Everything posted by BETAQDAVE
Hello there George While there appears to be plenty of mast above the topgallant sails, this ship was a whaler, and as such had a pair of iron rings mounted on both the main and fore mast commonly referred to as the "crows nest". That is where the crew stand watch to spot their quarry. To add a royal sail above the topgallant would have made it quite difficult to work that sail as the nest would prevent the spar from turning, not to mention the fact that it would interfere with their primary task of sighting the whales. Although it may have been possible to move the nest above that extra sail, that would just have increased costs. Since the minor increase in speed that it would provide was not much of a cost saver, the owners would not think that it would have been worth it. I think that they were primarily concerned with their profit. As far as the plans go, they were really lacking in details, which is one reason for my going to such lengths to find more accurate info. Dave
Well now I’m really up to my neck in it, as I returned to the major surgery of moving the main hatch. The first order of business was to remove another section of the false deck to allow me to get a little better access to the beam aft of the main mast so the lower deck and hatch can be suspended from it. This is how it looked before starting the changes. Once that was done, I worked on cutting the lower deck and hatch free from the beams above. At first I was perplexed about how to do this since the posts were really in a tight spot. Getting any kind of saw blade in there just wasn’t possible. A Dremel router bit with a long shaft was chucked in the drill press and the table was raised to the point where the bit could just reach the top of the suspending posts. I assembled a homemade clamp with a bolt, a large pair of flat washers, and a nut. The washers were large enough to get some purchase and yet just small enough to pass through the lower hatch. Hooking the lower washer around the bottom of the lower deck, the top washer did likewise on the deck beams above and the nut was tightened to hold the deck in place. Here is my set-up for this operation. By using the router bit in the drill press it allowed me to move the hull with two hands braced by the drill press table. I chewed off the tops of the posts with light passes allowing me to keep the bit under better control while doing this freehand routing. Once the posts were almost completely routed down, I used an Exacto blade to release the lower deck to allow me to shift the deck to its new location as shown below. Luckily, the width of the hull at this point allowed me enough clearance to shift it aft without needing to further modify the lower deck. I made a template of the new main hatch and taped it in place so I could see what adjustments were necessary to the deck beams. The aft end of the hatch would butt up to the face of beam #10 at the main mast and beam #9 needed to be moved to the forward edge of the new hatch. The two longitudinal beams were shortened to accommodate the new location of beam #9. Unfortunately beam #9 had to be discarded since the only way to remove it was to rout it out. So I cut a new beam and used wood glue to attach it to the side ledgers and support the remainder of the cut-off longitudinal beams. I cut two new longitudinal beams that ran between beam #10 and the new beam #9 and glued in them in position for the new sides of the hatch. I will let the glue cure overnight before doing any more rough work on it. I taped the template in place so you can see exactly how much the new main hatch location has changed. The next phase will be to shift the lower deck and its hatch to match the upper hatch location.
After trying numerous solutions for cutting the bulwarks down with every tool at my disposal, the one that I settled on was to cut it down with a special hand saw and various sanding tools. The first step was to cut narrow strips of painters tape to make my cut line more readily visible. While this operation in itself presented me with a problem because of my weakened grip which made holding my cutting guide still while cutting the tape with a #11 Exacto blade. Slicing my hold down fingers wasn’t something that I was looking forward to, so I just clamped the guide down to the table as show below before making the cuts. As it happened the height of the bulwark that I needed just happened to align with the bottom edge of the top plank of the inscribed plank on the model. That made it a simple matter to align my tape with the intended cut line as shown below. These tools shown below were chosen for the operation. The thin flexible bladed Japanese saw was selected because of the teeth that were both fine and made to cut on the pull stroke which made it easier to follow my cut line. The saw itself cut pretty smoothly, but the hardest part of this operation by far was trying to hold the hull steady enough to follow the line. I ended up opening up my vise for a loose fit and used some rubberized shelf liner to give me a non-slip surface to lean the hull on. Not totally comfortable with my sawing skill, I made sure to stay just short of the guide line so I could sneak up on it with various sanders. My grip strength was a hindering factor once again, so I wrapped a strip of the rubberized shelf liner with a rubber band around the handle and that helped quite a bit. The Electro-File in the photo was then employed to quickly sand down the irregularities before switching over to that wider flat sanding stick. The final step was using this wide flat sanding block that could span across the whole width of the ship to make sure that the top of the bulwark was flat and even for the later addition of the main cap. Here is the result of the whole procedure. I was quite happy with the results.
