Everything posted by Gregory
A different Mini Sander for very fine detail
Gregory replied to Johnny Mike's topic in Modeling tools and Workshop Equipment
A different Mini Sander What was your source for this? -
I have some padauk veneer as well as some dimensioned pieces. I really like the reddish orange color in my efforts to avoid paint. Don't have anything to show for it yet. I am using some bloodwood for the gunports on my rattlesnake. I don't find it particularly expensive in the quantities I might need for modeling.
That looks pretty good. Are you familiar with the Chapman drawings Gretel is based on? There's a stern for you. One little tip for that Mamoli casting. It's way too thick. It can be sanded way down without breaking into the carving. My 2nd ( or maybe my 3rd ) Gretel is in the works, and your log is inspiring.
I think your best go-to would be the build by JLong. A lot of stern detail shown here: Your model looks like the original builder decided a different approach than what the plans called for. To get it right you may have to tear some of that out to do it right. Do your plans include the detail like this, from the log I pointed to above?
deck planking options
Gregory replied to manning16's topic in Building, Framing, Planking and plating a ships hull and deck
I think boxwood would give a nice contrast . The holly is too bright for my taste. Do a little testing and see what you like best. -
FWIW, here are the chain plates in the Campbell drawings. I feel Campbell can be taken on good authority. I think the kit provided parts really compromise the quality of your build. The look above could be achieved with some annealed steel wire. My best guess would be 22 gauge. This little snip from the Speedwell plans by Chuck show how simple they could be. PS Here is a drawing I found from a Museum in San Francisco
The plywood I last used was this stuff from Amazon. I don't know if it is available to you in the UK, but it is very good quality. I used it for the bulkheads on my Rattlesnake. I checked my notes and I'm actually using 75% power at 5mm/s. I do know it took a lot more to cut typical plywood from stores like Home Depot here in the US. Your eBay store really looks nice.
I can certainly appreciate the price limitations. Do you have air asist? It makes a big difference in cutting power. Multiple passes should not make the kerf larger. I can cut 5mm plywood in one pass with speed at 5mm/second and about 90% power.
I'm using an Xtool D1 Pro 20W with Lightburn software. Ventilation is a must with a laser. If I were buying today I would get one of the Xtool S1 machines. Probably a 20W. If you skim through my Resolution and Rattlesnake builds you can see how I have put it to use.
Revell ?
Very interesting machine that appears to work very well. People should click on the video. Video here..
