Everything posted by wefalck
I would tend to agree with you concerning level of detail and scale - but: unfortunately, unlike in a photographic image, the viewing distance is not fixed. Though in general, one may view a model from, say, half a metre or a metre distance, one may also put the nose over it. If I were to design a model, for instance, as a film prop and it would only be seen from a certain distance, I would indeed put the level of detail on it that is needed to give the 'right' impression. For a show-case model the situation is rather different. Here you need to create the 'right' impression for various viewing distances. For certain details it may be safer to err on the small side ...
Bilge Pumps 1870/80
wefalck replied to GAW's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
I would suspect that Downton-pumps were fitted. These come in many varieties, here is an example from the preserved 1840s Portuguese Frigate: In later years they were also made with cast-iron bodies. I don't have British drawings, I believe, but I think some French and German ones. I would have to check in my library. -
I would like to add to my above post that one has to try to avoid being merely 'additive', which is why the first image in the previous post looks rather cluttered. Details have to blend into the overall image. On the other hand, the two images above do not compare very well with respective to what they were meant to show, because they portray two different subjects from two different periods. The first image seems to show an urban setting from the 1930s, while second image seems to show a more rural modern setting. Since the 1950s you can generally observe a de-cluttering of our (i.e. Western World) land- and townscapes. Simpler lines on everything, plain concrete walls, etc. So there is less 'detail'. The same applies to modern ships compared to e.g. the old sailing ships. Modern ships are mainly welded, while older iron- and steel-ships would have been rivetted, which immediately makes them look more detailed (even when countersunk rivetts were used). So, if you want a realistic appearance as they may have looked at their time, you may to include a lot of clutter and details (as in the first image above). Conversely, if you want to point out the aesthetics of hull lines or of the sail-plan, you may want not to include such detail.
Threads on miniature nuts & bolts
wefalck replied to jhearl's topic in Metal Work, Soldering and Metal Fittings
Dealing with the restoration of antique watchmaking machinery, I came across some pretty odd threads, but they seem to have been somehow standardised, as they re-occur in various machines. Modern engineering handbooks are largely useless to identify such threads. Finally, I got hold of a 657 page book from 1924 that only deals with threads. The multitude of threads that were used in different industries before Whitworth and SI (DIN/ISO norms) is quite amazing. The book also has a section on watch industry threads. It appears that each major factory has (had) its own standards ! However, in the Swiss watch industry the so-called Thury-thread seems to have become prevalent. Here is a Web-site with some information on it and dimensions: http://sizes.com/tools/thread_thury.htm. Chances are that these screwcutting plates that are being sold by watchmakers supply houses (and on eBay) have Thury threads. Proper taps and dies (as opposed to the plates) are made down to 0.2 mm diameter, I believe. I have some down to 0.3 mm, but would use them only on my watchmakers lathe, to ensure absolute concentricity and no side forces in order reduce the risk of breaking them. A die cost about 15 EUR in the late 1990s, when I bought them. Taps are cheaper. -
Shop-made filing-machine
wefalck replied to wefalck's topic in Modeling tools and Workshop Equipment
I gather, a real mechanic would throw up his hands into the air, if he sees me working …. ************************** The next part to be tackled was the socket for the overam holder. An overam is needed for guiding the delicate machine files and for taking up the side pressure when filing. The foot for the sawing table on the casting was hollow and sort of house-shaped inside. A piece of aluminium bar was carefully milled to shape and size to provide a snug fit. Two tapped holes will locate it in place. Shop-made boring bar with collet to fit the milling machine Boring-out the hole for the overam upright Drilling the 10 mm hole for upright round bar proved to be taxing for the capacity of my machines. There was not enough clearance under the mill for such large-size drill. Due to the hole being in one end of the part, it would also not fit into the four-jaw chuck for boring out. In the end, I realised a long-planned project and made an adjustable boring bar from a piece of 8 mm rod. For this I also had to fashion a collet with three set-screws for 8 mm bars etc. With this boring bar it was easy to drill out the hole with an excellent surface finish. Overam holding socket Overamr holding sockt in place To be continued ... -
If you go to location 52°33'07.02" N 4°36'10.96" E in GoogleEarth, you will see just a beach off Castricum in the Netherlands. However, when you switch to the 2005 image, you will see the ghost of S.M.S. SALAMANDER, which was an armoured gunboat of 1872 of the Imperial German Navy. She sank there in a storm in 1919 being towed to the Netherlands to be broken up. The shifting sands now seem to have covered her remains that were still visible in 2006 at very low tide. At some stage attempts were made to salvage and restore her, but it proved to difficult and costly. S.M.S. SALAMANDER was one of the boats of the WESPE-Class, the prototype of which I am currently building: http://www.maritima-et-mechanika.org/maritime/models/wespe/wespeclass.html (see also the building log on the forum).
