratlines going on currently behind the scenes).
Photos below showing the progress as well as the completed mainsail miniproject.
Below: the messy state of affairs before balancing and finalizing tension, with lanyard excess hanging everywhere.
Below: the mainmast, rope horse, and the snipped ends of all the falls of rope. Coils will be made and stuck onto the pins and cleats later.
Below: all the excess falls have been labeled to get the right diameter and length into the final coils.
Below: the brailed-up mainsail, with all its rigging finalized.
Below: views of the head and bowsprit with the bobstays, martingale stays, and gammoning.
Below: overall views of the rigging progress.
That’s about as far as I’ve gotten; today I got on the futtock staves and a decent number of the ratlines. Maybe another month and I’ll have the standing rigging completed at this rate?-slow but sure Meriadoc
- Thukydides, tkay11, GrandpaPhil and 2 others
- 5
59 minutes ago, GrandpaPhil said:
the hard part
Thanks; though I think in this case the hard part will be getting the stuns’ls to hang just right. When we get there. Better do some experiments.
Meriadoc -
On 2/20/2024 at 9:05 PM, GrandpaPhil said:
I am building the cat ship out of his book.
Interesting choice. I can’t wait to see it take shape.
I have the book; it’s one of my most prized possessions with all its magnificent plans. Given enough time I’d like to build everything in it and make my own variations like Ab does. For now I’ve started preparing to build a little kaag and pink sometime this year or so. Perfect little finishable projects, unlike my Badger.
Meriadoc
- Canute, mtaylor, GrandpaPhil and 1 other
- 4
A little update.
I managed to get all the rigging for the gaff and boom set. I wanted to get this out of the way before main shrouds got in the way. I don’t think the net tension of the standing rigging will affect these lines much.
You can see the vangs, topping lifts, sheets, halyards, and even an inhaul-which I’m wondering is even necessary. All lines except brails are belayed and fastened permanently; later I will snip off the excess and turn it into hanks. Not sure how the halyard falls should look. That’s a lot of rope.
The mainsail brails are still tied off at the foretop as they will eventually terminate at main shrouds cleats. The first set of main shrouds is going on now.
I made a twisted wire guide to hold the deadeye at the right height, but it always wiggles loose somehow. I have better luck just judging the length by hand and using my four hands and mouth to try to seize the shroud around the deadeye while holding it all in place somehow. I don’t even know how I do it but I have gotten better at it.
I cannot wait to get the standing rigging on her and start sculpting the rest of my sails. Anyone think I’ve made a horrible mistake by finalizing the mainsail rigging before the standing rigging?
Meriadoc- GrandpaPhil, ccoyle, Rudolf and 1 other
- 4
On 2/11/2024 at 7:39 AM, GrandpaPhil said:
I saw something on this forum that gave me an idea on model construction that I would like to try out really quick.
I am using a ship from Ab Hoving’s 17th Dutch Century Merchant Ships to try it out on.
I’m very curious about what you’re going to build from Hoving’s book.
-Nosy Meriadoc
Well back to business.
I started doing shrouds on the foremast, but decided to get the gaff sail all set up before putting the main shrouds in my way.
The boom, gaff, and sail went on in about a day’s work. I discovered that I forgot to prepare the boom sheets and peak halyard so there was some catching up to do. Also had to get all the lines on the sail- brails, sheet, and inhaul. Bending it to the gaff and mast rings (which were prepared with wire) took a while because all the little ropes get in each other’s way.
Then illness struck and things took a long pause while I recovered.
Today, I prepared everything for the final gaff sail sculpting: a jury lift and stay to stabilize the gaff and mainmast because of all the fishing weights to be strung from the sail, and several more weights had to be set up with wire hooks:See the operation below. In the end the heavier weights are more useful (about 10 grams each or so):
Brail lines are temporarily made fast to the foretop pins for convenience. The sail is wet by fingers (using a dripper just runs water down the sail) with paper towels below for safety. Weights tend to fall off and threaten to break the tiny pump handles on the quarterdeck. I got lucky.
When the sail dries, I can blast it with starch a few times to get it to retain the shape. With the sheet line pulled a bit, it should look much like the paintings. With that done I can proceed with the main shrouds and complete the standing rigging, and on from there.
I’m happy with the look so far. Hopefully the rest of the sails go well too. That’s all for now!
Stay healthy!-Meriadoc
- GrandpaPhil, ccoyle and Richard44
- 3
Well, I hope everyone is doing well.
