Meriadoc Brandybuck
Posts posted by Meriadoc Brandybuck
So much energy to copy and cut out hundreds of parts in a day. What do you eat for breakfast?
-Meriadoc
- mtaylor, Knocklouder, Canute and 1 other
- 4
8 hours ago, allanyed said:
material of the sails
Thank you! I too have admired the legendary skill of Doris and her creations. She is an inspiration to us all.
The first photo was ripped from the Seahorse website, and is of the original test model. I don’t know the exact fabric used, but it’s got to be soft cotton or linen. If you Google something like “seahorse Badger scratch” you can find the original build logs in English and Polish.
-Meriadoc- GrandpaPhil and allanyed
- 2
34 minutes ago, ccoyle said:
WAK as the publisher
Good thinking! Though, incidentally I was under the impression that the search field doesn’t work for strings of less than four characters.
(Like searching “Fly” used to not turn up any of the HMS Fly logs.)
edit: searching WAK works!-Meriadoc
- mtaylor, GrandpaPhil and ccoyle
- 3
Hello,
Do you ever see a painting of a ship and become struck with the magic, serenity, or majesty of the scene and wish to try to create something similar in a model?
I had picked up this kit of the Badger from Seahorse, intending to keep it around as a back-burner project with no clear start date in mind. Something to piece together as I mulled over problems on more important projects:
Months before that, I had found floating around the internet a 19th c. painting by one Richard Brydges Beechey of a ship of the line taking in her sails (HMS Asia of Navarino fame- and look at those stu’n’s’ls coming in):
I saw this painting and thought, “wow, that would be a magnificent effect to pull off some hypothetical day when one has room for a giant fully-rigged ship of the line in one’s house and has mastered scale sail manipulation, scale gravity, and patience!”
Then, for better or worse I realized I didn’t have to wait for some hypothetical day and could give it a go with the Badger; it has enough sails with the addition of some royals (likely enough for an ambitious commander to rig up), it’s in the stash, and I need experience so might as well try. And now this is my main project. This is not how this year was supposed to go.
Before going much further, I want to talk about the ship. There is a well-known Jotika kit as well as the fantastic Seahorse paper kit I’m building. Plans and log excerpts from the ship are available in Nelson’s Ships by Peter Goodwin, while background history and even more plans are available in Howard I. Chapelle’s The Search for Speed Under Sail.
You may have heard this ship introduced as Horatio Nelson’s first command, however that is almost certainly not quite the case, as Chapelle records. The Badger in the admiralty draft (lines taken June 1777, Portsmouth)-and thus in all the models- was indeed an effective patrol sloop which quite impressed Vice Admiral Gayton on the Caribbean station, but by October she was in a sorry state and he indicated in November correspondence that he would have her replaced with another vessel he had purchased. Young Nelson took command of “Badger” essentially at the start of the new year (‘78) and the logs indicate a refit is taking place at that time. After this point new things are mentioned in the log not mentioned before- royals as well as a spritsail topsail set on multiple occasions.
It is never mentioned in the log, but we can be confident that the ship was replaced and the winter was spent transferring everything useful over to the newly purchased brig, whose name was now Badger, and she simply inherited the log and navy register position of the previous Badger. I think this was a common enough practice in the history of the navy, especially when it had to maintain numbers despite high wear & tear on a foreign station. The takeaway is that we have no idea what young Horatio Nelson’s Badger looked like exactly. But we know in astonishing detail what Lieutenant Everitt’s Badger looked like!
Chapelle’s data include spar dimensions from the admiralty draft and a sail plan, which indeed differs from the lovely Seahorse plans. The kit plans generally have spars a bit too long and masts a bit too tall (and the boom is too short and the gaff too long).
Book vs kit- not to scale:Below is a detailed model shown in Chapelle’s book:
The main mast is to have a spread yard for the foot of the topsail on a rope horse (as opposed to putting the gaff and boom on a separate pole) and an improvised flying main course on a slightly smaller crojack- held in place only by the halyard.
This disparity in spar sizes presented a bit of a dilemma but I’m thinking I will stick with the dimensions from the kit, as this project is much more about stunsail art than historical accuracy, and the differences are not drastic. (Definitely has nothing to do with the fact that I had already enthusiastically prepared some spars and am too lazy to go back and redo it in this case..) Furthermore, I’m nervous the visual effect I want to achieve might not work as well with the slightly smaller top-hamper- this entire project being one giant visual experiment after all.
