Everything posted by shipman
Neither the Star of India or Balclutha were never designed or used as TEA clippers.
- 481 replies
- Cutty Sark
- Revell
Ah, yes. Thank you. I've read so much over the years; at some point recollections can get a bit cloudy. Thankfully a chance detail comes up which helps put 'new planks on an old hull', so to speak. It's worth knowing that nearly all the wooden structures and masts etc were in open storage at Chatham when the fire occurred. So as the ship is now displayed, all or most of what you see was as it was before the fire. The fire consumed all the contractors equipment and the temporary 'tent', but not much of the ship itself, with much of the iron framing surviving, if a little charred and maybe distorted a little. Not withstanding any modern errors during reconstruction we are lucky to have what is at least a true monument to the ship and ships (long gone) of that era.
- 481 replies
- Cutty Sark
- Revell
Without photographs (which could be used during most of Cutty's life)......NOBODY KNOWS 🤓 Please remind me.....who is/was Sankey and where is the model?
- 481 replies
- Cutty Sark
- Revell
All pertinent questions. Ultimately, you have to decide on details gleaned from what is available. I lean towards Longridge; he was an educated man and I'm sure his reasons for how he did things are in his book somewhere. Revell: Their first US hull moldings included portholes along the full length of the ship. This was corrected before the kit was introduced in the UK. Apparently Revell went to a lot of trouble to get things right; either the sent someone over or employed someone here to do a thorough job of recording the ship when first displayed in the dry dock. After a thorough search of photos at that time, the portholes were indeed there. These had been introduced when the ship was a sail training vessel, giving light and ventilation to the students accommodation. There are too few photos of the ship when employed to train young seamen, but what there are show many details now long gone. For instance the boat booms were mounted alongside the fore deck-house; the upper deck was partitioned off by several transverse bulkheads....and so on. The removal of the row of portholes must have been done late 1950's/60's. I assume the first four photos are of the Longridge model?
- 481 replies
- Cutty Sark
- Revell
Thanks for your kind comment, Kevin. Sails: There are several ways of depicting them. Hanging them as you say would have been normal in certain conditions; there doesn't have to be all up or down. Somewhere I've seen a photo where the Cutty is moored, drying the sails. After all it wasn't seaman-like to furl damp sails, that would be begging for mildew and rot. Depicting sails drying would be correct, but not very appealing visually as they would be just flat sheets hanging from the yards. Hope you don't mind my digressions; it isn't my intention to 'take over' your posts. But I do hope to be helpful when I feel I have something constructive to contribute.
- 444 replies
- Cutty Sark
- Revell
#187 the steel standing rigging is wound with hemp and tarred to prevent corrosion, so unless you knew better, it isn't obvious.
- 444 replies
- Cutty Sark
- Revell
Hi there Johnny, glad you find the hackney book worthwhile. Early in the book he clarifies that though Airfix have always sold the kit as 1:130, it actually measures out as 1:168! Considering the book was published in the mid 1970's it's quite remarkable. 3 titles were introduced, Mayflower/Victory/Cutty Sark. The intention was to guide the young modeller at the time on how to build representative ships from each time period. The rigging aspect could be applied to most ships from each period. Of course, this forum will blanch at that, but for the young/amateur/inexperienced modeller wanting to get a foot in the door and broaden the mind, before, perhaps attempting a more ambitious project, I believe that's a laudable thing to do. You'll find all the Airfix sailing ship models are generally pretty accurate, remarkable when you remember when they were introduced. My favourite is the Bounty, which at 1:87 scale gives the opportunity to get a lot of detail in, especially the rigging. Another plus of this kit is it isn't festooned with lots of cannons to get bogged down with. The hull could be easily adapted to produce ships using many different and varied rigs of the time There are as many ways to build these kits as there are ways to skin a cat (God forbid).
- 444 replies
- Cutty Sark
- Revell
LOL it can be done! Just got confused between these two builds, pardon me. I just added a comment to Kevin's log which should have been for yours (though most of my 'interuptions' may apply to both your logs) .... It's my way of showing some appreciation for what you are collectively doing. As for scaling up from 1:168 to 1:96, unless you're going to get too technical, simply doubling the dimensions you're talking about (to the eye on a completed model) would look just fine.