I haven’t been; in keeping with the recent theme of nothing going to plan, I ended up sick with pneumonia for about three weeks, stayed a spell in the hospital and finally got out alive.
It’s good to be healthy again. Really good.
I have lots of unreported progress. So I guess I’ll get to it.
Boats.
The kit includes two boats, a 16’ cutter and an 18’ launch, though the instructions are a bit unclear or mistaken about how they are to be planked. In any case I proceeded to assemble them, along with a scratch built 25’ longboat for fun since I’ve wanted to try building one for some time.
Above: test fitting my thwarts in the launch. I added thwarts along with a hastily scratch built windlass. The kit wants you to leave the thwarts out and stack the cutter inside, but that was not the usual British practice. Also I have other plans for the boats.
Above: cutter taking shape on the right with its clinker planking and my longboat (from Chapman) with its frames finally glued together.
Above: planking on the launch displaying the hungry horse effect. I found this difficult to avoid with the soft paper employed: in retrospect it would have been best to find more rigid planking even if it was a bit too thick. I can try to stick this side out of sight in the finished model; the other side isn’t as bad.
Above: added my own washstrakes. Longboat coming along with filler. Needs another go.
Above: final verdict for the kit boats- I find the launch far too blunt-bowed for 1776. It seems a bit more 19th century. In any case it manages to fit in the narrow space available aboard the little brig. I plan on having it suspended from the main & fore tackles and yard tackles, being swayed out. Though that might prove too ambitious and incompatible with the sailing activities going on. It would be a fun visual effect though.
The cutter ended up a bit too big as the clinker planking had trouble meeting the frames. It looks alright though and will go in the water with a spritsail and jib. You can see the templates I made for those sails below, along with a first batch of sails to make for the ship.For some reason sailmaking is enjoyable, even though it shouldn’t be. It takes too long. But I got the first batch ready.
Next post, we will talk about the status of the ship itself.
-Happy to be functional again Meriadoc
- Rudolf, GrandpaPhil and Richard44
- 3
Well, I have much to report.
I ran out of things to do that aren’t rigging-related. Rigging is my favorite part, but I wanted to make sure everything was ready to go so it will go as smoothly as possibly.
Masts have been finished with all blocks and fittings (except jeers yet) and when all was finished on the hull, they were finally glued in place and await shrouds.
I also experimented with sail manipulation and achieved decent results. Please see below.
Above- lots of subassemblies and two sails I prepared for practice and experimentation.
Above- masthead sheave blocks (going to check that terminology when my dog gets off my lap) for the running lines of the headsails.
Above- no way to reasonably hang these blocks from the tiny paper-construct fore top, so they are simply attached with a drop of CA.
Above- I decided I needed a saddle for the halyard of the flying main course crojack yard. The regular jeers will hoist the full-diameter main topsail spread yard.
Above- speaking of so many yards on the mainmast, I installed extra cleats and blocks to handle them. The kit doesn’t include jeers or even halyards for the main yard but I decided to use jeers for ease of hoisting. Slings were not quite yet in use at this time, so something robust would be desirable to hold the weight of the yard.
Above- a couple experiments. The cloth course was rigged to a jury setup with all its clews, bunts, and leech lines and hauled up. This looked completely unconvincing but I remembered to try fishing weights, so after wetting the sail I used weights to give the sail scale gravity effects. When it dried I used laundry starch in a spray can a few times to stiffen it before removing the weights.
There is also a brailed gaff sail and a tissue that I tried “clewed up” around a chopstick. Not bad if I knew what to coat it with for stiffening and longevity.Above- the result of my sail experiments. I also did a topsail, less tightly hauled up. It was made of a nylon blend fabric that feels nice but isn’t as workable. For one it’s nearly waterproof and thus difficult to soften. I used weights to obtain the curves, and lots of starch to hold it but it’s still pretty pliable since the starch can’t soak in. Acceptable result though for loosely hanging sails.
Based on these results, I will use the cloth from the lower sail (a fine lawn if I recall) and a diversity of fishing weights to sculpt each sail on yard with my jury rig mast before final installation on the model.
Above- my little figurehead painted with little head knees installed on each side. Also boomkins to handle the foresail tacks and timber heads made of Proxxonned 2x2mm stock. Also I went ahead and stuck in the boom topping lift so the ship looks that much more believable.
Now for standing rigging and methodical spar work and sail sculpting.
