Thunder
Posts posted by Thunder
  1. On 2/9/2021 at 3:07 AM, popeye the sailor said:
    I like the sails........reminds me of something I tried a while ago.
    https://wenzelswharftips.wordpress.com/wp-admin/post.php?post=35&action=edit
    it really is a toss up.......use the vac sails or go rouge and make cloth sails.  I find the use of cloth sails to be somewhat different between plastic and wooden kits.  most wooden kit are at a scale where cloth doesn't appear out of scale as much.  unless the plastic model is a larger scale,  the scale thickness issue with the smaller kits,  is more visible.   then again,  I've never concerned myself with either ;)
    I've got the Revell Gorch Foch,  which is a skill level 5.  I've also got the Monogram Bon Homme Richard and the Linberg Captain Henry Morgan...both are a skill level 3.   in the hands of a beginner,  I'm sure any one of these would be a very nice model.........but if one has the experience and knowledge,  then the detail they possess can be brought out.  it like what my bass teacher told me.......anyone can make music  ;)
    I have done sails with paper before, soaked it to make sewing the bolt rope etc in place. Soaked again whilst rigging, especially the furled sails. Then dried with an air dryer which gives a billowing effect.
  2. Hi Tim,
    Not looked in on this website for a long time. It was one of your updated that prompted me.
    Your Speedy is looking really great, you should be proud of what you have done.
    You are right to sort your own rigging, i found some errors with what Bill Shoulders did, mainly with the bowsprit. He was suggesting what would be more for a sloop which would be a shame as it is the rig of the bowsprit that stands out for a cutter.
    I will try to keep an eye on your work from here to completion.
    Adrian
  3. On 2/26/2024 at 10:36 AM, NoelSmith said:
    The National Maritime Museum in London sells copies of George Campbell's plans of the Cutty Sark.
    Have a look on their Cutty Sark Collection. Probably the very best set of plans available of the ship and also the most reasonably priced too when compared to commercial model makers plans from other sources.
    Also, the long out of print book by Noel C L Hackney published by Patrick Stephens in the UK was an Airfix Special book. Although aimed at building the smaller Airfix kit, the book contains a wealth of information about rigging the ship and lots of details with regard to painting  the model.
    Mr. Hackney wrote two other Airfix specials for The Mayflower and HMS Victory by the same publisher.
    I second these books, they are excellent. I built the Cutty Sark using one over 25 years ago. I intend to use it soon to build the Imai Cutty Sark.
  4. 9 hours ago, oakheart said:
    Wow Thanks for all the research, the first one looks like it could be  an angled leading edge.
    The drawing / painting looks more like a bevel than rounded.
    I does look like a flat plank.
    As this is no longer a model of any real cutter, I may use artistic licence here.
    Personally I quite like the angled look, so I may just go with that.
    Tim
    Hi Tim,
    Mine had the leading edge angled for a third then the centre portion rounded if that makes sense. Rudder slightly tapers aft but only the lower, wider section. The top section is the same thickness through out. As shown, the rudder does not reach all the way down to the bottom of the keel, believe to try to prevent being unhinged if the ship touched the ground.
    sorry for slow reply.
    Adrian
  5. I think that will look better than the regular spaced shrouds and have seen exactly like that in some sources.
    I would always try to get the straps down to the wale if possible.
    I would still say that this is a good representation of speedy. Items of rig would change through a ships life as captains changed things to try and get a better trim and improve sailing quality.