So about building the actual ship.
I started sticking the hull together in January. Goes together like a charm. Buy the laser-cut parts. Stick the frame together. Cover with paper cutouts for stability. Do your longitudinal strakes with gel CA applied only to frame edges. Final planking with printed paper (but you must edge-paint everything appropriately on the outer layer). Then it was time to do the wales, various deck fittings, and engineer cannons using toothpick shafts, paper layering, wire bands, and a glue drop for the ball.
I dry brushed the guns lightly with dark grey, but forgot to add touchholes…
The kit includes paper wedges to roll cannons with, but I found this concept to be unworkable with either thick or thin paper for 1/100 four-pounders, thus toothpicks were butchered for my guns.
I’ve also been assembling the laser-cut blocks, preparing the masts and larger spars, and starting to think about scrap experiments to try to finesse the clewed-up sails and dangling stunsails.
I made a rough plan to relate the visual effect of the painting inspiration to the actual ship I’m building with its particular spar anatomy.
And I’m taking bets as to how long you think this will take to finish
The nice thing is that this time, I don’t have to engineer the entire rig and belaying scheme from guesswork and low-budget research. Seahorse has it all planned; I just need to make a few additions. Those will be:
-Flying royals (needed for visual effect)
-Flying main course (will look nice and it’s even correct)
-Stunsail inhauls (needed to achieve the dangly stunsails- for some reason these lines are absent from the Seahorse drawings)
Wish me luck!
-Meriadoc
I got this book used about a year ago and plan on building at least one of the sloops he discusses.
This book really does set a high bar for this sort of work that I hope to see followed up on.
In particular, he does an admirable job explaining the physics that pertain to smaller warships and warships in general. Concepts like the problem of scaling down of two-dimensional sail plans to three-dimensional hull volumes and the need to obtain slight lee-helm when sailing upwind are well explained, as are their relevance to the design problems that had to be solved over the years. (Now I know why masts are raked!)
If anyone knows how to contribute to the next batch of research and exposition in this vein (into the American Revolution and Napoleonic period) I’m all ears and would love to help.
-Meriadoc- mtaylor, Canute and uss frolick
- 3
Sounds like lots of love and tacos going into the planking, which proceeds at a breakneck pace if we’re comparing it to wood bending.
Meriadoc
- Canute, Glen McGuire, GrandpaPhil and 1 other
- 4
The nice part about not having a kit is you can spile the planks appropriately from the start. Or on the second layer. Or simply on the cabinet paper layer.
Do you need to stabilize the frames with a thin paper layer like the Seahorse method?-Meriadoc
- Canute, Glen McGuire, mtaylor and 1 other
- 4
Of course in the end, the difficult decisions are yours to make.
I however don’t believe historical sources consider mast length to be deck-top. Usually it is from the step on the keel or whatever position to the hounds or what have you. Deck-top is a more useful measurement for us modelmakers, but shipwrights thought differently.
I did two quick case studies to demonstrate this. Hopefully they are clear. The easiest is right out of Chapman, the Bermuda sloop on plate LVII, no 15. It shows the actual mast right next to the lines of the ship.
Here you can clearly see that the mast from step to top of hounds is about 120mm, whereas the breadth molded is visibly about 42mm. Close to 3 times but clearly that’s from the step to the hounds, where your top or cross trees would fit. The location of the step can be seen in the draft.
I also looked at the Mediator sloop from Chapelle (Search for Speed Under Sail).
The mast length hounded corresponds to 104 mm (63 ft at scale of ~1/185). If I measure from about the deck level to the hounds or top, I get 88mm (check above). 104mm does approximately agree if I guess about where the step should go:
If you consider that these sloops were both speed demons and considerably larger (~60 plus ft length and ~21 ft beam) thus more stable based on internal volume per sail area, this represents an extreme upper limit to the mast proportions one might expect on a very small mid-18th c. packet sloop.
I hope these examples help. The picture in Chapman finally helps me understand what “hounded” ought to mean.
Now I’m wondering how over-proportioned my sloop ended up 😕Whatever you decide to do with your rig, finish it and enjoy the process!
-learning bit-by-bit Meriadoc- GrandpaPhil, Strelok, mtaylor and 1 other
- 4
I believe they treated the wood with some sort of compound which did the trick, giving a brown color. I don’t know exactly what the elizabethans used. I have a book coming in the mail that might have the answer, but I’m sure someone around here knows. But probably just treated wood, dark brown and easy enough to simulate with cabinet paper.