Happy Thanksgiving!Meriadoc
On 11/17/2023 at 4:47 AM, GrandpaPhil said:
Out of curiosity, do any of the rest of you make Christmas and/or birthday gifts
I honestly am not much of a builder. My love for sailing ships and need to see them in 3D causes me to tangle with skills that by no means come natural. I wish I was more of a craftsman- and I wish I had more space and time for it too!
Hope you’re enjoying those dollhouses! Not a bad distraction.
Meriadoc
- Canute, mtaylor and GrandpaPhil
- 3
Well, summer has folded into the unreachable regions of spacetime known as the past, and I spent way too much time enjoying a borrowed copy of the new Zelda game- but the Badger has not been forgotten.
I have completed assembly of the masts and principal spars, almost got the hull completely fitted out, and have been prepping all sorts of blocks and started getting the yards fitted while I dread the chain plate fiddling. Really, I had hoped to be doing clove hitches by now, but alas, time does not slow.Photos:
Above- I had to fashion the trestle trees from bamboo dowels that I planed down; the paper was too flimsy even soaked in CA. Bamboo is a good material for this sort of thing, whereas I am no master craftsman. They look best from a safe distance.Above- forecastle timber heads made out of square dowel sanded to rough dimensions, to be proxxoned into their final shape- after I practice a little with the new Proxxon router.
Above- the deadeye for the rope horse upon which will ride the main topsail spread yard. And ugly pins which will be covered in rope someday hopefully soon.
Above- stay collars look simple enough but take a lot of time and knots to prepare. Glad to have them ready along with the associated martingale and bobstay deadeyes
Above- gaff throat halyard block with brail fairlead blocks. I don’t know if that term is correct.
Above- gammoning cleats and my makeshift figurehead. I will have to sit down with some putty and sculpt some sort of scrollwork to make it a bit more convincing. Self-respecting ships of this period almost always had a figurehead, and I thought a little bit of effort would go a long way here.
Well, don’t be shy. Let me know what you think. I am hoping to get into running rigging by the end of the year, but I’m wondering about the build order with studding sails and so much scale gravity to work into the sails.
I guess I’ll do fore and aft sails first and then work the foremast course>tpsl>tglnt>ryl and then the mainmast. But do I do stunsails last, or as I go? I also have to make the boats, and for fun they’ll be in the water setting sail, or something visually interesting.
-Meriadoc
10 hours ago, GrandpaPhil said:
Sounds like a lot. It really isn’t. I could finish it up in a few months if I really wanted to.
I like the optimism and I envy the sort of time one might have on their hands to be able to finish up the hull, details, and entire rig of a ship of the line in a few months. I’ve been having some Zelda issues lately which have severely hampered my progress, in the spare time I do have, rigging my Badger.
-slightly jealous Meriadoc who has definitely not been playing the new Zelda game
- GrandpaPhil, mtaylor, Canute and 3 others
- 6
I think this highlights the difference between a sail plan as an exhaustive diagram of all the sails a ship might set at any given time (well, except they usually don't depict studding sails) versus the routine sails actually used in prevailing conditions. Practices changed over time, and the rig would be modified to suit the season or locale. It's interesting to read log excerpts (like in the book Nelson's Ships by Goodwin) to see what sails were noted as set or taken in depending on various changes in conditions. I suppose you could phone the NMM for a copy of the Bellerophon's log?
Meriadoc
Good morning Mr. Mclaughlan! and good morning everyone!
Apologies for the misspellings and the general ruckus.
It is great to hear the input from Bob Fraser and the esteemed author himself, concerning the publishing and practical difficulties.
As it seems unrealistic for museums to upload and digitally catalogue everything relevant to such niche research, we are powerless to pursue much until we have better-located collaborators with more viability for publishers.
We can leave this thread as a beacon to any would-be contributors as an idea pool for where to start and what to consider including.
Some of what one might include in a further volume exists in extant works and may either be brushed over or treated in an original way- Chapelle’s discussions of the American privateers, lots of books about schooners, and the detailed Seawatch exposition on the Swan class, and possibly others I’ve missed.
A further volume might take a more analytical look at how sloops were used by various navies, how privateers operated, the proportion of admiralty resources devoted to fielding sloops over time compared to frigates and line of battle ships, and what influenced design choices throughout the eventful decades in question. The impact of carronades and copper plating, the expansion of trade, and other developments would have told on the design, tactics, and importance of sloops.