Before deciding to move the hatch to the correct location I had been concentrating on reworking the bulwarks. Several things were revealed to be incorrect. As I mentioned in the previous post, the most noticeable error was the overall height of the wall itself. However, there were many other features of the bulwarks proven to be wrong. The pin rail on the actual ship was just a widening of the main cap rail rather than the continuous separate rail that was shown on both the plans and the kit, so I had to toss the ones that I had already made quite a ways back. On the actual ship there was an additional topgallant rail with a cap that will need to be added. The stanchions on the ship were wider and closer together than the plans and the kit indicated, so the ones that I had already made and installed needed to be replaced. The waterway also needed revision and some scuppers needed to be added. Other than that, the plans and kit were just fine! So, going back to the drawing board (or should I say the Paint program), I drew up scaled cross sections at the different areas of the bulwarks. The Paint program was quite difficult at first as I was not familiar with it at all, and as typically happens; there was no manual to explain how to operate it. It was vaguely similar to a computer program that I used to use at work to draw framing diagrams, so I was at least somewhat familiar with it, but then again that was about 14 years ago. Of course things have changed a bit since then and my memory isn’t what it used to be! This first drawing shown below shows the basic features to be added or modified to the majority of the bulwarks. The toughest change to make, will be removing 7/32” from the top of the bulwarks with enough precision to give me an even surface to attach the new main cap. I need to come up with an idea of exactly how I will go about that, because if I learned one thing after reducing the width of the main wale, plastic is much tougher to cut than wood!!! The second drawing shown below, illustrates the areas of the bulwarks where the belaying pins and the deadeye channels are located. This last drawing indicates the features of the bulwark at the opening by the cutting in platform. I will be experimenting for a while with some different methods of cutting plastic accurately, so unless anyone else has any suggestions on how to accomplish that operation, feel free to chime in.
Well…………….perhaps I am being foolish, but I have decided that I can’t go on with the Wanderer being done incorrectly. As that friend of mine that I began this build for has passed a while ago, it became my own project to complete. To build it as shown on the plans and model kit, knowing that those inaccuracies are there would just continue to gnaw at me no end. So now I’m looking at quite a lot of major surgery. To get a look at how to move the hatch to the correct location, the majority of the false deck needed to be removed first. Since the deck already had a break at beam #4, just ahead of the foremast, the job was already half done. I figured that the second break should be on frame #11, just aft of the main mast. Using a cut off wheel in my Dremel and a #11 Exacto blade when near the waterways, I cut the second separation line. Luckily for me, the false deck was merely pegged in place with wood trennels rather than being completely glued down. So using my smallest brad pointed drill bit (so it wouldn’t wander) once again in the Dremel, I drilled through the false deck cutting off the end of the trennels. There was a little glue that had spread around the trennels, but with a little gentle persuasion with a long thin flat metal bar, the sections were popped off. Here is a photo below of the results of this process so far. Since the inner deck was suspended with four posts hanging from the beams above (see post #24), I’ll need to saw through those posts and more than likely make new ones to hold it in the new location. Looking at it now, it appears that another small section of the false deck will need to be removed to get access to the bottom of beam #12 to rehang the assembly. As the bottom deck was glued to the plastic hull with CA glue, getting that loose may be futile, so I will probably just glue another layer of decking right on top of it. Moving the hatch aft should also be entertaining as the main mast will have to pass through both of the lower decks!
Do you add what they refer to as a micro bevel on your chisels?
