Craigie65
Everything posted by Craigie65
  1. Great to hear from the man himself! Some interesting insights to the hobby. I hope this helps Chris reach a wider audience.
  2. Glenn, For those of us who don’t use Facebook, do you have a link to a Justgiving page?
  3. Glenn My thoughts and prayers are with you, your wife and family. Good luck with your fundraising.
  4. As for stealer, the trick is to have additional planks that are wider than those provided in the kit. You can then have a wider plank at the stern. I have a stock of pear strips from Hobbymill.EU. The owner, Vahur is a sponsor of this site. Worth a look if you are going to build more?
  5. Hi Robin, I have the same difficulty with these bulkheads. For the stern the planking runs all the way to the keel, so for bulkheads 13 and 14 the measured length includes the area to the keel. For bulkheads 15 and 16 these only have a few planks running from bulkhead 14. Therefore I just use the plank width measured at bulkhead 14. You may need a stealer in this area. For the bow, the 1st bulkhead is usually similar to number 2. I think of it as part of a sphere with bulkhead 1 at 90 degrees to bulkhead 2. Hope that helps! good luck
  6. Lovely! Well done for persevering and overcoming the challenges you faced. I will follow along on your Speedy build.
  7. Wow, you certainly churn these out. The finished product always looks first class. You need to share your secret!
  8. Good progress Robin. Ratlines are time consuming. Watered down PVA glue is fine for securing the ratlines. I like to get them all square and evenly spaced before committing to glue. Just protect your deck from any splashes!
  9. Your approach to the tuck worked well. Looks good with a coat of varnish.👍
  10. Sorry to hear about your broken fingers, hope you are on the mend. You are on the right track using an electric drill/screwdriver to help shape the yards. Just take your time avoiding putting too much pressure on the yard arm nearest the screwdriver chuck. Once you get the taper close to where you want it, just proceed by hand using sandpaper.
  11. Andrew, Sorry to hear about your health, hope you are on the mend. Please take care of yourself. I am sure the warmer weather is just around the corner, and you will be back in your shipyard soon. 😁
  12. Really taking shape now, Robin. We have all been there with snapped drill bits. It’s fun digging them out 😡 The fine bits cannot take a lot of lateral pressure. Apparently HSS bits are stronger than the tungsten carbide ones, although the former are more expensive. You should be able to source suitably sized walnut dowel to replace the stock you used on the pumps.In the UK Cornwall Model Boat stocks various sizes. I am sure you will find somewhere closer to home.
  13. Glenn, Ouch!! Paul’s tubing idea made me think that you could “fish” the mast and call it a battle damage repair!
  14. Excellent job on the second planking, nice symmetry to your work.
  15. Andrew, Learning a lot from your build. Those really are mighty tight curves, hope you have enough spare planks to complete. Would be a shame to hide the excellent job you have done with the planking under a coat of paint.
  16. Thanks Andrew, Anything that makes planking easier is an asset! I am a bit of a sucker for tools, sometime I forget it is the model that is more important. If you are anything like me you will have a drawer (or 2) of little/unused tools.
