Posts posted by HIPEXEC
Not every step is perfect, but I made way more than I will need, so I can cherry pick the best sections. These steps look much better than the Constructo steps since they each have wider landing treads than Constructo's.
Dave,
Nice idea. I'll try any and all ideas until I like the results.
Yes, Constucto gave me pre-cut step sides, but they are so thick, they leave only a little room for the actual step? I'm still pondering how to attack this problem.
Looking forward to see your ladders.
Sam,
I like the idea of a wedge or block down below. I dropped a piece in and had to fish it out of the hull....no fun.
You're right....I continue to buy new tools. My Admiral marvels at how my work area has grown and grown and grown!
Thanks,
Rich
- Sjors, augie and Dimitris71
3
I made the chimney from a 6mm dowel and painted it. I drilled out some material in the end to make it look like the chimney opening. I'll pin and glue it tomorrow.
I glued all grates except the bowsprit grate. I also glued a shim in the bowsprit hole so the bowsprit slides in perfectly exactly at the correct angle. Next, I'll make the dowel hole through the bowsprit and deck, so when it comes time to mount it, it should just slip into place.
I thought of drilling the deck, but I get cold feet thinking about drilling in the deck. Pinning might be good. I also thought about doweling it so the dowel would match the bowsprit wood. What do you all think of that?
Since the bowsprit doesn't penetrate the deck for support, the way it is, it will only have glue where it meets the deck and glue where it passes through the hull. That seems fragile to me. Any ideas as to how to lock the bowsprit so it will be held robustly?
- Sjors, MarisStella.hr, src and 4 others
7
- src, Aussie048, MarisStella.hr and 2 others
5
USS Constitution by usedtosail - FINISHED - Model Shipways - scale 1/76
Love those clamps...your Admiral can hang out laundry in between clamps. I also like your use of thumb tacks to bend planks.
