Everything posted by Rustyj
US Brig Syren by Rustyj - FINISHED - 1:64
Rustyj replied to Rustyj's topic in - Build logs for subjects built 1801 - 1850
USF Confederacy by Rustyj - FINISHED
Rustyj replied to Rustyj's topic in - Build logs for subjects built 1751 - 1800
- 149 replies
- confederacy
- frigate
- 149 replies
- confederacy
- frigate
- 149 replies
- confederacy
- frigate
Augie you’re being too modest! I’ve seen your work and it is very good. Besides we both have the same teacher. Ok here are some more pictures.- 149 replies
- confederacy
- frigate
Hi Robert and thank you. The wire I used was craft wire. It was copper wire clad with a black covering. I believe it was around 24 gauge. I measured the shaft I wrapped the wire around and it was .054” (a little under 1/16”) so the rings should be pretty close to that. The size of the rings is just what I thought looked right and not taken from any measurement. Thanks again.- 149 replies
- confederacy
- frigate
Hi Augie, If I remeber correctly???? The stem is pear as well as the framing for the hatchs. I used some cherry for assorted deck pieces, binnacle, shot racks etc. -
Hi All, I've been digging through my file and I'm putting to gether the pictures for my scratch build of Chucks Model Shipways Syren. The build is in the 1:64 scale. The main wood used was Boxwood, Cherry, Holly and Swiss Pear. This log was started back in 2007 and I was bad about taking pictures but here is what I have.
- 149 replies
- confederacy
- frigate
Here is the ebony and holly strips I made to deck the great cabin floor as well as placing the hatchs and starting the planking of the deck. The deck planking is boxwood.- 149 replies
- confederacy
- frigate
Hi Pete, I glue them in place and then cut the notches. It will be harder to do it this way but for me I feel I can get a better fit in the end.
- 332 replies
- Triton
- cross-section
Nothing much to show other than just working my way across the lower gun deck. I temporarily glued the plans on because I didn't trust myself to transfer the measurements. Seems to make straighter lines for me at least.
- 332 replies
- Triton
- cross-section
- 149 replies
- confederacy
- frigate
- 149 replies
- confederacy
- frigate
Hey it's no problem Ben. Love the talk. Yves having been one of the lucky ones I understand your wishes.- 149 replies
- confederacy
- frigate
I have not seen the castings from the kit but I did see the mess they made of the figurehead. Ben are you out there? Can you help?- 149 replies
- confederacy
- frigate
Byrnes table saw accessories
Rustyj replied to Neill's topic in Modeling tools and Workshop Equipment
Hi Frank.I don't have any jigs and such but to cut the insert I do use the same size blade. It's aluminum and doesn't seem to dull the blade. -
Here are the stern decorations the were generously provided by Chuck. They are resin cast by Chuck and then painted by me. I could take 50 years and not be able to sculpt anything close to this.- 149 replies
- confederacy
- frigate
