SJSoane
Everything posted by SJSoane
  1. Hi Greg, Yes, I removed the pads on the clamps to get maximum opening, and it just, just fit. My bigger clamp would have crunched the hull. That is an impressive twist! Michael was also talking about hot air guns, and I had hoped Santa might bring one at Christmas, but alas no. Which one are you using? So do you shape this over the hull while blowing hot air, or do you bend off the hull and periodically check for fit? Mark
  2. I apologize in advance if my incremental postings on installing the wales are getting too tedious. When I looked around for information on installing wales, there were many unanswered questions on some of these details. So in the spirit of helping others see some of the issues involved as I work through them, here is another unexpected one. The top plank at the stern takes a fair twist in the vertical direction, in addition to the curve in the horizontal direction. I intended to steam and clamp the top two planks, and then follow David Antscherl's advice in the Fully Framed Model to carve the lowest 2 strakes to fit the very wicked curve further down. Then I discovered the problem of how to clamp the upper planks, first for steaming, and then for gluing. Clamps from the top or bottom cannot reach the plank, and a clamp across the stern slips off due to the extreme curvature of the sides. So in the best traditions of Rube Goldberg, I clamped a right angle device to the table, which gave a surface parallel to the keel to clamp to on the left. I then had to place a small clamp on the device holding the sternpost, to keep the horizontal clamp from slipping away on the right. It is holding the piece in place after steaming; tomorrow I will find out if this will also work for gluing the piece on. I realized that this pulled the hull out of true on the table top, and it will have to be re-leveled before I start marking up for subsequent work on the hull. Mark
  3. Hi John, Marc, yes, this model of the Bellona is absolutely captivating. I have studied photos of it for years, had a chance to examine it close up, and it still sings to me after all these years. The the lines of the ship, the exposed methods of construction, the assured craftsmanship of the model and its 250 year old patina, make this a timeless classic. As best I understand from the various Brian Lavery writings about this model, it was likely used as a demonstration or study for some proposed changes in the hull framing system. One side is framed in a conventional way, and the other side proposes a potentially stronger but more expensive way to run frames from keel to top with fewer interruptions. One side is partially planked, the other has no planking. druxey can probably give you a better understanding of the ribbands, the thin bands running longitudinally. They were removed as planking proceeded up the hull, and were initially used to align and fair the frames. Ed Tosti's books on the Naiad frigate illustrate how useful these were for keeping the hull together and aligned before the more permanent longitudinal structural pieces like wales, spirketting, deck clamps, planking, etc., finally locked everything together. It is interesting in the Bellona model that parts of planking are inserted between the ribbands, since these would not have been in the same place at the same time in the actual construction. I supppose they needed the ribbands to hold the model together, but wanted to suggest the actual lines of planking on one side while primarily concentrating on showing the framing system. I did not concern myself with ribbands on my model, because the stylized admiralty or dockyard framing system locks the frames together with no spaces between. This causes expansion and contraction problems with humidity changes, as I discussed earlier, but it does away with the need for ribbands. Best wishes, Mark
  4. Hi Gary, Your idea of battens is brilliant. It helps see the curve better than any other idea I tried, it provides a solid surface to check the upper curve of the planks against while sanding them to a final shape, and a firm clamping surface for the final installation. I will definitely use this idea for the upper works. Hi res photos are uncomfortable; I admire Ed even more for posting these all the time. They show more than the eyes can see, and they reveal that one's craftsmanship is not as good as one thought. A little humbling. Maybe I can figured out a resolution for photos that exactly matches the level of detail that I can see without magnification... Looking forward to seeing your progress on the Alfred! Mark
  5. Greg, I am glad you prompted me into, and liked, the hi res photos. I am not sure how many of those revealing photos I can bear to post over time, but we will see... druxey, ah, hah, very ingenious! Thanks. Mark
  6. Hi druxey, A few years ago in Denver, I put a humidifier in the shop and it didn't seem to make a huge difference. But I did manage to start rust on tools, so I quit. Moving to Montana certainly has helped with higher humidity. Maybe the Admiralty models did not have this problem because it is more reliably damp in London more of the time.🙂 My posted picture raises a new question that I have not yet faced on this project. This plank is cut by the gunport. I started filing to fit before installation, and then it occurred to me that I ought to be using the gunport itself as a guide for filing the piece to final fit after it is glued in. This will be the same situation with all of the planking when it hits the sides of the ports. Are there any best practices for filing to the port without accidentally filing the side of the port itself? Masking tape on the inside faces of the ports? Mark
