Everything posted by chris watton
No, Sphinx is a small 20 gun post ship, a miniature frigate in looks, and very mid 1770's. Surprise is two decades later, and in reality a French corvette, although larger than Sphinx, she was still considered too small for a frigate by that time, hence her very short active life after capture (in reality). Surprise would have had a launch and pinnace, but not a yawl, I do not think, as this was replaced by the cutter, around 24 foot in length.
OK, Jim (Hatch) has put together the three mini coat kits that will be standard for the Sphinx kit, a 22' yawl (£24), 24' launch (£25.50) and 28' pinnace (£28.50). And he has done a marvellous job, I think. I am hoping to have a few of each in stock next week, to buy individually, as Jim is doing a little online (PDF) build manual for each. The 18'cutter is also getting a small revamp, in keeping with the new releases. The boat kits will have extensive laser cut parts, in pearwood (0.6 and 1mm), including laser cut pear oars, thwarts/stern sheets and gunwales if applicable, and MDF bulkheads and building base. The keel for all new boats is 1mm pear, to keep the scale look, plus a PE sheet for the finer detail (floor/gratings and 'iron work) A little later, I will have a 36 and 34' launch, 32' barge and 32' pinnace, and finally a 36' admirals barge, which will be suited for a larger model with the single boat on/in the waist
Looks fantastic Glenn! If the PE on that aftermost window decoration is just glued, I would suggest trying to remove it carefully using a knife blade, and swapping them over. there are locating holes for these, when matched up with a pin, should fit perfectly.
- 382 replies
- Vanguard Models
- Duchess of Kingston
Trumpeter Scharnhorst Battlecruiser 1/200 is coming soon.
chris watton replied to yvesvidal's topic in Plastic model kits
I may have to get that. And then never find the time to build it... But feel I must have it! -
Amati Victory has 'Spirketting', but no etching detail. For Sphinx, I am working on a laser cut main wale with properly spiled etching, like the spirketting. Truth is, if this were sub contracted, there's no way I could afford the costs of the extra laser work, and it is only now, now that I know the capabilities of my laser machine intimately, that I feel confident in including this kind of detail in my future kits.
First planking complete and sanded smooth. This is 1mm thick x 5mm wide limewood, much easier to work with than 1.5mm thick lime (Took a day to plank and 20 minutes to sand). Hull lines are quite planking friendly, so not much overlap to sand. No changes needed for the bulkheads, as all planks sit just right on each, so this means I have no more work to do on main skeletal structure. No gun ports to mark out and cut out, too, they will just need a slight file so they are flush with the main frames.
Yes, what I designed is Amati's. If I wanted to develop another, it would have to be from scratch. But then again, I would not want to 'exhume' a 15 year old design...
I have the more expensive Tamiya Yamato kit, and it is so much better than the standard older kit. As it's snowing heavily here today, I won't be going to the workshop to sand the prototype hull. Instead, I thought I'd dry fit another critical area, the bow. This is made up of 14 parts and, as with Duchess and fishing boats (and all new future kits), it has the rabbet worked into the prow and keel parts. Again, these are just for checking and are throwaway parts.. The figurehead is the kit version. Each kit will have a 3-d printed figurehead with zero trimming required. The 20 x 9 pounder short cannon barrels will also be 3-d printed in a matt black colour, an example of which is shown. I have given Jim two sets of carriages, a set with and a set without the cap squares pre-cut into the cheek. I think the pre-cut cap squares may win the day. Ladders this time will be laser cut and etched in 0.6mm pear, making them more to scale, thickness-wise (5 ladder sets altogether for Sphinx)
This is always my dilemma, price. If I was designing for a large manufacturer, this model would have been trimmed down to the absolute bare minimum, to keep the material and packing cost low. I do not consider this so much, but it still means it will cost more than an equivalent size 'mainstream kit' - although they are basically empty shells (As an example, even a small model like Duchess of Kingston has well over an hour's worth of laser cutting time per kit). Right now, considering the amount of materials required for this (many pre made parts means a lot more sheets of pear, maple veneer for decks and plywood), plus cutting times, it will not be below £500, but I hope that people will find pleasure in the build, rather than frustration. There will be a lot of parts both in wood and PE, but that doesn't mean complicated, it just means there's less parts the modeller will have to fashion themselves, plus more detail than conventional kits. It would be so much easier (and so much quicker, development-wise) to just include the bare minimum and a bunch of wood strip and drawings and then ask the customer to get on with it, with the end result being totally dependant on the skills of the customer. Price would be halved, but I suspect many kits would be abandoned out of sheer frustration - and my design philosophy has always been to design a model kit how I would like it, if it were my hard earned buying the kit. But this way, time and costs are quite large - but I also know there will be a lot less 'abandoned projects' with these kits. For Sphinx, like Duchess, this will be only one version, due to materials being tested for the prototypes. There will be a pearwood block and deadeye option, as usual, but that will be it. I am sure some will not use the laser etched decks and plank their own way, which is fine. Some of the results of this look stunning from what I have seen. But I prefer the customer to have the choice, they can use the pre made parts if they wish, or depending on their own preferences and skill level, can use the kit as a basis to really make it their own. (BE's Zulu kit and DELF's Speedy immediately springs to mind) Not sure about manger, as I have made 'concessions' with the extremities of the hull to ensure they are more than robust enough for sanding, so the front upper deck stops at bulkhead 1. Am sure there are seats of ease located on the bow gratings, but haven't thought of flag lockers yet, as I have spent all my time sorting the basics for the hull assembly. As mentioned before, for the larger models, I will dial back slightly, so hull and decks will be conventionally planked (as I can only buy certain materials up to a certain size), but will still include as much deck detail as I can get away with. But if Sphinx sells well enough, it may be worth transferring some of the same design cues to the much larger kits - but for the larger kits, I will also need to invest in another more powerful laser machine.