Thanks for the praise to all I think there are numerous tutorials on the Web on photoetching, Matie. I am using pre-prepared brass sheets available from various vendors. In order to keep things simple I work with small frets only and use small vessels, such as plastic film containers, for the processes. Compared to professional foam-etched parts, my shop-products are not that well-defined at all. It is not so easy to agitate the parts in the etching solution sufficiently uniformly. In fact, I produced probably two bad parts for every good one. In the end I picked the best parts from all tries. Surface etching (e.g. rivets) is simple, you just need two different masks for both sides. As you can see from the pictures in the post above, one mask just covers the areas not to be etched-away, namely the rivets and other raised features.
Well, too much travelling the last few weeks resulted in little progress. It is frightening to think I started this project already in March, thinking that I would quickly return to my WESPE-class gun-boat project … ****** The excentric rod was turned from a piece of steel, while the actual lever with the ball end is a recovered piece from a similar broken commercial product. For other pieces of equipment I turned such levers myself using a ball-turning attachment. Method for turning the excentric for the holding-down bolt Holding- down bolt and excentric lever assembly Table bearing barrel and locking arrangement To be continued ... -
Micro-Mark MicroLux LaserKnife 2525 – A Review
wefalck replied to mtaylor's topic in Modeling tools and Workshop Equipment
Hi Mark, I have been tossing with the idea of getting one of these cheapo units, but your experience really put me off becoming an 'early adopter'. There is a lot of potential in laser-cutting, but as with every tool you get what you pay for. Also this experience seems to confirm the wisdom that these Chinese machines (whether manufactured to foreign specs or direct imports) should be rather considered an assembly of parts in an advanced state of machining … a starting point for a project I may come back to this, when my eye-sight gets too bad for working on small parts - hopefully in another couple of decades or so. -
Wood Preservative/Stabilizer
wefalck replied to robcg's topic in Painting, finishing and weathering products and techniques
Ship models are usually kept indoors, so there is not really a need for preservation or stabilisation. There may be issues with woodworms (anobium punctatum), but this is a long-term preservation issue. In some parts of the World you may be also worried about termites, I gather. Otherwise, the surface of wood is usually treated for esthetic reasons mainly. Covering the surface with some sort of lacquer or varnish also allows for easier cleaning, which again may not be an issue for a ship model that is kept best under a glass cover anyway. Outdoor wood preserving agents that contain various organic or inorganic biocides would actually be most unsuitable for indoor use because they may give of hazardous fumes or may be toxic when people/pets come into contact with them. For the same reason, one should not (re-)use such wood (e.g. old railway sleepers etc.) indoors. -
Cutting brass sheet
wefalck replied to Landlocked123's topic in Metal Work, Soldering and Metal Fittings
For straight cuts in brass up to 0.5 mm thick I would score it with a cutter about half-way through (as noted above) and then wiggle it (perhaps with a pair of flat pliers in the case of narrow strips) until it breaks off. The edge, of course, needs to be filed or sanded flat. Thicker stuff I run through the table saw or the saw table on my watchmakers' lathe with a HSS sawblade. This leaves a very clean cut. Curved cuts in very thin brass, say 0.2 mm thick, can be done with an inverted saw blade in a a jewellers' piercing saw. In this way the teeth will not 'catch', as otherwise there may be only one tooth in contact with the material at any one time. -
For me there is only one rule: reproduce the prototype as well as you can within the limits of materials' sizes and their workability (and of course your skills). Detail only appears too much and overcrowding, if they are done overscale (for whatever materials or skills reasons). The conclusion from this could well be not to include a certain detail, because it cannot be reproduced adequately.