  7. Hi Greg, I am like an aging film star; no closeups, soft filters on the lens required! But in a Hollywood-like expose, here to reveal all, is a closeup of the plank I just glued one, before sanding. You can see all my dark secrets. The re-drilling of the temporary batten, the stain on the hull that has been there for 10 years and I have no idea where it came from, and most important, the seams opening up between frames in places. These seams open up in the winter, with the lower humidity, and close in the summer. This is a classic problem of cross grain construction, where the wood expands and contracts much more at right angles to the grain than it does lengthwise. I measured this seasonal change at 3/16" to ¼" over the length of the hull. Good wood construction argues for avoiding this, or using slotted screw holes on wood at right angles to the grain; otherwise, the construction can tear itself apart. This is obviously not possible in this project, with deck clamps, wales, spirketting, planking all glued on at right angles to the frames. But several centuries of this construction methods seems to have worked, and I hope it will work for me. The humidity shifts are not nearly as severe here in Montana as they were in Colorado, so I see less annual movement already. And cross fingers, the planking above the wales still to come should cover up my other dark secrets... Best wishes, Mark
  8. Hi Alan, A nice thing about retiring is that it put us into a one story house, which means I have windows in the shop. The bad thing about retiring is that there is less sand in the top of the hourglass, which creates a greater sense of wanting to get things done! Mark
  9. I am making steady progress on the wales. My old clamps are proving quite serviceable for this; I have started to run them through gunports as I get further astern and they no longer reach from below. The last photo shows why Gary's idea of a batten is such a good one. There are numerous little pieces around the pierced gunports, and I can see they will easily go astray without a constant guide from stem to stern including going over the gunports. Mark
  10. Ed, Would the reason for this ingenious fixed yard and double topsail be that it would take fewer men to manage the sails (smaller surface to handle, more subtle adjustments possible)? Beautiful craftsmanship! Mark
  11. Hi Gary, I did not think this through many years ago, when I got all exciting about putting in the gundeck before messing with the wales. I can see the value at this point of doing the wales first, since my framing system does not easily allow of clamps above the wales. But there is always a way, if only we stop to think about it a while! Mark
  12. Hi druxey, Yes, you are right! I wish I had thought of that. Oh, well, when I do my next 25 year long 74 gun ship, I will get the order right! Mark
  13. Thank you, Marc, for your words of encouragement, and I enjoyed your tag line of "we are all works in progress, all of the time." Applies to us and our models. Once I rounded the bows and began placing planks further aft, I realized that the wale dips below the lower gundeck at midships; and therefore, my clamps from above would no longer work. So I rummaged through my box of old tools, and recovered the clamps I had made almost 20 years ago to clamp up the growing sandwich of frames in the admiralty framing system. I ran these through the open frames athwartships, and they worked perfectly to clamp from below. I just have to be very careful not to nick the frames when I pass the threaded rod through. I wrapped them in tape to help avoid the worst damage. Mark
  14. Hi Sailor, As John points out, the hooks give greater strength to the wales, preventing them from sliding fore and aft relative to each other. As I understand it, the ships tended to droop at the head and stern--this is called "hogging"--due to the greater buoyancy at midships relative to the two ends. The wale curves up to help counteract this hogging. The wales are in tension, pulled along their lengths, to resist the hogging. And so the hooks help keep the wales from pulling apart along their lengths when they are under strain. Even on the model, these provide surprisingly effective longitudinal strength. I understand the hooks were only used on larger ships, presumably due to the greater forces at play on a longer hull. Mark
  15. Hi Mike, I agree, that example has too much joint showing for my taste. If you experiment with some ideas, I would very much like to see them! Mark
  16. Thanks, Mark, for the kind comment. I continue to be inspired by your phrase, "The shipwright is slow, but the wood is patient." That applies to me big time! Even with more time to commit to the project, it still seems to take me forever to get each piece on the hull. And thanks, Siggi, for the update on the collections in London. It sounds like they might finally do the right thing and put more of that priceless collection on display. And I look forward to seeing your new project, the 60 gun 1745 establishment. Will it be a full hull? Best, Mark
  17. Thanks, Gary and druxey, you both helped me get this far! Håkan, although I am only a few months into retirement, I highly recommend it. A friend described retirement as this: "remember a sunny, summer day during your year between 8th and 9th grade (12-14 years old). That is retirement". Mike, good question about highlighting the joints. I have gone back and forth on this over the years, wanting to show off the joinery, but also thinking about the effect of scale. Looking at a model at 3/16"scale is like looking at the real ship from a good distance away, where joints would not show prominently, if at all. For the same reason, I have been using tinted colors so far, to keep it from looking too intense. At a little distance, a real ships colors are more muted due to the atmospheric effect. My boxing joint at the foot of the stem is an example of no highlighting (2nd photo). However, I did put some pencil graphite in the joints of the capstan step (3rd photo). I may do more of this. But for the wales, I think it will not show anyway. Looking at the 2nd model of the Bellona (shown on the cover of Brian Lavery's book below), the wales are pretty black and uniformly smooth, even with the more muted colors on the gunports and the fore bulkhead. I considered Ed Tosti's solution for his Naiad, which was a dark brown color, but I fancy staying closer to the 18th century model I am emulating. I am taking Ed's advice, and putting together a test panel to try the black stain on the joinery, to see how it looks before settling this altogether. So how will I feel if I put all this work into the joinery, and it does not show except very close up? It is a little like all of the great detail that many projects on this website put into lower decks, knowing that they will never be seen again. At least the ship modeler knows the details are there! I am open to thoughts about this. Best wishes, Mark The Lavery book it at: https://www.amazon.com/Ship-Line-History-Models/dp/1591141877/ref=sr_1_1?ie=UTF8&qid=1516232652&sr=8-1&keywords=The+Ship+of+the+Line%3A+A+History+in+Ship+Models
