Everything posted by wefalck
  1. I think your original question was about a difference of rake between masts, top-masts and topgallant-masts ? The answer is probably that there shouldn't be a difference. If there was, somehow the tops and the caps are not properly matched. However, a slight difference is not really consequential from a sailing point of view, only perhaps from an aethetic one. The actual rake was very much subject to fashion and tradition. For instance, it became fasionable to have extremely raked masts around the 1840s, but by the end of the century the became basically vertical. The tradition is that the rake increases from front to back. On the other hand, there are many vernacular craft that had extreme rakes in both directions and often on the same craft - think of certain Portuguese or Chines boats. For a given sailplan the actual rake of the mast will move its centre of gravity slightly, but taking in or setting sails probably has a more profound effect on a square-rigged ship. The situation is somewhat different on sloop-rigged yachts, which carry most of the time the fore and the main - there, changing the rake changes the tendency to turn leeward or otherwise, giving more or less pressure on the rudder/helm, and changes the turning behaviour when going through the wind.
  2. Using the real wood species for a model usually does not work, because the grain patterns are too coarse. For a model some wood without visible grain is more realistic.
  3. Wow, that is a lot of money to sink into a kit ...
  4. Wow, this is serious competition in the field of micro-machining ...
  5. For flat chisels I would try to source some 2 mm square watchmaker's HSS gravers. They come in something like 8" length so that one can get three or four chisels out of them. HSS doesn't need hardening and tempering, just cautious grinding to shape. At times when one could buy with a clean conscience from Chinese sources, 2/3/4 mm HSS blanks could also be sourced on ebay. Dito. round blanks for gouges.
  6. I think this looks very convincing - the work of a stage and lighting director The problem of shadows on the backdrop occurs also in table-top photography. I have tried to circumvent this with back-lit translucent backdrops. However, this may not work for night scenes either. I like the character of the mechanic crawling halfway under the lorry, very well animated. Did you do this or is it a commercial figure?
  7. @Shipman, I am using either zapon-varnish or shellac solution. The former straight out of the tin and the latter I mix myself from shellac flakes and alcohol to a viscosity that seems adequate for the job. The zapon-varnish can be softened with aceton and shellac redisolved obviously in alcohol.
  8. For securing all ropes, knots etc. my preferred medium is dilute varnish or shellac. If something is not right, you can soften it with a drop of acetone or alcohol and adjust.
  9. If you don't have/want to show natural wood, you could also build up the keel/stems from several layers. The outer layer should be as thick as the rabbet would be deep and follow the outer rabbet line.
  10. A bit off-topic, but this here is probably one of the most advanced shipyards in Europe and a leading cruise-ship builder (not that I endorse these products, however): https://www.meyerwerft.de/en/technologies/optimized_processes/index.jsp I think there was also somewhere a video that showed their plate-cutting and welding.
  11. Perhaps Roger referred to the modern section building methods. Section building as such has been used since the 1960s, I believe, but later came CNC-cutting and then CNC-welding machines. Depending on how big the assembly hall and the cranes were at the yard, quite large sections could be assembled not by hand-welding, but using numerically controlled welding machines, which result in narrower and more uniform seams.
  12. Not sure that shellac over oil is such a good idea. Keep in mind that it takes days to months for the lineseed-oil to fully polymerise, depending on how fat or lean you applied the oil-paint. Until then volume changes of the oil-paints can/will occur. Shellac per se is brittle and a pure shellac varnish may crack. That is, as pointed out above, varnishing is normally done months after applying oil-paints and these varnishes are normally mixtures of different resins that show a behaviour more similar to that of polymerised oil-paints. Apart from the fact that indeed one can simulate wood grain quite nicely with oil-paints, I wonder why mix paint systems and use oil-paints at all? I think the wood planking can be simulated well with acrylic paints and then one can use acrylic varnishes to achieve the desired surface sheen. If it was me, I would either use all acrylics or oil-paint and a varnish from a reputable artists' supply house. Three different paint systems over each other calls for trouble, keep it simple.
  13. In general, avoid mixing too many media, such as acrylics, oil-paints and organic solvent-based varnishes. And respect the 'fat over lean'-rule Using oils over acrylic paint/primer is not a problem. However, you should give the acrylic time to cross-link and diffuse out the water, which takes several days, if not weeks, depending on the thickness of the layer. The 'drying' of oil-paints in reality is an oxidation process of the lineseed-oil. This takes time. One can speed up the process by adding 'dryers', which add as catalysts. Some pigments act actually as catalysts, which is why some colours 'dry' faster than others. By using solvents, such as turpentine, you reduce the amount of binder, i.e. linesee-oil, in the paint, which is the reason, why oil 'washes' dry faster. As long as this 'drying' process has not been completed, which also can take weeks, one should not apply any varnish. After all, the artists of old held the 'vernissage' of their paintings sometimes a year or so after completion. In any case, I would go for one of the classical varnishes for oil-paintings, rather than for other solvent-based varnishes. As long as you stay within the same paint-system 'intermediate' varnishes in general are not a problem, but the same precaution re. 'drying' times apply, when using such 'intermediate' varnishes.
  14. Brian, to add to your arsenal of ideas: - styrene sheet with seams engraved into which one lays fly-tying thread - there are also commercially available 'weld-seams' as decals, but their scale may to large (1:35) and they may be rather pricey for such large hull.