Well, I did go back to the drawing board and started to recheck some critical measurements concerning the bulwarks due to discrepancies revealed by the additional photos that I came across. Using the HO (1:87 scale ruler supplied by one of our sponsors (Evan Designs) the top of the cap rail on the model measured 5’-2” tall, whereas the actual ship in the photo below indicates that the top of the main cap rail was actually waist high or about 36”! Not exactly a minor discrepancy, considering that the entire bulwark will need to be revised. There is an additional topgallant rail also shown on the photo in certain areas that appears to be 7” tall with an additional cap rail of about half the thickness of the main cap rail. So, now the total height of the bulwark in those areas should be roughly four feet or about the shoulder height of an average 5’-7” man at that time. Curious, I measured one of the figures below that was included with the kit and found that he only measured about 4’-6”. Perhaps he was the cabin boy? It appears that if I want scale figures aboard I will need to pick up some HO scale RR figures. The more I look at the photos, the more errors I find. It makes me wonder where the manufacturer came up with the details to produce the model in the first place! While the internet nowadays makes it easier for me to find photographic evidence of the correct details, they should have been able to locate the info that at that time was only a few decades old. In addition to using the HO scale ruler to measure the model and a 1/6” scale ruler to measure the A.J. Fisher plans, I used my Art Minor degree and some basic anatomy that shows that the overall height of the human body is 8 times the dimension of the head (Measured from the crown of the head down to the chin) to help with scaling items in the various photos. Taking the average mature male height of 5’-7” of that era divided by 8 gives you a head size of 8 3/8”. So that in turn allows you to determine the height of various other body parts. (Like 1’-4 ¾” to the bottom of the knee cap) One drawback of this method is that you need to make a separate measuring stick for each photo and only measure items that are the same depth in the photo. So anyway, speaking of major discrepancies, I found that the most critical detail as far as my model is concerned would be the location of the main hatch and the anchor point for the mizzen mast stay. The rear edge of the main hatch scaled 8’-0” on both the plans and the model ahead of the main mast fife rail. However, on all of the photos of the real ship, that dimension appears to be less than a foot!!!! The actual anchor point of that stay was actually an iron fitting on the back side of the main mast that also has numerous fairway leads for the running rigging down to the main fife rail. (which, by the way, does not have a fife ring on the main mast) So……..my efforts to make an accurate representation of the Wanderer would seem to be all for naught since at this point nearly everything on the deck around the hatch is wrong. To correct this error, I would need to merely remove the false deck, cut out and revise the majority of the deck framing, take out the lower two exposed decks and try to shift them to the correct positions along with the lighting. Then I would just need to completely replace the finish main deck planking including the new hatch. Right!! No problemo!!! This, despite my desire to actually make an accurate representation of the actual Wanderer, is well beyond what I am willing to do at this point. Apparently this has now become more of a generic version of a whaler. Needless to say, I have become very disappointed by this particular major development! I apparently made too many assumptions about the model being at least somewhat accurate and just needing a few minor corrections. Of course, as they say, when you assume things you only make an *** of you and me. For now, I’ll keep reviewing the photos and mark all of the needed changes on the plan.
At this point, I continued to work on the outer hull. The vertical rub rails on the Aurora kit are misrepresented as solid lumps rather than the actual rails, which are shaped metal bars with spacers to hold them away from the hull. (The photo below clearly shows this.) Also there are not nearly enough of them as each pair of davits required two or three of them and the kit had only one. Therefore those plastic lumps were also filed and sanded off and will be scratch built. Another feature that is shown different than the actual feature is the removable gangway section of the bulwark at the cut-in platform. The kit indicates a pronounced pair of wood jambs that project well beyond the surface of the hull and above the cap rail as you can see below. Once again, that’s not an accurate representation as shown in this photo below. Very early on, I had decided to display the model with the gangway left open, so I cut it loose from the bulwark at that time. Now, I also needed to remove those jambs, so a bit more surgery was required so I could once again improve the accuracy of my model. In that photo, there also appears to be an additional layer of protective planking that I will be adding below the opening where the whale carcass would rub against the hull. Assuming that the average shoe size back then was around 10 or 11 inches long, the photo also allowed me to get a good idea of the actual size of a lot of the details. On the lower left of the photo it also shows the stud-link anchor chain running past the hatch apparently to the chain locker pipes just after the main mast. (I have no exact location.) That’s opposed to the chain pipes just behind the windlass as shown on both the Aurora model and the A.J. Fisher plans. Another benefit of removing both the vertical rub rails and the gangway jambs is that it will make installing the vinyl tape planking easier with uninterrupted runs. Further review of the photographs led me to make a few changes to the interior of the bulwarks. One thing became readily apparent. The stanchions are way too far apart, and while their width seems accurate, the depth should be thicker. So once again I’ll need to go back to the drawing board and revise my original diagram for the bulwark that I drew up way back on 6/23/2018 in post #15. Meanwhile I’ll remove the too thin stanchions that I’ve already changed once before.