Considering Mr. Mclaughlan’s comments about the number of different nations developing small warships, it is necessary to consider splitting the volume based on region or conflict, or picking up on the general trends and supplying examples of the evolution of diverse subtypes. Furthermore, to be worthwhile it must not simply catalogue information that is already well-known, but provide new illumination and analysis in keeping with the quality of the original volume (a truly challenging task indeed).
(In a few decades I shall begin looking into the viability of a Greenwich-area retirement.)
If I may be bold enough to ask the author’s thoughts- Mr. McLaughlan, what sloops of war of the American Revolution or Napoleonic period do you find most interesting to discuss or paint?
-ever-hopeful Meriadoc- druxey, Bob Fraser, mtaylor and 1 other
- 4
On 7/1/2023 at 5:31 PM, Bob Fraser said:
I've had a reply from the author Ian McLaughlin and summarised below with permission.
Thank you for reaching out to Mr. Mclaughlin and getting an update on the state of research and the challenges facing a further volume.
I’ve been thinking about what could be done by aspiring scholars interested in picking up where the last volume left off, in collaboration with the author. The topic does remain sorely under-covered and stands as a glaring hole in our picture of the royal navy at the time, whose majority was made up of small patrolling or support craft.
It occurs to me that a lot of the research from the American side of things can be gleaned from referencing Chapelle and other extant works, while the best record of actual hull forms from American vessels of the revolutionary war and into the Napoleonic era comes from British admiralty drafts of captured vessels.
As for the French side of things, I imagine that again British admiralty drafts may be adequate to explore their input, though some research on the logic of their design and use would be necessary. I’m also curious of Mediterranean influences on French craft of this period, and a glimpse at xebeques frigates and tartane privateers may make sense.
British designs (from a quick glance at nothing more than the Wikipedia list) seem to include successive batches of 6 lbr ship sloops not radically different from the designs arrived at by the end of the Seven Years’ War, plus attempts at developing an effective brig design (such as HMS Speedy) based around 4 pdrs for budget presence.
Royal navy schooners seem to have mostly been built in Bermuda (such as the famous Pickle) and many schooners were purchased or used as captured, generally built in America even if captured from the French. A chapter or subchapter on Bermuda shipbuilding would probably be appropriate to include as well.
A fact that strikes me is that the British Bermuda schooner classes were all rather smaller than most of the American “letter of marque” schooners we now call Baltimore clippers.
Then there are the large populations of Cherokee and Cruzer class brig sloops and the smaller “gun brigs”, all an evolution in applying the carronade to amplify firepower for affordable omnipresence through small hulls and crews. There is a memorable image somewhere of a small carronade-armed brig playing an important role in the capture of a French 74, though I forget the details of the incident.
A discussion of the impact of the carronade on naval warfare would be unavoidable, as sloops became primarily carronade-based platforms over time.
A discussion of the development of fleet supply lighters and water tankers to support the Brest blockade and ships patrolling foreign stations may also be appropriate in such a volume, as they were small utility ships vital to the fleet (but difficult to market their own volume about).
This is all no doubt known to Mr. McLaughlin and most of us interested in further research. I’m wondering if a different publisher could become interested in helping such a project along, if one or more intrepid contributors were able to help assemble the needed research and images. I wish I was in a better position to offer more than simple words!
We have the ability to coordinate online across oceans, if only we could get the NMM and other institutions to send us all they have on the subject matter! Or upload it in a searchable way.
-hard-headed Meriadoc -
5 hours ago, michaelpsutton2 said:
I had always hoped as well for a follow on volume to include up to the end of the Napoleonic period as well. This is obviously the moment for someone to step up[ in collaboration with the esteemed Mr McLaughlin and the new proprietors of Sea Watch Books.
This is what I was thinking. I’d love to take on some of the burden but I live a long, long way from the NMM…
-Meriadoc -
5 hours ago, cotrecerf said:
It's a pity that there is apparently no hope for any follow-up volume.
There is hope!
Though not in the near future.
In the meantime I found a book called Frigates, Sloops and Brigs by James Henderson focused on the Napoleonic period. It dates from the ‘70s. I ordered a copy, so I’ll see if it’s any good.
-positive Meriadoc
HMS Revenge 1577 by GrandpaPhil - 1/64 - CARD - from Victory Models Plans
in - Build logs for subjects built 1501 - 1750
I’m interested to hear how that goes.
I’ve some very small and thin stunsail booms and yards to manufacture at 1:100. I’ve been sanding down bamboo dowels to the right diameter, and am also considering brass wire for the tiny yards.
Meriadoc