Good point, thibaultron, about the hand-files that are cut for the push stroke, while machine files have a socket at both ends, but normally are inserted in such way, that they cut on the down-stroke of the machine. I also acquired a couple of diamond-studded stub-files with prismatic resp. cylindrical cross-section for use in filing machines; the obviously cut in both directions. ***************** The lathe-turned part for the bearing-barrel was sawn in half and the two halfs were clamped end on in the vice after careful alignment. With a fly-cutter the surface was milled perfectly flat and the diameter reduced to bring the rotational axis of the table into its surface. Milling flat the halves of the bearing-barrel The position for the barrel was marked out on the piece of 4 mm aluminium that will become the table. In the following step the positions for the mounting screws were marked out and drilled mit a 3 mm drill on the drill press. The two half-barrels then were stuck onto the table with a few drops of cyanoacrylate glue after careful alignment. Bearing-barrel in position on the underside of the filing-table The positions for the mounting screws then were marked with a transfer-punch. A light knock separated the parts again, which were then transfered to the mill for drilling and tapping M3 of the mounting holes. I usually start the tap on the mill with a few turns to ensure it is perfectly concentric to the hole and vertical. The tapping is completed by hand. Drilling and tapping the mounting holes for the table on the bearing-barrel Sqaring the edges of the aluminium plate for the filing-table proved to be just at the edge of the capacity of the milling machine. The plate was clamped to the vice on the mill with a C-clamp and the edges milled flat. Squaring the edges of the filing-table With the bearing-barrel screwed onto the underside of the table, the assembly was bolted to the table of the milling machine for milling the slot for the holding-down bolt. This holding down-bolt will be tightened using a excentric lever. Milling the slot for the holding-down bolt To be continued ... -
Possible new technique for making sails.
wefalck replied to rckdr's topic in Masting, rigging and sails
Actually, as the sail would be put together from its panels etc. you don't need any pencil lines and the likes. The seams would show up as on the prototype by the shadow of the edge of the panel or doubling. -
Is the work done already ? If not, why not using very thin polystyrol sheet ? This would save you also the filling and rubbing down to get a smooth surface. Otherwise, I would use liquid plastic cement for glueing paper strips. This seeps into the paper and dissolves the polystyrol of your hull, forming a solid bond. You can apply more cement afterwards as a filler, before sanding the strips.
Not sure, why everyone wants stitched sails. The stitching and the thread used are grossly out of scale unless you work in say 1:24 or bigger. However, glueing the panels together is an option. Not sure the glue on the tape would be strong enough for the narrow seams in the sails. It is meant for full-surface re-enforcement in picture-mounting and book-binding. -
galvanized fittings and chain
wefalck replied to Jond's topic in Metal Work, Soldering and Metal Fittings
If you are using brass throughout, a good base may be chemical tinning. I cannot recommend a reagent source for this in US though. After thorough cleaning and degreasing (as you would do for blackening) you immerse the parts in the solution until a coating has formed. Initially the coating is of a dull silver, which looks quite like galvanised steel. You can touch up places also with paint as noted above. Rubbing a soft lead pencil over areas that would show wear makes it look more like bare steel. -
The work on SMS WESPE has once more stalled a bit, because I got side-tracked by some engineering work. I wanted to first complete the model, but then realised that a filing-machine would come handy when making certain parts … The die-filer is a machine that has all but disappeared from modern workshops. I suppose there are several reasons for this. Many consumer goods and toys that once would have been made from (folded) sheet-metal parts are now made from injection-moulded parts. For more delicate sheet-metal parts also photo-etching is being used. I believe the watchmaking and jewelry industry still uses stamped parts. However, also the methods for making dies has changed. While the stamp can be worked on using milling- and grinding-machines, this is often not possible with the dies, particularly, when they have to have sharp internal corners. The die-filer with its reciprocal, rather than rotary, movement allowed to do this. An inclinable table was needed to work-in the relief that permitted the stamped parts to drop out of the die. Today, electrical discharge machining (EDM) and laser erosion has replaced the old technique. Hand-held filing machines are still in use for work on injection moulds and similar tasks on complex surfaces. In a small model-engineering workshop, the die-filer still has its uses, mainly to work on precision sheet-metal