Everything posted by captainbob
Hi Walt, Glad to see all is well and you are building again. Your rebuild is looking much better. Bob
- 208 replies
- meridea
- repair ship
Thanks Mark, Making repetitive parts reminds me of a story. A man driving down a country road sees some handmade furniture in front of a house. He liked the look of one of the chairs and asks the price. The craftsman said $35.00. The man thinking the chair would make nice dining room chairs orders a set of eight. The craftsman says “That will be $2000.00.” The man complains and asks why so much. The craftsman says . . . “The first one was fun”. So now two more buckets. Bob
SS Vinal Haven by TBlack - FINISHED
captainbob replied to TBlack's topic in - Build logs for subjects built 1851 - 1900
Where a stack went through a deck a larger hole was cut in that deck to keep it from the heat of the stack. The ring with the holes and the cone shaped sheet metal above it are a cover for that larger hole. Bob- 326 replies
- vinal haven
- steam ship
Yah, I'll settle for the snails. Bob
- 552 replies
- maine lobster boat
- Midwest Products
Plank edge sanding
captainbob replied to rebekb's topic in Building, Framing, Planking and plating a ships hull and deck
I've had bad luck with my "Edge Strip Cutter". The blade is mounted too high to keep it from following the grain of the wood. Bob -
Michael, Went back to see find something and noticed I missed your art show link. I wish I were there to see it in person. Love your piano(?). Have you come up with an easy way to lower the mast for transit, or will you loosen the shrouds every time? Bob
- 2,215 replies
Today I made a couple of buckets for the dory. There are many methods, but this is the way I did it. First I cut 12 staves the same size and mount them on a piece of masking tape. These are .03” X .50” X .16”. I sand a slight taper from end to end so one end is narrower than the other. Then one by one I sand the edges so the cross section is a trapezoid. Place them side by side on clear tape with the smaller face pointing up and the narrow ends all at the same edge. You can see how the taper causes a curve. Cut off one end of the tape flush with the edge of the last stave. Now roll the tape with the wood inside until the first and last pieces of wood meet and the tape on the end goes around the outside to hold it all together. Make a disc of wood to fit inside the smaller end and glue it into place. The bands are made from narrow strips of card stock. After cutting I stained them. Cut the tape off the lower part of the bucket and glue the card stock to look like a band. Remove the rest of the tape and glue the other band around the top. I didn't measure the taped staves for the diameter of the bottom but you could measure everything carefully and use geometry. Bob
At 1:96 scale yet. If I hadn't watched you do it I'd say you were kidding. A fine build, John, A fine build. Bob
Plank edge sanding
I clamp several planks together, like a deck of cards, and then sand the edges all at once. Bob -
Michael, The chain plate, deadeye and lanyard all look good. Will there be an easy way to release them when you want to lower the mast for transit? Bob
- 2,215 replies
Ah, but she's out and working. She'll be hosed down when she gets to dock and sells all those lobsters. Of course Popeye will have to keep some for his own dinner. Good work Popeye. Bob
- 552 replies
- Midwest Products
Finally I was able to do a little more on the dory. I started to paint the inside the same blue as the outside, but everything I saw showed the inside tan, yellow or yellow-orange. So I painter it a warm yellow. I also added the lifting ropes in the bow and stern. Now I need to put the boat aside and make all the things that the fisherman needed I n the boat. Later, Bob
Michael. Love the chain plate with that little detail at the bottom. You're a real craftsman but you are an artist also. Bob
- 2,215 replies