- 481 replies
- Cutty Sark
- Revell
Don't want to teach what you may already know..... eg. assuming that's from Hackney: 5'' full scale rope at 1:168 would be 104 tight turns around a stick over the length of an inch. That would be fine thread indeed.
- 481 replies
- Cutty Sark
- Revell
Reminder....cordage used to be measured around the circumference. Don't compare Cutty with Victory.....that would be folly. As for scaling up from 1:168 to 1:96, unless you're going to get too technical, simply doubling the dimensions you're talking about (to the eye on a completed model) would look just fine.
- 444 replies
- Cutty Sark
- Revell
Stacked boats on the Bounty for sure. I'd be surprised if boats on the Cutty were stacked though. Interesting techniques for stacking boats. The height of the top boat (in that image) suggests it's resting on the thwarts, which was done. To keep the center of gravity low, the thwarts of the lower boat would be removed so the top one 'nested' snugly; 'nesting' I believe is the correct term.
- 481 replies
- Cutty Sark
- Revell
Your #154 looks to be the same book but an edition I'm not familiar with. https://www.ebay.co.uk/itm/353978898254?hash=item526ac9574e:g:DewAAOSw45FiQJ-needs c This book turns up regularly on ebay, often much cheaper. I got one recently for under a tenner. As with all kits, there's something needing a bit of fettling. That deck issue isn't the end of the world and not hard to put right.
- 481 replies
- Cutty Sark
- Revell
Indeed, the Beagle is a re-hash of the Revell Bounty. The 1:87 Airfix Bounty is a much better kit, the scale providing scope to get all the details correct. The AOS book shows how accurate that kit is (at least compared to the drawings in the book).
- 481 replies
- Cutty Sark
- Revell
Chain 40lpi https://www.ebay.co.uk/itm/362852779497
- 444 replies
- Cutty Sark
- Revell
Don't forget the Cutty used steel standing rigging. Running rigging, foot ropes etc were hemp. A considerable amount of chain was used on bowsprit, masts and yards.
- 444 replies
- Cutty Sark
- Revell
Refer back to your post #38....small boat on deckhouse, Sydney 1891. I have seen drawings/plans/models where there were 2 large boats, with a smaller one between on the aft deckhouse. A similar small boat on the fore deckhouse. It doesn't seem unreasonable to adopt such a scheme. Never come across mention of a 5th boat. As far as deck clutter; unless she was loading/unloading cargo, the decks would need to be free to allow working of the ship. It's worth looking up Alan Villiers photographs on wiki...obviously a later period, but not dissimilar ships.
- 481 replies
- Cutty Sark
- Revell
I recon this is as busy as a sailing ship deck would be while at sea...... https://upload.wikimedia.org/wikipedia/commons/b/b5/Parma_-_under_sail_in_heavy_weather.jpg
- 481 replies
- Cutty Sark
- Revell
This stern decoration is turning into the adventure/farce I was suspecting. I don't understand Radimir's instructions either. The transfer sheet malarky has me scratching my head big time. It could be worse; it could be me.
- 481 replies
- Cutty Sark
- Revell
I have this 'ornament', but don't recall there being 'transfer foil' enclosed. Hope you can make sense of their instructions.
- 481 replies
- Cutty Sark
- Revell
May I suggest you email hismodel? and seek their advice. Good luck.
- 481 replies
- Cutty Sark
- Revell
They obviously consumed the ships stock of rust inhibitor! Hope they paid the admission fee.
You two chaps are making a great team. Neither are as daft as I look.
- 481 replies
- Cutty Sark
- Revell
Can I be the first in the cue and be cheeky and request a set of your lozenge decals? I have no means of printing and haven't a clue how to do the origination on my laptop. Kevin, see my comment #122 here. I share your pain.
- 481 replies
- Cutty Sark
- Revell
