Thunder
Posts posted by Thunder
Hi Dunnock, I will be watching with interest as just started her myself. Interestingly I had no issues with, and no cleaning up to do of the bulkhead slots, as all fitted together perfectly. My kit has been stored under the spare bed for 10 years which may be why, or has their quality dropped? I am having the same decisions as you regarding bow and stern post and am undecided what wood to use as second planking. I have purchased some box to make my own planks and some pear in case I do not make a good job of the box planks with my small Proxxon circular saw. The only other addition made to the keel is an extra false keel that makes it the correct depth and additionally hides the plywood. I have done this as not decided whether to apply the copper plates yet.
Wish you all the best with your build, It does look like you won't need it, doing a great job so far.
Don't believe from the above comments that if a kit is double planked it will be good quality. Many are not. Some stretch the limits on gaps between the bulkheads to a level that make it very difficult to plank well without huge hollows in between. If possible i would check this prior to making a purchase.
Considering the shape of Bounty's bow that planking is excellent. I hope I do that well when I get to build her.
The most important thing is that you enjoy what you are doing, that is after all what having a hobby is all about. I like to think I am producing something of accuracy but that does not mean that is right for everyone. You build your model the way you want it and enjoy what you have produced.
Just my opinion but I think what could be a great model can be made to look like a toy if the rigging is poor. It does not take a lot of effort to make it look better, even just the use of different size threads makes a difference.
I have said many times but the best guide for an Airfix / Plastic kit is the books by Noel C Hackney. For your period of rig you would be best with the Mayflower book. Especially as you have this kit on your shelf. Takes you through the build and any modifications that you can possibly do to improve. It then takes you through the rigging step by step. I used it as a basis for my Airfix Golden Hind.
Hi, just seen your build for the first time. Do not know much about this kit but looks like you have used walnut for the deck planking and the first planking, is this correct? Usually this would be for the second planking only, don't want you to end up short for that.
I would take a look at the 'Modellers Shipyard' kit range. Their Mary Burne ketch or mermaid cutter would be good options and less war like. Never seen one of these kits to say how good they are but subjects look good. I think there is a Mermaid build on here.
- Edwardkenway, mtaylor and lmagna
- 3
4 hours ago, vaddoc said:
Also check Arkowood. They seem to select the timber they send out quite well.
I love beech. It is hard and tough, holds an edge, glues well, sands well, bends fantastically well. Good for frames, planks, keel. Does not split like walnut. I am going to plank two boats at 1:10 scale with it. I like it looks and colour although the pattern is quite prominent.
A couple of things though. The wood pattern depends how it is cut, can be elegant little dots (usually) or wide spots (not very nice). Also, wood seems to vary from tree to tree (I know, big surprise here...) I received some beech recently that seems much harder than wood I bought in the past.
If you like the looks go for it.
I did see the Arkowood, there is also Ahorn (maple), Birke (Birch), and Weisbuche (hornbeam or white beech?) which all look to be good woods.
Thank you for your comments. Tempted to try.
- Edwardkenway and mtaylor
- 2
7 hours ago, captain_hook said:
I have ordered several times there before (pear stripes and some basswood), but haven't seen Castello on their website. The stripes were precisely cut. You're sure they also sell boxwood?
Hi they have labelled it as Buxbaum Castello wood from Brazil which I believe translates as boxwood.
Thank you for your comments a great help.
Thank you for the replies, I was looking for something to replace the walnut in my next kit and found the above site after someone placed it on here. The boxwood seems a very good price compared to another provider in the UK which does not sell the sizes the same as the kit. I could actually buy the boxwood and the beech for the same price as the boxwood alone in the UK. Before I purchased i wanted an idea of quality. I have seen a few on site that have purchased box only to find it was what looked like dyed lime.
Perhaps i could email for a small sample of each. They do sell pear as well but this is more expensive.
Hi, photographs below are from my unbuilt kit.
I have pieced the parts together as best as possible to give you the hull dimensions. looks to be about 505mm from figurehead to taffrail. Measuring from the Anatomy of the ship book Bounty I get same dimension to be 336mm@1/96 scale. Which i think comes out at 504mm @ 1/64 scale.
- mtaylor, peterbrowne and Gregory
- 3
Hi,
Two questions, has anyone used the attached site in Germany?
Willkommen bei der MassivHolzWerkstatt. - modellbau-holzs Webseite! (massiv-holz-werkstatt.de)
Is the Buxbaum Castello wood from Brazil good enough quality for second planking?
Oh, a third question. Beech is often described as the scale oak, has anyone planked with this and what are its characteristics? Does it cut and bend easily, is it easy to work with?
O.k. 5 questions but whose counting!
Adrian
Or if in the UK go and take a look at the place below:
https://www.bucklershard.co.uk/
Well worth a visit
Hi,
Not quite the same but many done by Langton Miniatures. I believe at one time you could make a full Trafalgar set for war gaming.
http://www.rodlangton.com/index-2.html
- Old Collingwood, Edwardkenway, mtaylor and 1 other
- 3
- 1
Final photographs. Just a few minor tidy ups to do so as far as here is concerned this build is complete. Base board for stand made out of an offcut from when i did my skirting boards. Brass plaque was from Engraving World
https://engravingworld.co.uk/brass.html?p=2
- GrandpaPhil, robdurant, Wahka_est and 15 others
- 18
Hi,
The caldercraft instructions are to use natural thread but then to colour them black with black indian ink. The reason being is that it is far less stressful on the eyes to rig the natural thread. Just be very careful when using the ink. You get little black dots everywhere if not careful.
It is very hard to get them level and you have looked to do extremely well. Are you using a jig? Just a simple piece of spare 2mm ply with four pins for the upper holes of the lower dead eye and two lower holes of the upper deadeye. You then get the distance and tension when doing the shroud rather than when rigging between the deadeyes.
Still not easy so, looking at yours, if not using the jig, perhaps you don't need it.
Hi, yes i put eyebolts around the base of both masts and kevels on the masts as well. I found that i ended up doubling up on he foremast. The bitts by rights should also have sheave holes through them and the bits in front of the fore mast belaying points. I also ended up doubling up rigging belays on the knight head timbers for the bowsprit rigging belays. I did end up with a lot of spare belaying pins on the racks between the gunports at the main mast.
On 10/5/2020 at 1:18 AM, acaron41120 said:
I think they have made part one a bulkhead as it actually forms the beak head bulkhead at the front of the forecastle.
Do you have to cut the bulkheads out? I have this kit on the shelf and they all just press out. Also instructions seem concise, have you got them?
If having to cut them out it may be worth investing in a scroll saw such as the Proxxon one, will be easier than a jigsaw.
You have asked a question else where about filing down the deck beams to make the deck flush. I would not advise unless sure kit is incorrect. Most ships decks are higher at fore and stern and have a camber so higher along the centreline. Helps with water run off from the centre of the ship.
I'm going to complete my rigging research for the Sovereign of the seas whilst also starting a wooden kit. Although just purchased the NMM plans of the Serapis I think it will be either the Diana, Granado or Fair American.
Buxbaum - Castello (Brazilian origin) - http://www.massiv-holz-werkstatt.de/
in Wood discussion...Where to use it? Where to get it? What types are best? How to Finish it?
I have it all over my front garden but after 20 years it is still not substantial enough to get any planks from it. Don't think it will be usable in my life time.
I have purchased two sheets of 3mm and 5mm thick . Was wondering what was the best tool to use to one planks off at about 1mm thick. Have run a couple off on my small proxxon circular saw but too many teeth marks where i hesitate. Was thinking of setting into a longer bed to make it better for supporting what is a metre length plank.
