Posts posted by moreplovac
- nehemiah, BenD and GrandpaPhil
- 3
- GrandpaPhil, Gregory and nehemiah
- 3
Continue with rigging...
A little helper to assist with keeping the same distance for both blocks..
and the other side...
Some random shots of blocks and rigging details.. if someone is interested in following one rigging line specifically, let me know and i will provide few pictures...
From sailor' perspective...
From bird' perspective... hopefully bird is not fully fed.
While i was rigging this block, i rigged the wrong block, the one further on the left. All line was completed, ended in the third pin but had to do one more time, again. Practice makes it perfect..
Happy modelling..- nehemiah, gieb8688 and GrandpaPhil
- 3
- GrandpaPhil, nehemiah and ccoyle
- 3
- ccoyle, gieb8688, GrandpaPhil and 2 others
- 5
- ccoyle, nehemiah, GrandpaPhil and 1 other
- 4
Making few 0.3mm ropes, using crochet lines and Golden oak stain. I usually cut the lines in 1mm length, deep one line at a time in the stain and pull it out, at the time i drop the whole line in the stain. This prevents a line to stay in the stain for too long. This allows me to somehow control the beige colour shade of the lines.. then let it dry for a day...
It is time to bring the model back on the table...
... and to replace the plan
All sails appears to be done..
Work will start on a jib by making a holes for rings.. and making 7 rings in 3mm diameter. The rings are blackened and polished before mounted on the sail..
Then the sail is attached ...
Then a tack cringle is attached to the parrel using a simple square knot. Next, the halyard is attached to the head of the sail..
... and it will be tight to the cleat using a 3.5 mm block with an iron hook..
Happy modelling...- GrandpaPhil, nehemiah and gieb8688
- 3
- nehemiah, GrandpaPhil, Tim Curtis and 2 others
- 5
Marking the position of reef lines...
Production line, knot making process...
Freezing the top of a line with a drop of CA glue...
After making holes in the sail, the reef lines are pushed thru...
50/50 diluted white glue assist keeping the knot positioned...
The ship cradle, once turned up side down, serves as a good, small table for tasks that require precision and patience.. this is part of making a knot on the other side of the line..
After reef lines haircut is done... few lines still need a bit of adjustment...
and completed...
Happy modelling..- nehemiah, gieb8688, GrandpaPhil and 1 other
- 4
Working on blocks, different sizes, for different yards... a bit of serial production.
I used a bit of CA glue to freeze the block and now rope is slightly stiff; need to massage it so it will fit around the yard..
A foot rope is also installed; slightly different approach this time. First i made an eye...
then drag the main rope line thru with a help from this fancy tool...
The the lines were tight to the yard in appropriate length..
I will adjust foot rope to look a bit more realistic...
Happy modelling...- nehemiah and GrandpaPhil
- 2
- 2
A bit of a white glue, diluted 50/50 to freeze the reef band...
A bunch of reef lines were pre-cut, a knot was tight on one end and opposite end frozen with a drop of CA glue so it can easily go thru the hole..
Once all lines with a knot were pushed thru the sail and secured with a drop of white glue, the work on opposite side started by making another knot... Then all lines were cut to the length..
Just to break a bit from reef lines, started to work on attaching a sail to the yard....
... first attaching the corners of a sail with a strangle knot...
The holes for robands were also predrilled..
Then it becomes very hot in my little workshop so continue tomorrow...
Happy modelling...- GrandpaPhil and Eurus
- 2
Reef points installation process..
Mark it on the sail..
The knot was made on one end of the rope..
With needle it will be pushed through the sail.. if the hole is big enough, the reef line can be frozen with CA glue on one end and that end can be pushed thru the hole... this way no need for needle..
On the other side of the sail, the another knot was made..
The string is pooled and the knot was finished on the sail..
The knots were frozen with a drop of diluted PVA glue on each knot.. and dried with the hot gun (on lowest heat setting)...
Haircut time..
One row is completed..
