Posts posted by Ferrus Manus
To fill cracks, try using plastic model putty. This can be found at most hobby stores.
- Canute and Old Collingwood
- 2
Oh, what a nice paint job! At this scale, it's a wonder anyone can get anything painted right. You are doing a marvelous job on this kit.
@Ian_Grant I did some Lego models on a cad software a couple years ago, and i thought they were pretty cool. Would you like to see mine? @Vincwat, your Surprise is coming along nicely!
And look even closer! That carrack on the left is basically an enlarged Mataro carrack. I might use this image as a reference for the Senora Fielden. This image just keeps on giving!
Would you look at that, Steven! Look at the upper works of the aforementioned caravel as well as some of the vessels in the foreground. The upper works of the caravel i just got done referencing have red, blue, and yellow paint, and the entirety of some of the foreground boats are painted as well, some even having designs. So, my paint job is historically accurate, or at least plausible.
There is little evidence of what flags were flown on Portuguese ships. This image shows the Portuguese caravels and carracks in port. The ships are likely from the mid-late 1400's, looking at the forecastles of the carracks. Look at the caravel on the center-right.
This caravel is flying a Portuguese flag on the main truck, and multiple streamers on the lateen yard peaks.
For this reason, I will decide to fly a Portuguese flag on the main truck and a streamer on the main yard.
That's an interesting rigging setup on the guns! I think the looped thread looks just fine. Like i said before, the company that made this model has no excuse not to give you at least some instruction on the rigging. My recommendation is to look up rigging plans of similarly rigged ships, or see other MSW modelers rig their kits.
I would like @Louie da fly to come and check if, other than the flags, anything else is needed that i missed in my research. I don't want to end up leaving anything out that should be there. Granted, i did more in the way of detail work than i usually do.
- GrandpaPhil, Louie da fly and Archi
- 3
Let me finish off this sail by telling you guys that i'm using Heller blocks, which almost pass for medieval blocks, but are damn near unusable. I also was not provided any kind of kit string, but that's typical for Heller. IF they give you any line whatsoever, it's going to be worthless and model-ruining. The same goes for Revell kits pre-1990.
I also have a solution for the bendy mizzen yard, and it's sitting right in front of you. My idea is that the mainsail is perfectly sufficient to propel the ship, and knowing Medieval sailing techniques, the mizzen sail was likely used more as directional trim; a "wind rudder" more than actual propulsion. Because of the toggled blocks, i would have to just include the toggles and tyes, and the halyard. No blocks or lines, just the furled sail.
This is the box art.
The box art does a pretty good job of depicting the proportions of the actual model, and that includes the yards. The mizzen yard is shown inboard the shrouds and parallel (kind of) to the keel. They are either raising or lowering sail, because the blocks are still attached to the yard. They probably would have taken those off to clear up the deck when the sail wasn't being used. The artist also depicted the men on the ship as significantly smaller than 1/75, more like 1/96.
Multiple historical images also depict caravels sailing with only the main, although the mizzen sail is basically always depicted as being furled aloft rather than on the deck. These images are, however, all significantly later than 1441.
- Knocklouder, GrandpaPhil and Archi
- 3
I've made a flimsier yard work, so there's no reason for this one not to. I just have to be gentle. Maybe the next kit will involve the replacement of yards.
...What i'm thinking is a generic English galleon rechristened the Queen Elizabeth, for a friend of mine. Obviously with historically accurate fittings.
- GrandpaPhil and Louie da fly
- 2
50 minutes ago, Louie da fly said:
It's also a gentle lead-in to building a whole ship in timber
Oh, stop! You really are that persistent, are you? Don't think i don't notice. For now, it's good to watch you build Medieval ships. You already know my first wood ship will be the S.F.
- Louie da fly and GrandpaPhil
- 1
- 1
To everyone here, I am currently working on a 15th century caravel, the Sao Paulo. You can see it in the pre-1500 kit builds.
On 1/8/2024 at 2:22 AM, Isaiah said:
you’d be a bit sad giving away
Actually, i'm happy i get to give it to someone else! I am happy that someone thinks highly enough of my models as to ask for one for himself. I am happy that my creation will get to be viewed and enjoyed by someone other than me, and whenever i hear that someone saw and liked one of my ships, i get the same enjoyment.
2 hours ago, Old Rentner said:
somewhat depressed
I will continue to say that for a first model, your Mayflower is better than most. You can talk to me anytime, i will always be here.
Happy belated New Year, William!
Now that the rigging of masts is complete, we can start in on the yards.
Yes, you saw right. The main yard is 1.5x the LOA of THE SHIP. Each individual one of the spars that are tied together to make the yard are individually as long as the distance between the bottom of the keel and the top of the flagpole.
It also might be an issue that i'm not using the plastic kit-provided "sails", because the mizzen yard is the second or third flimsiest yard i've ever received in a kit. I just got done painting the rest of the blocks and will begin stropping them at some point today.
On 1/11/2024 at 7:14 AM, Admiral Beez said:
I'll likely have a similar experience, but I think I'll give it a go.
Just save yourself some time and sanity like I did, and junk the shroud loom. However, you could very well make it work and prove us all wrong.
- allanyed, mtaylor and Admiral Beez
- 3
I also plan to use toggles on the vangs and braces for both sails, 8 lines in total.
9 hours ago, Louie da fly said:
could have been a tiny bit tighter, but setting up these things is pretty difficult.
For being the most complex shrouds i have ever rigged (looks can be deceiving!) I like the overall appearance. I agree with your assessment, however, from a distance it isn't really seen.
9 hours ago, Louie da fly said:dating right back to the year dot.
1441 exactly?
The open flame technique worked miserably on the Golden Hinde, breaking several lines, and i never tried it again. I am open to the waxing technique though, i bought several pots of finger-apply lip balm just for this. I have never used it as lip balm.
HMS Surprise by Vincwat - scale 1/69 - Lego
Honestly, i think of Lego as a legitimate modeling medium. I didn't know Lego models were even considered legitimate here, that's why i haven't made a build log for one.