Ratline Making Tools
BETAQDAVE replied to acaron41120's topic in Modeling tools and Workshop Equipment
Although those Ratliners from Micro-Mark (It's basically a loom.) are available in three different scales, it's unlikely that the shrouds would align with any particular ships deadeye placement. -
I thought the same and although it was a bit pricey, I went to this site: Scaledecks.com and took care of the problem with mine. It's an actual wood product about the thickness of a heavy sheet of paper backed with a thermal fleece. Unlike some products out there that have a self-adhesive backing that makes aligning and placing the sheets very difficult, this backing provides plenty of surface for styrene cement to bind with and yet allows you to fine tune your placement. The pattern is very accurate and there is good contrast between individual planks which really makes it quite attractive.
- 399 replies
- cutty sark
- revell
The main wale is shown in the photos as being the same thickness as the cap rail with a double beaded edge. Since the cap rail is going to be 1/16” thick, that’s what I’m going with. So the first step was to set my dividers at 1/16” with one point slightly extended to ride along the top edge of the plastic wale. Starting with a light amount of pressure, I scribed the short point along the entire length of the ships wale. (Incidentally, I worked on the port side first to work out this operation just in case it didn’t work out so well, because this would become the back side of the model.) Once I had a good line to follow, I switched to pulling the backside of an exacto knife with a #11 blade with the tip broken off. Gradually after a few more passes, the scribe line became deep enough for this plastic scriber to follow the line. Now I gradually increased the pressure and continued to deepen the scribe through the full thickness of the wale. This may sound easy, but it took at least 40 passes to do this on each section of just one side of the hull!! The next step was to chew off the lower portion of the plastic wale. Now I started working on the bottom of the wale, using a similar method of scribing a line along the bottom edge of the wale with that exacto knife. (The scriber handle prevented its use here.) Removing the bulk of the waste from the wale was pretty tough. At first I tried just using my 2MM dogleg chisel, but even though plastic would seem to be soft, it carves very hard. After much tough carving, I finally managed to finish the port side, but wasn’t looking forward to doing the same on the starboard side. So, I decided to modify one of the blades for this Craftsmen vibrating saw before working on the starboard side. With a hack saw I decreased the width of an old blade to make it more maneuverable. The blade basically vibrates with a very short stroke side to side. Following the scribed groove on the bottom of the wale I leaned the flat of the blade up against the hull. This really made short work of the majority of the waste without damaging the lower hull. (Wish I thought of this before doing the port side!!) However, some areas like here where the wale meets the eagle figurehead I still needed the chisel to finish it. This left just a bit of fine work with the chisel to clean up this modified surface of the hull. With a little filler and sanding, applying the foil tape should make all this work disappear.