Happy modelling...- GrandpaPhil and BLACK VIKING
- 2
Still need to practice this technique, mostly on some bigger scale model... It turns out that with this way the amount of sail cloth provided in kit might not be sufficient. Also needs to practice on type/amount of glue used to glue strips together to simulate joining of two cloths..
Anyhow, the new material was located and in this case i will try simulating with a pencil line... I will also practicing with another sail cloth material and using "pulling the threads" technique for simulation overlapping seams..
Tracing the sails down...
Simulating overlapping seams..
Cutting strips that will be glued to the sail..
In order to protect the cloth from starting to tear apart, the cloth for strips was covered with diluted white glue, 50/50 with water, left overnight to dry and ironed before used. Then it was placed down, with material threads as vertical as possible. Then i put several strips of transparent scotch tape to prevent tear, very much the same reason of putting the scotch tap on veneer before cutting it...The strips are cut 3mm and 4mm wide.
I started with the longest run first... following the sail template..
I used white glue, not diluted to glue strips to the fabric. The scotch tape is pulled off easily once the glue settles down.
The sail is cut off..
The simulation lines have to be put on the back as well.. Two lines of scotch tape with measurements are put on the desk and the lines are run on the material..
All sails completed.
Now it is time to run a boltrope, 4mm thick, using combination of cyano glue for a quick grab/hold and 50/50 diluted white glue running with the line, to make sure rope stays on..
Will continue tomorrow.
Happy modelling... -
Certainly, will provide a feedback...
With this technique the amount of provided fabric is not enough since the length of it is shortened for at least 1mm after each strip cut.
Need to find another piece of suitable fabric and try again..
There are different ways of making sails; this time i will follow sails making technique suggested by one Russian modeller. Never tried before so might as well try it now..
First, material is cut in a strip 10mm wide, which is then glued to the material overlapping by 1mm.
Measuring 10mm..
.. cutting the stripe...
... making 1mm overlap...
... run a layer of carpenter' glue, diluted 50/50 with water...
... put the cut stripe on the top of the overlapping area, in that 1mm grove, carefully remove all rules and press lightly to remove excess glue. Use a piece of bounty paper to grab the glue. After gluing few stripes, run heated iron (on silk setting) over the strips to speed up glue drying..
In the process...
So far...
Will continue tomorrow.. Happy modelling.. -
Work on sails started by scanning and printing the copy of sail plan from the kit.
Then i cut them all..
Test on the sail cloth that was included in the kit.. appears to have enough space for all..
Now put them aside til i am working on staining the cloth..
The model is also resting a bit ...
First i ironed the cloth...
Than stained in golden oak stain, must say i do like this stain colour,... a bit messy job...
Taking excess stain from the cloth, with a help of few sheets of bounty paper..
Cloth is drying ...
Happy modelling.. -
The rat lines have been completed. Interesting work, must say... It does really test your patience...
In the process at topgallant...
All completed...
During the work process, outer jib boom guy (hopefully have the term correctly) was slightly damaged, enough to bother me so i replace it with a new rope.. Here is process..
And completed..
Now it is time to do some touchups on the model and to start working on sails.... woohoo.
Happy modelling.- Tim Curtis and BenD
- 2
6 hours ago, Tim Curtis said:
Really like what you are doing with this kit Moreplovac...
Keep up the good work!
I am currently building the same kit - but adapting it quite alot.
Its helpful to have this build log as a reference.
Tim
Hi Tim, happy to share tips if you need it during building phase..
Cheers
Phoenix by Moreplovac - FINISHED - Master Korabel - 1/72 - Russian Brigantine
During the work, one line was damaged and needed replacement..
It was replaced and all is good again...
I also removed the ship boat as i will be adding few more details to it...
Which in turn, leaves a bit more space for work..
Another parral to build...
And continue with the sail... keeping it up with a small cloth pin...
Then i had to rearrange and reposition some ropes correctly.. a bit of diluted white glue to keep the ends straight and some weight till glue dries...
Happy modelling..
