SaltyScot
Everything posted by SaltyScot
  1. Peter, That picture literally spoke a thousand words. I had several ideas as to how I was going to do this, now I have one. Thank you!
  2. Steve, This is a great summary and a very interesting and fact filled "report". I particularly liked the Wipe-On Poly solution. I too will tuck all this away for future builds. Thank you!
  3. I use this technique quite often too Keith and for that very reason!
  4. Being a lover of any old wood I think what you have done here is fantastic. What a beautiful display piece! Congrats on the build and welcome to this wonderful forum!
  5. That is some fiddly work there Chris but it is coming along. We are all obviously very self critical of our work and that is what makes us strive for perfection. That being said, let us remember the words of Salvador Dali - "Have no fear of perfection - you'll never reach it"
  6. Question for you.... in the first pic of this post I see you stropped the blocks. Did those wire eyelets come with the kit or did you fabricate them yourself and wrap them round the blocks? The reason I ask is because that was what I was thinking of doing with mine.
  7. That is quite the kit and she is starting to look very nice!
  8. Thank you for the info there sir. Sadly I stained the hull earlier on this afternoon. That being said, I will definitely take your advice and use it if I come across a situation like this again. There will be a way round all this
  9. As so often happens with the best laid plans, things didn't go as I wished they would. I had 3 coats of blue on the hull and was very patient and waited the full 24 hours after the 3rd coat so that it was completely dry (I didn't do that with the second coat entirely and got a scuff mark..... ). I had ordered the white pinstripe (1/8") to arrive today and was looking forward to getting it on. When the package arrived and I saw what was in there I was shocked. The tape was nowhere near 1/8' wide, more like1/16" !! Not wanting to be beaten I masked the hull back up and spray painted the white stripe that way. The lines are not as precise as I would have achieved with the pinstripe and that concerns me. I have been battling with the option of putting a 1/4" strip on there now. Despite masking I did get a little white paint bleed onto my lovely, shiny blue hull I rubbed it down again with 600 grit and will mask and repaint again tomorrow. The jury is still out on the width of the pinstripe.
  10. We all know that research plays a huge roll in the accuracy of any model, Glenn. Here we see a prime example of that, nicely done sir.
  11. You are doing OK, Glenn. The improvements you are looking for will happen automatically with more practice. That is usually the way thing go, isn't it?
  12. Sometimes the simplest jigs give the finest results. We don't need to "over engineer" stuff like this do we. Once again, your eye for perfection (this is aimed at your first post in this new lot where you swapped out that piece that was not quite good enough for you), is what is giving this build the quality it has. Thumbs up from me sir.
  13. That is exactly what I have been doing, but thank you very much for your input. The decision to be made is just how much detail am I prepared to go intoi for a model of this scale (as you mentioned before). I will be aiming for a little more realism on the winches than I currently have.
  14. The paint job is coming along quite nicely, I am very happy with the way she looks right now. As per the instructions on the can, I have to wait 48 hours between coats. I can do a quick respray, if necessary, if I do it within an hour of the initial coat. I have two coats on there as of this writing and am waiting until Monday afternoon to add the final coat. After that the tape comes off, the wood on the lower half of the hull will be treated with a very weak stain to bring out the red tones (already tested on some scrap walnut strips) and then she will get a clear coat to protect everything. In the meantime I am cutting deck planks, sanding down the mast to the specs in the plans and generally cleaning up my shipyard table
  15. She looks better every time I see her, Phil, really coming along nicely. Your last image here shows a good example of how the card is stacked (I hope I got that right??) for strength once it is fitted. Very interesting.
  16. I have also used the glue/sand and fill method mentioned here. By adding a little glue to the crack (I use an aliphatic resin glue, applying it with a fine dental tool) and sanding shortly afterwards, the sanding dust basically applies itself to the glue in the crack and fills the hole - if it is not too expansive of course. I prefer this method to the mixing sawdust with glue beforehand method but we all have our preferences, right?
  17. This is truly a fantastic build. The Victory is a personal favorite of mine, always has been since I attempted the Airfix kit as a young boy. One day maybe....... The good thing is, I will have your build log to help me along if and when I do get round to it. A seriously good example of what she should look like. You have a new follower sir!
  18. I like your methodical approach here sir. It shows in the quality and standard of the work being turned out.
  19. This looks beautiful and precise, Mark. That measuring device in the first image looks like a nice piece of kit and very useful too. I wouldn't want a bent frame on a model of this calibre either. Very nice work.
  20. Thank you for that, Phil, that was a very nice thing to say. I agree with what you said about deciding to try; as we all know, even the longest journey begins with that first step. Onwards!