As I was waiting for my elevator to be serviced recently, I spent some of my free time (maybe too much) trolling the Internet looking for additional info on the Wanderer. I came across numerous photos of the actual ship that I hadn’t come across before and unfortunately, to my dismay, discovered that a lot of the info I did have was wrong. That even included some of the details that I followed on my first build of this ship from my A.J. Fisher blueprints. Although to tell the truth, those plans didn’t supply all that many details to begin with. I had to use quite a bit of guess work since that was built back in the 60’s prior to the internet and this forum. It’s also evident that most of the models of this ship that are shown on the internet do not reflect the actual features shown on the photographs. One model even shows the height of the bulwark to be closer to shoulder height rather than waist height that is shown on the photos and the figurehead as a woman in a dress rather than the eagle that was actually on the ship! The kit from Aurora that I am working with is also especially deficient as far as the accuracy of those details, but the main form of the hull seems to be close enough for me to modify to be a closer match to the actual ship. For example, the kits tryworks show brick exposed on all four sides rather than the iron sheathing on the sides and back by the carpenters bench. And one feature that was seemingly important on a whaler that is totally missing would be the trypots to boil the blubber in! So, this will be one major rework. Another detail that is quite a departure from the actual ship is fact that the anchor chain locker is located closer to amidships rather than right at the windlass as indicated on both the plans and the model kit. So I will now need to modify the deck to relocate those pipes. The main whale on the model is grossly oversized and will also require some major revision by reducing its size and changing its profile to show the double beaded edge that was on the actual ship. Luckily I didn’t paint the hull or mount it on the ways yet as this will take quite a bit of manhandling to remedy. Obviously the planking appearance will change, but then it will be covered with the vinyl foil tape anyway. Some areas at the bow and stern require an additional topgallant rail and cap not shown on the plans, so the planking will need to be consistent. To maintain some semblance of historical accuracy that is important to me, there will be many other details too numerous to mention here for me to modify. It looks like the project completion date will be getting extended, but I would not be satisfied with the model if I didn’t do them. Installing the finish deck will be on hold for a while until I figure out some of the other modifications that will need to be done first. The first revision will be correcting the main wale, and I expect that to be quite a chore.
How about this paperback book that was put out when the Constitution was celebrating her 200th anniversary from her launching in 1797. This book covers her from her design to her present state of preservation, including all the major and minor reconstructions. It includes detail drawings like this throughout. There are also several color prints of her in action including her living room sized main fighting top. At a cost of only $22 I found the 239 page book to be a very informative guide when I built the Revell version that's currently still in drydock after a fall that pretty much dismasted her when impacting the floor of my garage. I've never repaired her, but didn't have the heart to throw it out as I still may fix her up. Maybe someday.......
Looks like a good poster for Ducks Unlimited. (A local local wildlife preservation organization.)
What‘s that saying about the best laid plans of mice and men? Oh yeah. I decided that the next step now had to be changed from painting the copper hull to installing the wooden deck. Due to the manhandling of the hull that would be necessary while installing the decks, all of my masking now had to be removed. Oh well, better than risking damage to the paint job. The false deck needed to be installed first, but clamping the false deck down presented quite a problem since it curved front to back and side to side at the same time and the bulwarks were in the way. Because the glue needed to be spread out on all of the deck beams, by the time the glue was spread, there wouldn’t be enough time to set all the clamps before the glue set up. So, rather than trying to glue the deck directly to the beams, I ended up pinning it down. (That’s where the ends of those tooth picks used for the pegs in the last posting got to be used up.) Taking the starboard side of the false deck in hand, I lined it up with the centerline of the ship and clamped it in place. I put tic marks along the centerline to mark where the edges of the beams were located. While the starboard side was still in place, the port side was fit in place and the tic marks were transferred to that side also. I also cut small holes in the decks where the wires for the cabin lights would be located. At this time I needed to figure out how I was going to fit the finish deck in place with the hawse pipe fittings attached to the bottom side of the deck, since once the deck was attached I would no longer have access to the inside of the hull. My solution called for separating the bow ends of the false deck from the remaining deck to make things easier to handle. Once the bow ends were separated, a section of the false deck surrounding the pipes was cut free and the remaining bows false deck was cut just a bit bigger so that when the finish deck was attached it would allow some extra clearance. I fit the pipe through both the hole in the false deck bow section and the bottom of the finish deck, and glued it in place with medium CA leaving the pipe flush with the top surface of the finish deck as shown below. The false decks were removed and the tic marks were extended across the top surfaces using my thin beam metal square that I picked up from Micro-Mark. (Yes, I know their stuff is pricey, but they do carry some products that you can’t readily find anywhere else.) Starting with the port side deck, it was realigned and clamped in place. The outer edge of the deck was fitted with pairs of 1/32” thick wedges set under the plastic waterway to force it down to the perimeter ledger and the tops of the beck beams. (That’s 1/32” for the finish deck and 1/32” for the additional wood waterway with scuppers shown way back on post # 15.) In addition to the wedges, I used some small C-clamps wherever they could be set and used heavy weights to hold down the center of the deck. (These small C-clamps were rather cheaply made and turned very hard. Using this Slipstick dry lubricant on the threads helped quite a bit.) Using a 3/32”” drill bit in my battery powered General screwdriver/drill, holes were drilled through the false deck into the beams below as shown on the layout that I had just drawn on the topside of the false deck. Drilling one hole at a time, working around my clamps and weights in two rows, I used the cut off ends of those toothpicks, dipped the end in carpenters’ wood glue, and pressed them into the holes (with those D batteries again) to pin down the deck. (A-la trennels.) This section of the false deck was then set aside to cure overnight. Removing the clamps and wedges, the ends of the pins were snipped off and sanded flush. So now the starboard side of the false deck was clamped and installed similarly. So here it is with both port and starboard false decks finished. The two bow sections of the false deck were now done similarly. The false deck is now complete.