Wales seem to have been black but that could be extrapolating later practices inappropriately. There’s a few helpful galleon buffs around here who can probably tell you all you want and more if you bug them about it.
Happy scratch building!-Meriadoc
- Glen McGuire, mtaylor and GrandpaPhil
- 2
- 1
4 hours ago, Strelok said:
I lost bulkhead E somehow
Did you check the fridge? It must be hiding around your desk somehow.
I like how you work. Clean design, well thought out ahead of time. Gives me ideas.
I think I detect an error in your rigging plan though. The upper masts and spars look okay but the lower mast is almost certainly far too tall. You said you cross referenced other sloops, but the mast lengths listed in tables are notoriously confusing for modelers as they often include (and don’t always specify) the entire length from the step (on the keel) to the hounds (a difficult term to find a definition for) or the cap. Or the top.
A common mistake is to forget to subtract the height of one’s spine/false keel, for example.
Another point is that the smaller the ship, the less proportional sail area it can safely carry due to to the math of volume decreasing faster than area, so scaling down rigging plans or formulas that work for larger vessels doesn’t work, while this sloop is almost the smallest ship in Chapman’s book. You might try to compare sail area of similar sized vessels to inform your mast and spar figures.
I hate to say all this as I know you’ve done an extraordinary job planning your rigging! However, I’m quite sure your lower mast has fallen victim to an error somewhere, either in the historic fuzziness of what is meant by lower mast dimensions in any particular record, or by forgetting to subtract for your model’s structure, or perhaps both.
Loving how this build is progressing!
-Meriadoc
- Roger Pellett and mtaylor
- 2
Why, hello!
I just wanted to reassure everyone that this build has not been abandoned. Over the last year I made some progress, getting the keel and beak and some of the trickier wales on. And the gallery.
It’s hard to come back to this project now as I have evolved a bit as a modeler; I realize just how much of a “product” these kinds of kits are and how many corners they cut to make a kit cheap and attractive to lazy builders. It may make business sense, and to be fair this is one of their older and cheaper kits. However it is important for us as modelers to unlearn the myth of straight-cut planking; and plywood has no business in our ship models. At least for the visible parts.
Still, I mean to finish this kit, slowly, with some more research. I look forward to the rigging stages. For some reason that seems to be my favorite part.
I’ll be trying to phase in more work on the Revenge as I bounce between a few paper models and scratch builds, none of which are in a huge hurry.
So look forward to more, sporadic posts!Long overdue,
Meriadoc
- GrandpaPhil, Cirdan, Baker and 2 others
- 5
The dry brushing on that bronze really looks convincing. I’ll have to do the same on my future guns.
Meriadoc
- Knocklouder, mtaylor and GrandpaPhil
- 2
- 1
On 3/24/2023 at 1:29 PM, Ferrus Manus said:
nautical paintings
Thank you kindly for your compliments! I’m not entirely happy with the results I achieved compared to period paintings, but happy enough to want to try again with other subjects. The paintings are such a wonderful thing to have access to, serving as a sort of unphotographic record of nautical scenes from centuries not blessed with cameras, thus why not try to replicate some of their magic in our models?
The “fluyt” that snuck into this build log is actually a sort of pinas, called a jacht apparently, and I have a build log for it if you are interested (though it’s been a slow go):
https://modelshipworld.com/topic/32866-duyfken-by-meriadoc-brandybuck-seahorse-1100/#comment-950561
Meriadoc- mtaylor and GrandpaPhil
- 2
Hello,
After some discussion, enthusiasm was found for building the Aquitania! ...if anyone can find a good set of lines plans for her frames. Nothing on Google or Taubman's that I can find. I thought of using the available deck plans to reverse engineer the hull shape, but that's an iffy prospect likely to cause many headaches. Anyone know anything I don't?
Appreciating the help,
Meriadoc
1 hour ago, Roger Pellett said:
Even if United States could be cleaned up, her propulsion plant would be uneconomical to operate and probability expensive to replace. This assumes that a crew could be found that would be qualified to operate it.
Still somewhat uplifting that that they haven't scrapped her. Maybe they're keeping her in mothball in case they ever do need a rapid fireproof transport.
Thanks for all the information!
I see there is a Vaterland and several other offerings in the paper market, and lots of plans.
