ECK
NRG Member-
Everything posted by ECK
- 66 replies
- Adder
- Vanguard Models
Back from vacation. Boom, gaff, lifts, jeers done so yards squared off. Next will be the back stays then attaching the bow and rigging it.
- 66 replies
- Adder
- Vanguard Models
Finally finished the shrouds and ratlines. Will be off to the beach next week. Hopefully just a couple of weeks more to complete.
- 66 replies
- Adder
- Vanguard Models
- 66 replies
- Adder
- Vanguard Models
- 66 replies
- Adder
- Vanguard Models
I brush on the poly especially over the bare wood It helps as if you accidentally get some paint on the bare area easier to scrape off if the poly is underneath. I also got this combo airbrush and venthood set. For most of the pieces the hood works well.For the white of the hull I use a lot of tape and mat combo spray can of primer and paint. I got the airbrush on amazon
- 66 replies
- Adder
- Vanguard Models
I use vallejo flat red, what Chris recommends on his ships. I soak and shape the inner forward bulkheads and let dry overnight. I then spray paint them and what ever else I can prior to installation. I find spraying leaves more of the detailed engraving visible compared to a thicker brush coating. Once in place I then paint a light layer of matt ploy.
- 66 replies
- Adder
- Vanguard Models
Have pinned the yards to the mast and done some of the jeers and tyes. Will remove bowsprit until after shrouds done as just gets in the way.I do this part now when access is much easier than after when the shrouds are in place
- 66 replies
- Adder
- Vanguard Models
- 66 replies
- Adder
- Vanguard Models
If the hole are obscured by paint you can use a hand drill or needle to open it up and then just glue in an eyebolt.
- 146 replies
- Adder
- Vanguard Models
Thanks. My 15th build so learned a few tricks especially once I joined the form and saw the great wokr/tips from others. You may noticed that I splurged and bought pear blocks for a more realistic look. Since I started building with real looking blocks, I find the final product just looks better although not obvious until you get closer to the model.
- 66 replies
- Adder
- Vanguard Models
- 66 replies
- Adder
- Vanguard Models
Far enough away. When I do real sanding I have a vacuum on pulling in the big dust or go outside. This filing does not spread far.
- 66 replies
- Adder
- Vanguard Models
Started on lower masts. First Dowel cut to length: Then taped off lower area to be carved Placed in vice and long side filed down 1 mm Next marked off upper area, rotated 90 degrees and filled upper area ( with one side flat keeps things straight in vice) Kept rotating to finish then trimmed tip for cap
- 66 replies
- Adder
- Vanguard Models
Well hull basically done. Hammock netting will go in at the very end as I always bend/break them while I am doing the rigging. I also put some tackle on the carronades and fully rigged the 24 pounders (a real pain , fortunately only 2. Use 2.5 mm double and 2 mm single blocks). Here is Adder's smasher next to the maindeck ones on Indy And 24 pounder here compared to Sherbournes's main guns
- 66 replies
- Adder
- Vanguard Models
Thanks. I use Vallejo flat red followed by a coat of satin poly. It is the color Chris uses in his models.
- 66 replies
- Adder
- Vanguard Models
Long journey, incredible job! Hope you will enjoy your next project as much as I am.
- 587 replies
- Indefatigable
- Vanguard Models
- 66 replies
- Adder
- Vanguard Models
- 66 replies
- Adder
- Vanguard Models
Work for the day done. Mainly adding belaying pins, various bolts, catheads, railing etc. Had not pun on the poly yet so some parts a bit dull
- 66 replies
- Adder
- Vanguard Models