Surprisingly enough, the elevator tech showed up on the 9th as promised. After about an hour of testing and adjusting the limit switches, it was ready to go again!!! So now I was finally able to get a few things taken care of. The launching way ramp was glued into place on the display base with the anchoring bolts tightened down to help clamp it in place. Now the braces for the ways were begun by gluing the 3/32” x 1/4” basswood vertical braces up against the timber walls with carpenters glue. (The concept was shown on a June 7, 2019 posting.) Each one needed to be a different length, so it was all “cut to fit”, no mass production here. I just held each brace momentarily in place for the glue to get tacky before setting the following one. To keep the spacing more consistent, I cut this spacing block to go between. Once all 32 vertical braces were installed, I gave them a good coating of Minwax light oak finish with a small brush. Now it was time to make the diagonal braces that were made with short pieces of 3/16” birch dowel. Unfortunately, each one of them was also a different length so more “cut to fit” was involved. These were set at an angle of roughly 45 degrees. The bottom ends were set with carpenters glue into shallow depressions drilled in the base and the top ends were also glued and partially beveled to sit flat against the vertical braces. On the top of each brace, a small depression was made with a very sharp F drafting pencil lead to represent a metal spike to secure them. (Similar to my method of showing trennels made in the decking on my June 28, 2018 log entry.) Once all these diagonal braces were installed they were also stained in place. Here are the ways shown below at this point. The bottom ends of all the diagonal braces were held in place with wooden pegs driven into the ground at an angle of roughly 45 degrees. To make the pegs I clipped the pointed ends off of some round wood tooth picks and used the remaining center portion. (The pointed ends will be used later as trennels to hold down the false deck.) One end was sanded smooth for the exposed end of the peg. Using a steel center punch, I located the hole for the peg right up against the bottom of the diagonal braces and gave it a sharp rap with my hand as shown here. Once all of the impressions for locating the pegs were made I came back with a drill bit matching the diameter of the tooth picks and drilled about a ½ “ deep hole at a 45 degree angle. I laid out the pegs at the holes with the sanded ends set near the holes to speed things up a bit and keep me from putting the wrong end in the hole. Now, production style, I installed the pegs one by one. I bottomed out the sanded end of the peg in the hole, clipped it to length, removed the peg, dipped the clipped end in carpenters glue, and pushed that end of the peg back into the hole using a D sized battery. (Using the flat end of the battery gave me more control and caused less damage to the sanded ends of the pegs than using a hammer.) I repeated this operation for all 32 pegs. Once the pegs were installed they were all stained in place. So, the launching ways as shown below are complete except for the main hull braces which won’t be installed until the hull is in mounted on the stand. There are some more details to add yet, but they can wait until later.
I think the center of the line would be the way to go. I use a pair of drafting dividers with a center wheel so it won't loose the setting.