I've known about the Airfix liners and built several of their warship kits in high school, but now everything comparable I have is in 1/700...
I'll have to do some thinking.
Cheers!
Meriadoc
Hello,
My friend wants to work on an ocean liner project together, and I'm getting a few ideas. I'd like to avoid the ubiquitous Titanic, and probably want to go with some of the larger, later ships like the Queen Mary, Normandie, or such. Or the Imperator Class (later Berengaria, Majestic, and Leviathon). Does anyone know of any such large ocean liner kits available in card or, suitable plans to build from? I will rescale whatever I build to 1/700 and possibly 3D print most of the tiny parts.
- Meriadoc
I too bought the Anatomy of the Ship series book for the Bellona and intend to build her in 1/96 (after several test runs with smaller subjects). A kit might be helpful, but hard to track down!
-Meriadoc
- GrandpaPhil, bruce d, mtaylor and 1 other
- 4
5 hours ago, Strelok said:
I hope, my Chapman Sloop will look half as good
If you take your time, at the scale you’re working at I don’t think I’d want to compare mine side by side with yours!
Meriadoc
Hello, I hope everyone had a satisfying holiday season.
At last, finally, after way more time than I ever thought it ought to take, the sloop is finished. With a two-year old to look after, I suppose I ought to be happy I’m getting anything done at all- even at a glacial pace. But the results are in and you can judge for yourself.
First, pictures from before the plunge, when the sails looked normal (very unfinished; nothing belayed, but all sails hoisted):
Note the distraction in the last picture above.
Then, it was time to try tricky magic with the sails; I wanted to simulate some of the looks you see in many nautical paintings and harbor scenes- yards hanging this way and that, sails all droopy and limp after the wind has died, crews fiddling with this or that brace or halyard. Not the trim, well-organized, and perfect image of a ship sailing in ideal conditions.
A slice of its less photogenic and more mundane moments.
Thus, one by one I worked each sail carefully with watered-down PVA, and using becalmed scene paintings as my guide, (and reworking each sail multiple times by dampening and adjusting them, plus working with the tackles to manipulate them until I was either happy or stuck) I got somewhere with it, I guess.
First, examples of my inspiration:And before getting my fingers all dirty, it was necessary to do some pre-viz to establish what exactly I wanted to go for in the context of my sloop’s particular rig:
So, having taken some time to enjoy the sails as they were, I took the plunge and went for it:
Then, some reworking, particularly to the topgallant and gaff main:
(Here I offer my apologies for the length of this post)
Having established the position of the sails, I set about belaying everything, which took forever and a lot of super glue and more cleats than I expected (better prior planning would have helped). Then it was time for a final touch:
It is handy that 1:100 is a reasonably common train diorama scale, so I was able to find some cheap figures which I modified with paper and putty to simulate 18th c. hats and boat cloaks; nothing fancy but valuable practice. I saved a few lines to be worked by the crew instead of belayed, which was more complicated and took more planning than I ever imagined it could. Also I remembered to rig anchors, which took forever too.
I’ll endeavor to make an actual gallery, but I’ll upload some images below to show the final result.
Lastly, I would like to say, this has been an arduous but immensely enjoyable process of learning how to make a reasonably accurate model of a ship from paper and cloth. I owe Ab Hoving for sharing the method of how to do it, as well as his encouragement and critiques, and several friendly members who offered thoughts, insight, or moral support. It was all very helpful. I hope you enjoy the result, and I hope the next project can take off soon.Let me know what you think!
-Meriadoc
- Strelok, Keith Black, Knocklouder and 6 others
- 7
- 2
HMS Badger by Meriadoc Brandybuck - WAK - 1:100 - CARD - serenely taking in sails
A small update.
After much fiddling, I have finished all the principal deck fitting, except for the chimney which is ready to go and some deck cleats I need to double check.
I added scale gravity to the carriage breeching ropes with pva, which worked better than expected. I refuse to do the training tackles (though the kit includes parts for them). You won’t be able to look too closely at the guns anyways with all the stunsails in the way.
Note the highly imperfect rings and badly painted pins (won’t be visible when covered in rope).
Next, I must strop all the deadeyes and get the masts finalized.
Before I get too much further, I will be conducting sail experiments. Tips about modeling loosely clewed-up sails are very welcome. I have several kinds of cloth to compare for scale performance.
-Meriadoc