  18. The first planks of the wales are on, so far, so good. They are a little oversize in thickness to allow for leveling later, but the hooked joints are tight. These were the most challenging pieces I have installed so far on this project, with compound curves and tight tolerances on the hooked joints. Mark
  19. Gary, you are so right about doing things a couple of times to finally figure out what you are doing. Now if we had all had apprenticeships with a master model builder when we were young, we might have been able to avoid a few mistakes later in life, but not all... Mark
  20. Gary, sorry to hear about the channel mix-up. I look forward to the updates, when undoubtably the planking will be even better than the previous because you have now had a practice run! Mark
  21. I forgot to mention, thanks Siggi, for the spectacular photos of bows. These are the kinds of images that keep me going, because I am reminded just how beautiful these ships and models are when they are completed. And it looks like more models are now on display at Chatham and Greenwich? The last time I was there a number of years ago, there were very few compared to the massive numbers in the old display at Greenwich before the museum was renovated. I had pretty much given up on Greenwich. Mark
  22. After recalibrating my gantry for measuring off the sheer drawing, I decided it would be prudent to re-plot the wales, just in case things went astray during the move. While I was at it, I re-thought how to attach the batten above the wale, for more accuracy. I had previously plotted points the thickness of the batten above the wale, so I could see the points from above while attaching the batten (too hard to look for points under the batten, in the shadow). But this proved to be inaccurate; the batten itself was not completely the same width along its length, and I had now plotted more points against other points, allowing errors to creep in. So, instead, I drilled holes at the plotted points at the top of the wales, which I could see clearly without the battens in the way. And I then put small nails into the holes, using these as stops against which I could very accurately hold the batten while drilling and fastening it. This was a reminder to me that--at least for me--registering one piece against another is going to be more reliable than free-handing. Mark
  23. Mark and Ed, I missed your comments before I just posted above. Ed, I take your advice to heart; attending rigorously to the drawing is going to avoid any visual ad hoc adjusting that will later get me into trouble. I am also reassured that the wale appears to be parallel to the top of the hull right at the bows, since that was also carefully plotted from the sheer. Interestingly, as I tried to figure out why my plotting on the hull was originally erroneous right at the stem, I double checked my means of measuring. I had been using a gantry like yours to measure from a set height above the hull. But I unfortunately discovered that in my recent move, the gantry came out of true. The top of the gantry is not completely parallel to the base, and sheer drawing relationship to the top edge of the board has changed slightly. I don't know if this is the increased humidity, or things got knocked, but recalibration is definitely necessary! Mark, I see what you mean about the original Bellona model. Yes, they did leave off the topmost, foremost strake, I believe to avoid running into the temporary batten in this demonstration model. So I am definitely working to the top line of the wale taken from the sheer drawing, and I will be planking with four strakes in the wale. And it is a joy to be able to work on this more fully in retirement, although I still don't get as much done as Ed does in a day. He sets a standard to which I continue to aspire!
  24. Thanks, Gaetan, Siggi and druxey, for your thoughtful help with this question. I worried in the middle of the night, because all of your examples, and my own of the Bellona, show the two wales coming to the stem at an acute angle, not as a horizontal line as my previous photo showed. So after more careful measuring, which continued to confirm my location, I realized that it had to do with the angle of the photo. As I show below, dropping the camera down reveals that my wales also come to the stem at an acute angle. And then I realized that the only way the wales could form a horizontal line from one side of the stem to the other would be if the bows were a perfect hemisphere at the stem. But since the hull is slightly pointed at the stem, the wales will have to form an acute angle. Mark
  25. Hi Gaetan, Yes, the wale does make a double curve. i confirmed this more horizontal arrangement with careful re-measuring against the sheer, and also checking against the photo I took of the original Bellona model, where you can see the top of the wale on the port side is just about horizontal when it joins the stem. It is particularly interesting that the French wale you show definitely angles upward in comparison. This is all the more interesting because I understand that the influential Bellona design was derived from a captured French ship. I wonder if the original French ship had a sloping wale, and if the British adapted the French design to their own traditions in some places. Best wishes, Mark