Along this line of thought, I came across my pencil sketch of the Monitor and Merrimac battle in Hampton Rhodes in the civil war. It was taken from a term paper that I wrote back in High School. (Just a few years ago)
After I left seven messages for the elevator service manager to get some service and finally an impatient call by the admiral to the head office on the 26th, I finally recieved a reply that same day. The manager said they needed to have a company meeting the next day to rearrange their scheduals due to the elevator service tech just returning from quarantine. On the 28th I called again, but they had no decision yet. This morning I was finally informed that they would come on the 9th. Like I said previously, I won't be holding my breath.
Sometimes it seems that there are times when everything that can go wrong does just that. With Covid-19 we started this year off with a bang, and that just keeps on going way beyond the miracle endings proclaimed by the one least qualified to know. Things just seemed to accelerate from there. They really started to go more awry last month when our clothes dryer was out of commission for a week or so. Then I went in for a little MOHS surgery with a little extra trauma for my toe just thrown in for giggles. I no sooner pretty much recovered from that, when I had to go in for Colonoscopy surgery yesterday. Now today I found out that the elevator to our basement has also just decided to go on the fritz! Luckily the admiral was here when I got in the elevator. Because, the door to the cab wouldn’t open to let me back get out. She had to use the emergency exterior key to the door to let me out. Luckily it was at the top when it happened, so we didn’t have to find some other way for me and the wheelchair to get back upstairs! I just got off the phone with the new service manager (the third one since we had it installed in Dec. 2018) to try and schedule a service call. They can’t have anyone here till later next week and that comes to the tune of $375 🤑 for the call plus labor and any parts needed. Hopefully it can be fixed quickly, easily. (And cheaply?) Someday, I may be able to get back down to the basement model shop. However, at this point I’m not going to hold my breath after the way over extended time for the original installation of the elevator. Only time will tell I guess.
Despite my best efforts to blend that plug into the base, the wood grain didn’t match very well and as a result it was still somewhat noticeable. So I simply redrilled the holes for the mounting bolts to allow the unplugged side of the base to now become the front. Once the base was redrilled, I pieced together three sheets of 150 grit sandpaper to represent the surface of the ground around the launching ways. The joints in the sheets were placed to align with the extended timbers that will brace the hull. Once the edges of the paper were trimmed off, I held them down on the base and traced the outline on the baseboard. Since the board was already prefinished, that finish was sanded off the surface up to the traced outline of the paper to allow the carpenters wood glue to bond. A 50/50 water to glue mix was spread out with the edge of an old credit card up to the traced outline. One unforeseen complication that developed was the fact that the paper soaked up the glue much faster than anticipated and the edges of the paper quickly curled up. So it was a bit of a scramble to flatten and hold it down to dry. The launching ways, various boards, clamps and weights were assembled and applied as shown here. The base was left to dry overnight and the next day the surface was given a light coating of Minwax honey oak just dabbed on here and there with a paper towel and given a quick brushing to even out the coloration with a wide stiff bristle brush. Then all of the excess was soaked up with paper towels and set aside for a couple days to dry again. Now it was time to work on the trim molding. Using my Makita chop saw shown here, the back side and the two end pieces were cut to length. The saw doesn’t slide, do compound cuts or have a laser guide, but then I bought it way back in the 90’s so I just had to “rough it”. (One trick that my grandfather taught me when cutting miters, was to stain the cut ends before assembly, making the joint less visible even if your cut wasn’t as precise as you wanted it to be.) Once these three trim pieces were cut, they were nailed in place with my pneumatic Makita brad nailer show here that even predates my chop saw. However, it still works much beter for me with my diminishing manual skills at trying to use trim nails and a hammer. Now that the easy parts of the trim were done it was time to work on the more involved job of making the front piece. The trim at the front needed to have a central portion removable to mount the switch and to allow replacing the battery when needed without turning the whole case upside down. In order to make it appear to be more like one continuous piece of molding, it was composed of three separate pieces cut from the same length of trim so the grain pattern would appear to continue somewhat uninterrupted as show here. Unfortunately, my chop saw uses a 1/8” thick blade, so the overall piece needed to be about 3/8” overlong with a miter cut on each end. The location of the removable central piece was determined, allowing the joints to overlap the blocks. Then with two 90 degree cuts it was separated from the end