Everything posted by wefalck
Some people use air-baloons as formers. One has to check first, whether the choosen varnish doesn't eat the baloon though. A completely different technique is to hide a stiff wire in the bolt-rope of the leeches and feet of the sails.
In principle yes. However, I would refreain from using such organic materials that are prone to microbial attack, commonly called mould. Other people seem to have used diluted PVA glue or, in my case, sanding filler. Matt acrylic varnish could be another option.
Good point about water-based paints/sealers and steel wool. Some people use magnets to pick up the wire residues. There is also aluminium wool apparently, but I don't have come across a source for it yet. Apart from the steel wool, I also use razor-blades as scrapers after applying sanding sealers, which gives a nice smooth finish too. It only works on flat surfaces though.
What kind of varnish are you talking about, acrylic-based ? Even water-based acrylics may give off fumes, as they often contain some alcoohol. I believe there are also water-based acrylic sanding fillers. You may have to experiment with the wood you are working with. Something I haven't tried on wood myself, but that may give reasonably good penetration are pure acrylic emulsions, without pigment and and fillers. You can buy these in art-materials shops as primers. It may be also possible to dilute them with alcohol to further enhance the wood penetration, but this requires some experimentation.
Acrylic paints are water-based and will raise the wood-grain. So one would need to sand it again afterwards. Assuming that you are talking about a fully covering, opaque layer of paint, I would prepare the wood with a good solvent-based sanding filler, sand/scrape it smooth, and then apply the paint. Solvent-based fillers are to be prefered over water-based (acrylic) fillers, because they penetrate the wood better.
A method for making panelled sails using paper
wefalck replied to Cathead's topic in Masting, rigging and sails
This is my most recent attempt in 1/87 to show the reef points in a realistic as possible way:- 49 replies
- sails
- sail panels
As I have used this technique on virtually all my models made over the last couple of decades, I may be allowed a couple of comments : Not sure what scale you are working in, but 'bond' paper seems to be rather heavy even though it would be a good quality of paper. I would rather go for something as thin as possible. If I wanted to stich-on the bolt-rope (I never worked in scale, where this would be possible physically), I would use the thinnest fly-tying yarn I could get holds of (something like 18/0 and perhaps even split it). The reef-points are actually held in place by stiched-on crown-splices on both sides of the sail. These can be simulated by two figure-of-eight- or over-hand-knots that are pulled very close to the sail. Not sure, whether 'dafi' presented his technique (already) in this Forum, but for his 1:96 scale HMS VICTORY he developed a three-layer technique using self-adhesive tapes as used by book-restorers to (almost) invisibly patch up ripped pages. Strips of that paper-tape are pasted from both sides onto a backing of very fine silk weave ('silk-span') to create the effect of the sail-panels. This composite can be crumbled and creased to give a realistic cloth effect and when stitching-on the bolt-rope the silk-weave prevents the edges from ripping out. Interesting technique, but I have not yet used it myself.- 49 replies
- sails
- sail panels
Deck Furniture Caulking
wefalck replied to Worldway's topic in Building, Framing, Planking and plating a ships hull and deck
Do you mean deck-houses by 'deck-furniture' ? Deck-houses were normally built using carpentry 'tongue-and-feather' techniques, which make caulking unnecessary. This building technique is possible, because the differential movement of the parts is limited, so that no seams will open. Decks could be laid in the same way, but it is not (normally) done, because it would make it virtually impossible to replace single planks without ripping out the whole deck. This is not an issue for deck-houses. -
More tools - Luthier, jeweler, fly-tying
wefalck replied to vossiewulf's topic in Modeling tools and Workshop Equipment
I have a box full of them in all sizes and shapes. However, as I am working a lot with steel, I have always some swarf and filings flying around that seems to collect on these magnets ... -
We tend to think too much in terms of (building) rules, regulations and standards - because they have become so prevalent and institutionalised since the early 19th century. We also tend to think that any material could be 'ordered' at any time. However, wood is a natural material with limited supplies of the qualities and dimensions the builders may have wanted. So in practice, they may have had to make do with whatever was available in a particular yard. (Hard)wood supplies tend to follow an annual cycle, with wood being cut during the winter, transported to the rivers for rafting during the high-waters in spring. You couldn't just place an order for a particular kind of timber, when you ran out of it ... So one should expect a lot of variations dictated by these boundary conditions.