  15. Just read the (reconstructed) CV of a master born in 1706 on the Amrum island (North Sea coast of Germany), who first put to sea at the age of 12 - most men of that island were mariners, as agriculture was poor and not many other occupations neede. He sailed out of Hamburg and three years later was captured by pirates from Algiers and sold as a slave. After another three years he was bought out of slavery and then moved up the ranks, eventually becoming a successful master in the triangular trade between Denmark, West-Africa and the Danish Westindies. So successful that he could retire as the richest man of Amrum at the age of 42. In less demanding environments, boys would not enter the service before their 'confirmation' (i.e. the protestant version of the First Communion), in the 18th and 19th century around the age of 14. That was the age when one would leave school to become apprenticed. As noted before, boys from very poor families would probably lie about their age ...
  16. MDF is rather stable as long as you don't soak it in water. So it is important that in particular the edges are sealed or not exposed. Bulkheads from MDF shouldn't be a problem, as the planking/plating will cover the cut edges. I gather the boat was welded? Perhaps covering the wooden planking with thin Bristol-board would save a lot of time in filling and sanding and the individual plates could be simulated that way. Otherwise, I used copper foil (as in copper-sheathing wooden ships) to simulate on-off riveted plates. Could be used for welded hulls as well. The welding seams could be simulated by engraving or embossing. Modern boats like this are not my subject area, but I am curious, how you will tackle this project.
  17. On the glass on ships, I always wondered, whether they kept the glazed windows at sea (and in battle, of course), or stored them below. Glass still was an expensive item in the 17th century. In fact, often Muscovite was used instead, which is a natural mineral and can be split into very thin sheets. Muscovite is much more elastic than glass, but less clear. Today it is still used as high temperature-resistant looking glasses in furnaces and the likes.
  18. Half-cut away model showing a (non-working) scale steam-engine and boilers? These old steam-yachts are a lovely, steam-punky sort of crowd ... some years ago, we happend to be in Nice, when a childhood friend of my wife called her to wish her 'Happy Birthday'. When she asked, where he was, he said "in Nice" (he works on 'super-yachts' as an IT engineer). When we asked, where to find him, he replied "that's easy, just look out for the biggest boat in the old harbour, where normally cruise-ships berth". However, in spite of the 'glitz', helicopter and all, I found the old 1920s steam-yacht on the other side of harbour much more classy and desirable ...
  19. Keith, perhaps you should put a cheap tablet or something like that to the model that shows images of the path and also images of those things inside that are barely visible? Otherwise, I can only echo, what the others have already said 👍
  20. I am not so familiar with 18th century rigging practice, but brails on the mainsail (no. 24 and 25) are definitively needed to reduce sail area quickly. However, you need to decide, whether the vessel would have had a standing or a lowering gaff. If the boat has a lowering gaff, it probably does not make much sense to lead an other running rigging, such as bulins or topgallant braces towards it. I would also doubt that there have been bulins (21/22) or even topgallant braces (10). On British cutters of that period the topgallant braces were led towards the end of the jibboom and belayed at the spill. The topsail- and topgallant yards may not have had braces at all, as the were set flying (at least the topgallant) and would come around together with the main yard. Aren't there any backstays for the topmast? Just having a stay would not be enough to steady it, as the main force is from behind and sideways.
  21. Could you please provide some background information, for instance what model you are talking about? Then people can give some more specific advice. The rigging consists of many different sizes of rope, depending on their function.
  22. Grant, it wasn't meant to be a 'lesson', just some observations. If sources tell you that the binnacle had (at some stage) Kelvin balls, that's it then. Ships change over time, so it is extremely difficult to represent a particular ship 'correctly'. Your sources from different times may show you certain features, but unless you have corroborating sources, you cannot know whether at another time the same features were present. So you may indadverntely create anachronisms simply because you don't know any better. That's the fate of any modeller. Contextual historical information, say the date of the Kelvin patent, can help you bracketting the time, when certain features could be present on a particular ship.
  23. Would be interesting to read the technical information sheet for this. From the description I would guess that is is a pure acrylics solution, no pigments and fillers. In this sense it is a primer, rather than a sanding sealer. How does this stuff sand? My experience is that acrylics are too soft to sand well or at least one has to let them cure for weeks.
  24. Nice work on the binnacle/compass! These 'Kelvin-balls' are there to correct the 'deviation' (horizontal deflection) of a compass caused by iron elements used in the construction or of iron articles in the load. Ther is also a vertical deflection called 'inclination' that is compensated for in later magnetic compasses. On road-steads there was usually an area set aside so that ships could steer a full 360° circle while making compass readings and observations of two given landmarks at the same time. This allowed to plot the 'deviation' of the compass readings from the theoretical readings. This plot was used to adjust the 'balls' in order to minimise the deviation. In the absence of such adjusting features, the 'deviation table' could also be used during a voyage to correct the course. I am not sure though, whether a wooden sailing ship, such as HARRIET McGREGOR would have had at that time this kind of correction features. There were older correction features, but they are not as prominent.
  25. Shellac is also a traditional cement used by jewellers and watchmakers. The latter use it in molten form to stick (temporarily) metal parts together. Dipped in alcohol, the parts separate. A while ago, I got myself shellac-flakes and dissolved a lot of them just in a few millilitres of alcohol to make a cement with honey-like consistency. It grabs quite well, but it takes quite a while for the alcohol to evaporate. When working with it, the 'open' time is quite infinite, giving you lots of time to adjust parts. As any excess can be wiped off with a brush dipped into alcohol, it makes for a neat cement.