portions. Those two mitered end pieces were now nailed to the base. Next, to make the central portion fill the gap, I crept up on its length with my disc sander until it was a fairly tight fit. Here is a view of the unassembled front trim before the final fitting. Now that all of the trim was cut and fit to my satisfaction it was time to work on the mounting of the light switch and battery fittings. The first step was to make a mounting block for the switch; I sketched up this diagram of how the switch would function. Since the switch function was actually a push button, I needed an extension plunger to go through the face of the molding. Being a notorious scavenger with limited metal working tools or skill, I went through my misc. metal bins and came up with some 16d solid copper nails. I shortened one nail to about two inches long with a hacksaw and chucked the shaft of the nail in my “metal lathe.” (alias drill press) With the drill press on, the nail was machined into shape with a coarse metal file. Being just a common nail, the head was not really centered on the shaft with anything approaching accuracy so it was ground down until it was even and the diameter was just slightly smaller than the step on the face of the switch. The shaft was also filed down until it was looking more like a polished custom fitting. Here you can see both the full size copper nail and the finished copper extension plunger in the background of this photo. Using a small scrap of the molding for the block, I glued and clamped it to the back side of the trim located to fit in the open space between two of the base board spacing blocks. Once the glue set, I selected a spurred wood bit sized to match the step on the switch and drilled into the back of the block until it was just short of the molding. Then, switching to a drill bit matching the shaft of the plunger, I drilled all the way through the block and trim. Here is the trim at this point. Using wood chisels and files, a groove was routed out the width of the main body of the switch. It was only about 1/16” deep, just enough to hold the switch in place. The switch itself operates with a spring mounted plunger, that when in the off position is fully extended. Once the plunger is depressed it clicks and stays depressed just proud of the step on the face of the switch housing and is in the on position. (You can see in this photo of the switch that shows both the plunger and that step on the face of the switch.) After much checking and fine tuning, the depth of the bore for the head of the plunger was adjusted. While holding the switch and plunger in place, the actual operation of the switch was checked while hooked up to the battery and lights. The copper plungers’ projection beyond the face of the molding while the switch was in the on position (fully depressed) was noted and marked on the end of the plunger. Adding about 1/16” to this mark, the plunger was removed and cut off at this length. The cut was filed smooth to a polished finish and sprayed with Tamiya TS-80 clear matt acrylic varnish. Here is the molding in place showing the copper plunger installed. At this point the switch still needed to be fixed in place so that when the plunger is depressed it doesn’t push the switch housing out of place. I ripped down two narrow strips of oak to flush out with the backside of the switch housing and glued them in place on both sides of the switch with wood glue. In the unlikely event that the switch needs to be replaced at some point, I glued and clamped another small block of wood alongside the switch block. A thin piece of plastic was cut and screwed to that extra block with a single screw to allow it to swing over the back of the switch and hold it down and yet still be able to swing away allowing the switch to be removed. So here is the completed switch housing below. As far as the battery housing is concerned, it will just be taped to the backside of the removable trim piece to hold it in place and yet be easily released for changing the battery. I had to splice some additional lengths of wiring to reach the new location of the switch. The splices were done with the help of this recently purchased new tool that could strip the insulation off of the very thin wire that came with the lighting system without damaging the copper. The ends of both wires were bent back and hooked together with the wires tightly twisted to form a very secure mechanical splice. Additionally, the wire splice was soldered and covered with shrink tubing heated with an old blow dryer. All of the remaining loose wire will just be taped to the bottom of the base board with sufficient slack to allow removing the switch trim piece to get at the battery. An additional length of shrink tubing will be applied to the wires as they are run through the base board, launching ways and the keel of the ship for a little bit more protection. I think that a couple pieces of double faced tape will be sufficient to hold the switch trim piece in place on the base. If not, I could always recess pairs of thin magnets to do the job.
Actually, my intent is to show the ship in dry dock for refitting rather than as a museum ship. The copper bottom would now be exposed for some time to the air after having returned from a long whaling voyage, thus the green and white mix to the color. As far as the vertical streak pattern goes, I am looking at these two photos below of the Cutty Sark that does show them.