I always think that (even now)! when it comes to making them, but once I get started, I am always surprised that they are all completed in a couple of days. The new boats will have planking laser cut on a 0.6mm pear sheet, so not so thick (although you still have to taper them yourself, you need something to do..) ETA - I think Sphinx will work just fine without boats, as the quarterdeck will be designed to be only partially planked, showing the deck beams..
I have been ploughing on with designing the Sphinx model kit. here are a few (bad) pics of my prototype build (the third and hopefully final). I am just making this up for pictures for Jim, who will once again build the finalised model for the instructions and box art. This is a lot more complex than previous Vanguard Models designs, and as such, is taking far longer to develop. However, I am hoping the end result will mean that many will be able to make a very nice model from the kit, and enjoy the build without the need for special skills.. For now, this is as far as I will go, design-wise, and may pull back a little on larger models, due to material costs and cutting/engraving times. Knowing me though, I wont.... Regarding the pics, please bare in mind this is still in prototype stage (with a hope that this will be the final stage for all parts that have been fitted), and this model will probably been thrown away once I have what I need from it. Oh, and one last pic that Jim sent me, with progress on the ships boats, three of which will be included in the Sphinx kit.
Occasionally, both for the gunwales and main wales (the latter if they are single strips), I will just pin them in place with little to no glue. I then cut off the exposed parts of the pins and sand smooth and then touch up with paint.
- 382 replies
- Vanguard Models
Yesterday I had a small amount of stock for a selected few Blomefield pattern cannon. I will be having more sizes made in the future, but what I have now is shown in the line drawings. These are 3-d printed and are of a dull black colour. I will be using the 9 pounder Armstrong shorts for Sphinx. These (Blomefield) were introduced in around 1795, so it is very probable that if the model you are making was launched around this time, it would have had the newer Blomefield pattern. However, I would assume that older ships that were still active after this date would have kept their original armament throughout their operational careers (Armstrong pattern). I will get some pics of the castings soon. Cannon Carriage and gun sets (Blomefield) – VANGUARD MODELS
I did design a 72nd Surprise 15 years ago, but was never released (This was for Amati). It is a shame, as it was to be quite detailed.
Looking good, Rusty. Don't worry too much about the thin vertical pieces on bulkhead 9, these are just a leftover from an earlier idea of having the cabin doors separate, and open if the modeller wished. However, this never got passed development stage, as I feared the pear bulkheads would be way too fragile with an opening and very thin door frame (as the pear bulkhead requires very slight bending in order to fit in place), so that idea was ditched. The thin verticals are simply the leftovers... I almost filled in that door area on bulkhead 9, but decided to leave it...
- 201 replies
- Vanguard Models
I would recommend using matt only, not satin and especially not gloss, for the clear varnish.
- 382 replies
- Vanguard Models
A little update. It has come to my attention that a lot of emails have gone unanswered. I can only apologise, the email account was not added to my main accounts, as I thought all mail came via 'enquiries@..' I feel really bad about this, as there are a lot of emails from people that I didn't even know I had, and must have thought I was ignoring them. However, this has now been resolved, so no more unanswered emails! Sorry, Chris
I am working on it, just CAD stuff though, so no nice pics to show. Mainly masts and yard drawings, just to get the laser cut and PE associated with these assemblies nailed. I do have the sample cast resin stern and figurehead decoration arriving next week, and the PE for the three ships boats arriving too. These will be included in the Sphinx kit, but also available to buy as separate mini kits once ready (22 foot yawl, 24 foot launch and 28 foot pinnace) I am back at work full time, too, which is a pain, and I have had to spend a lot of time at the laser machine, cutting production parts for existing kits
