Everything posted by SaltyScot
Nice lines, Glenn, she looks very neat. If I may ask, what sanding sealer did you use sir?
- 241 replies
- Vanguarrd Models
- Harpy
I can only agree! A real pleasure to look at, Peter.
- 222 replies
- sultana
- model shipways
Apologies are not needed here, both of these stories are very touching, John. I must say I was saddened to read of this great boats demise on the sands, what a very sorry end to a wonderful ship. She certainly led a full life at sea. The story of the model is not so different. There were times when it could have been lost and completely forgotten, were it not for some good fortune and a few very willing people. I am so very glad she is being restored in such a professional way to at least show the people who get to see her just some of the grandeur and spirit of the once great Duchess!
I am not sure if you are familiar with the term "gob smacked", John, but I was certainly that when I went through this log. It literally means speechless and sitting here staring open mouthed. The quality is outstanding. I know you are a long way into the build but I will hop on for the rest of the journey sir.
Having been through something similar in the past, I can (quite literally!) feel your pain Vossie. I too wish you a speedy recovery. One TV series that we did enjoy was the Day of the Jackal (we watched it on Peacock). If you haven't seen it and can get Peacock I can highly recommend it.
- 714 replies
- lady nelson
- victory models
That is quite ironic. I am researching the history of the Baltimore Clippers right now. Although a little earlier than the 19th century, they still spent some time up in this area (I live on the edge of the Chesapeake Bay). Whatever you do, I look forward to being able to follow.
- 222 replies
- sultana
- model shipways
Today I tackled the mast. I went ahead and fitted a brass washer at the mast base. I had seen this done on an Endeavour build on the Ships of Scale forum and quite liked the look (although that builder had painted his black to match the boat's theme). As anyone who has done this build knows, there are A LOT of the small eyelets to be attached to the mast, 26 alone running down the stern facing side for the sail. It was certainly interesting drilling all the holes and cutting the eyelets down to size. The plans recommend cutting them down to 7mm in length but I found this to be too long. I adjusted mine to 5mm and they fit just fine. The only ones I had to make a little shorter were the few at the top of the mast. The taper up there required shorter eyelets so that they didn't protrude out the back. Once everything was assembled, I did a dry fit. This is one tall mast! The mast was then primed, left to dry and another fit was done. This really gave me a good idea of how the final colors will work together. I will be applying two more coats and a clear coat before all is done. I do have one small spar still to add at the top, I wanted to wait until everything else had had its first coat and dried because it sticks out at the rear of the mast. It will soon be time for the rigging Before that happens though I must finish the deck completely. I have a bunch of cleats to add and a few blocks still to make.
Well worth the effort I would say. Nicely done!
- 332 replies
- Harpy
- Vanguard Models
I can only agree, this looks fantastic. You did a fine job with that ink wash, it really made it pop.
- 78 replies
- Derfflinger
- Flyhawk
Bit of an understatement there, Peter, if I may say so. You should be proud, she is looking extremely good, sir. Congrats on a job well done. Do you have anything particular in mind for your next project?
- 222 replies
- sultana
- model shipways
Welcome to MSW, sir. One can see pretty much instantly that this is not your first "rodeo", even if this is on a much smaller scale that what you did before. As someone already mentioned, you are going to do just fine here.
- 81 replies
- Norwegian Sailing Pram
- Model Shipways
Impressive, truly. A very clean, precise build, Peter.
- 222 replies
- sultana
- model shipways
Your sanding has really smoothed out the planking there, Glenn. It looks really good.
- 241 replies
- Vanguarrd Models
- Harpy
I didn't get into the shipyard until after 3 PM today. Nevertheless, I did manage to get a few things done on the deck. The bow has its cleats and now the trim can be added and the edges finally get their coats of wipe-on poly. I also started adding the blocks at the mast and finished the railings at the bow end of the boat.
best SECOND model ship kit recommendations
SaltyScot replied to palmerit's topic in Wood ship model kits
I could not agree more. Getting a feel for the ship/boat or whatever it is puts me in a whole different mindset when it comes to tackling the model. It's kind of personal if that makes sense. -
I decided to take a break from the deck for a while and start stropping some of the 40 odd blocks that are required for the rigging etc. These things are 4mm in length and VERY interesting to handle! I followed Keith Black's method of stropping that he adopted in his 2021 build of the USS Tennessee. It worked well once I had the system under control. Having never done this before, it took me a few tries to get the feel of it. Now I am getting along rather well but, despite my well lit magnifying glass, I can only do a dozen or so before I have to rest the old peepers. The wire I am using is 34 gauge so I have to be careful not to over tighten it.