parts and when one has to ensure that the worked-on surface has a defined angle with respect to another. A die-filer can also be used as a scroll saw. For this reason, castings for constructing a simple die-filer are still being sold commercially and and some small specialised machine maufacturers still produce different machines, mainly for the jewelry manufacturers. However, the latter ones are rather heavy and costly. Filing-machine for the jewel-making industry (http://www.walther.ch/hwz/d-fm77.htm) Kit for a filing-machine (http://www.martinmodel.com/MMPtools-subfiles/MMPtools-sub.html) Some bench-lathe manufacturer also offered filing-attachments that were driven from the lathe headstock. As the filing-machine is useful for clock-making, e.g. for working on the spokes of clock-wheels, some people made their own attachments for WW-type lathes and they are highly priced, when they appear at auctions. Cataract filing-machine for their bench-lathes (see: http://www.lathes.co.uk/cataract/index.html) Filing-machine from a 1913 catalogue of an unknown German maker Drawings for a filing-machine from a 1913 catalogue of an unknown German maker Building a filing-machine has been on my agenda for quite some time. With this in mind, I was able to purchase a treasure lot of rare Vallorbe machine-files. The lot contained round, half-round, tri-angular, and square files starting from 1 mm diamater resp. 1 mm x 1 mm cross-section, going up to 4 mm x 4 mm, and of various cuts. Unlike most other types of files, machines files are prismatic across their whole length and have uncut shanks at both ends. Treasure-box with machine-files A selection of machine-files I first thought about converting my only moderately useful Proxxon DS 230/E scroll-saw into a filing machine. However, the table would not tilt and the holders for the saw blade were difficult to adapt. Then a broken jigsaw attachment for a power-drill came into my possession. Having no need for such attachment, the idea of converting it into a filing-machine emerged. The jigsaw was completely stuck nothing moved, and the sole plate was broken off. After having drilled out the screws that held the lid, the reason was obvious: it was completely filled with saw-dust, including the ball-bearing, presumably because it was upside down used under a saw-table. After dismantling and thorough cleaning it worked again. This meant, that I had the mechanism and the casting forming the basis for a filing-machine. The disassembled jigsaw According to the tables in the machine catalogue fo 1913, from which above illustrations were taken, the maximum stroke frequency would be around 400 per minute for hard materials, or less for softer materials. I sourced in China a geared electric DC motor that is rated to have 400 RPM at 12V. The output torque should be sufficient for the machine to be driven directly. Geared 12 V DC motor to drive the filing machine In order to minimise the slot for the files, allowing to work on small pieces, the rotational axis for the tilting machine table should be in its surface plane and also should not move out of the centre line. The foot of the jigsaw was arranged in a similar way and only needed to be adapted. The table will rest on a half-round barrel that can be clamped down onto a corresponding bearing surface. I had some 40 mm diameter alumium in my stock from which I turned the barrel. It will be sawn into half and screwed to the aluminium machine table. The bearing for the barrel was milled accordingly. Similarly, some of the future bearing surfaces on the casting were milled flat, which just went up to the capacity of my milling machines. Luckily the zinc die-cast material of the jigsaw housing is easy to mill. Set-up for milling the bearing of the tilting table Part-machined jigsaw casting To be continued, once I got over my flu ...
timing belts and pulleys
wefalck replied to Kurt Johnson's topic in Modeling tools and Workshop Equipment
These teethed belts and matching pulleys have a standardised tooth spacing and width. On ebay there seem to be various sources for them and some model shops have a small selection. Incidentally, the belt and the pulley on the above picture do not match, they should have the same width. While these belts certainly can transmit a higher torque than round or even V-belts, they do not act as a safety clutch as the other belts would. It is, therefore, easy to overload the motor, if something gets stuck in the machine. -
When the strop is supposed to be served all the way around, one can also use a piece of silk-/cotton-covered copper wire and put the joint underneath the lashing, similar to what was shown in the above post. Such thread-covered wires are available from retro radio-stores and similar places, or sometimes on the flea-markets.
Make it look like brass
wefalck replied to rcmdrvr's topic in Painting, finishing and weathering products and techniques
Only metal looks like metal … apart from this, the plastic modellers have tried to overcome this and there are a number of quite good metallic paints around now. It seems that Alclad is one of the best ones, but I haven't tried it yet myself.
