kenr
Everything posted by kenr
  1. Hi Slog As discussed I have taken some pics of my Endeavour bowsprit Hope they help Regards Ken
  2. Hi Rich Well that is a major step over and done You will be looking forward to Monday AM Regards Ken
  3. Hi Slog I just went back and had a look at my Endeavour I sanded the bottom of the BS flat. If you think it will help I can take a picture tomorrow and post it That will be more fun than doing housework Regards Ken
  4. Hi AJ Good work I think most of us have fitted strips of wood between the bulkheads where need , to provide all around support for the deck fittings Regards Ken
  5. Hi Daniel Regarding Vorons post. If I look at one of the the PDF,s it is back to front ( ie in reverse ) Is that what you intended ? Regards Ken
  6. Hi Larry I too am glad you are back. Alistairs detailed reply will help a lot At the end of the day gaps will be filled and the hull will be painted. So don't stress about it Regards Ken
  7. Hi AJ Going back to your comments about the Humbrol paints I sand off the scorch marks and always apply white undercoat before putting the top coat on The top coat could need 2 or 3 applications Regards Ken
  8. Hi AJ I think most of us have had that gap problem Your solution is a good one Regards Ken
  9. Hi Ron I,m with Alistair I have gone back and had a look at my Caldercraft Endeavour 140mm to 150mm looks about right Regards Ken
  10. Hi Bill I will also book a seat for your build It will be most interesting to watch you use your considerable skills to build a model tall ship Regards Ken
  11. AJ The paints I use are as follows. Red Humbrol tinlet #60 Yellow/Buff Humbrol tinlet #103 I always undercoat first with a waterbased product from the paint shop ( white ) Black is a small can of flat black again from the paint shop And the green. The plans say "dark green " so again to the paint shop I pick a dark green from a colour chart and get a test pot made up The test pot is big enough for me to use a brush which is about 1.5 inches wide so I can paint quickly and smoothly Hope all that helps Regards Ken
  12. Hi AJ I do have a build log although it is not updated very often at the moment It is called " US Brig Niagara by Kenr" Regards Ken
  13. Hi Ed it will be good to follow your build too. I completed a Niagara a few years ago. Most of the masts and rigging where smashed in a house move Rather than trying to repair the damage I bought a whole new kit and started again The theory being I would do a better job second time around Time will tell Regards Ken
  14. Hi AJ Fair point . I went back and measured the width of the planks I used and came up with 1/8th Does that sound right ? Ken
  15. Hi AJ I cant see the transom planking size on the plan either But , in the instruction book ( page 16 ) under the heading Planking the Counter and Transom It says " Cover the counter and transom with 1/32 planks " Hope that helps Regards Ken
  16. Hi Tony Regarding your comment about the single deck Are you planning to put in a false deck?Regards Ken
  17. Rich I,m with you I would not put the house up for sale and till you are 100 % certain about the job and you have a start date Regards Ken
  18. Hello QA As far as I know MS does not have a distributor in Australia either, so we order direct from the US paying by credit card then airfreight to here The lack of a local distributor is really not a problem The freight cost is generally offset in that we don't pay US taxes and Australian GST Regards Ken
  19. Hello Ed Well that does sound like good news However it could well be a long and careful process to get the relationship back to where you want it. Regards Ken
  20. Hi Rich Actually you might be able to help me with my next project The blocks for the gun tackle. Each gun has 2 single and 2 double blocks , if as you did, leaving out the in haul tackle I am going to drill a hole in each of those blocks and fit a hook Does that sound right ? Regards Ken
  21. Hello Everyone I am posting a quick photo to show I have been doing some work on my Niagara As you can see I have been putting off sanding and painting the hull and working on the deck fittings Now that it is warming up here I have no excuse not to get outside and finish up sanding the hull Regards Ken
  22. Hello Mate Well done. So where will you be moving to and what will you be doing ? Regards Ken
  23. Hi Rich Taking a short term contract sounds like a good idea Brings in some cash and keeps your hand in as well as exposing you to a potential employer Regards Ken
  24. Hello Steven Yes, welcome to the Niagara Club Floyd and Rich have given you a very sound starting point From your pictures you should be very proud of your fathers workmanship. So don't hesitate to ask and join in Regards Ken