Indeed, one cannot generalise (easily) from individual ships. However, our physical evidence across the centuries is rather limited, we have to use what we have. Comparing 16th century and early 19th century practices may also be problematic. Production techniques for planks were different, as was timber availability. I didn't read up on CHEERFUL, but where did Chuck get this 'real' planking expansion from ? I gather it is reconstructed ? From which sources ?
Interesting reading, thanks for the link. This actually opens another front, namely whether we talk about shell-first or frames-first construction, or a hybrid of both. It seems that in fact the latter has been quite wide-spread in Northern European shipbuilding and the dhows of East Africa also belong into this category, as the first few planks are put into place before the inside timbers are errected. Shell-first construction would require horizontal scarfs with backing pieces in order to make a continuous plank. This would typically avoided, if at all possible, for garboard and floor-planks in smaller vessels. However, we slowly deviate from the original question. This should actually be rephrased in the sense that planks were taken as long as available. If shorter ones had to be used, then in areas of the hull of less structural importance, i.e. in general higher up.
I gather the question of butt-joints or scarfs depends on how close the frames are spaced and how wide the frames are. If you have double-frames, just a few centimetres apart, you can put a butt-joint just between them without fear that the hull-movement would open the joint or a spike too close to the plank end would split it. If you have wider spaced frames - in my example above they are about 30 to 40 cm apart, you have to make the seam longer and more in line with the run of the planing, i.e. make a scarf, in order to accomodate differential movements of the planks without allowing gaping seams. The scarfs are placed with both ends on frames and no doubling behind is used, at least on Zanzibar. The frames would be too narrow to drive two spikes through next to each other and at a distance that would be safe for the plank ends. Butt-joint would be structurally unsound in this case. It all is a question of the size of the available materials vs. the size of the boat/ship.
I should add to the above that the joints between hull-planks would be scarfed, not butted as on the deck. This requires extra length. Below you can see two images of modern-day dhow-building on Zanzibar. Certainly not the most sophisticated builders, but it illustrates nicely how it was done for centuries: Fitting the scarf between two frames: The faired and smoothed scarf: More details here: http://www.maritima-et-mechanika.org/maritime/tanzania/tanzania.html
Wooden ships don't have 'structural' bulkheads. In wooden ships bulkheads are only more or less temporary, relatively light-weight constructions to keep e.g. loads or stores in their place. The idea of bulkheads as structural parts may arise in shipmodellers, as often the model hull is constructed around solid bulkheads - this has nothing to do with a real ship. I think a plank has to cross at least thread (double) frames in order to be properly framed. If it crosses only two frames wave action or the like can push the plank inwards with the ends rising and the caulking falling out. However, such short planks would generally be avoided, if at all possible.
A 'story-board' is always a good proposition for justifying, why certain features are shown. It makes sure that the different aspects, e.g. of how the sails are set, match throughout the ship. Basic facts to consider would be the direction and strength of the wind relative to the ship and what kind of sea it is encountering.
Frame weatherization?
wefalck replied to Anguirel's topic in Building, Framing, Planking and plating a ships hull and deck
Better yards indeed built under a shed, if physically possible. Wood is not 'weathered', that is exposed to the elements on purpose, but rather 'seasoned' in a shed, as noted above. Leaving a ship in frames outside was rather a necessity (lack of funds, workmen, etc.) then a deliberate choice. -
Didn't say they aren't used. They are not essential, when close-hauled. One has to balance usefulness against detriments.
It may be worthwhile to reflect on the function of the (topping-)lifts. They are there to steady the yard, not to 'lift' the yard, which is done with the halliard. So, when the topsail(s) is/are set, there is no immediate need for the lifts, as the yard is also stabilised by the braces. One can probably let go the lift(s) when close-hauled and the problem is solved.
If you use an acid, such as cooking-grade flavoured vinegar, the coloured compounds will be probably some iron-organic acid complex. If you filter this, there will be no particles. You should end up with a dye. However, big chemical companies can control processes much better and I would also go for commercial dyes. At the amount we need them, the cost will not kill you. Incidentally, the (cast-)iron guns of old were 'browned' by repeatedly wetting them with vinegar. Finally, the rust and iron-organic compounds were solidified by applying lineseed-oil. Kind of in situ oil-paint production.
