popeye the sailor
  1. I ordered some decals last evening............and I also found out that I can't use the subject 'old Glory'. I'm going to have to decide on another premise. I neglected to book mark the info I found.......I'll tell yas why when I find it again.
  2. thanks gents........I never knew that there were so many.........then again, that they even existed. I saw them........but the wild paint made me thing that it was someone's idea.......it wasn't real. I'm not into building models that don't exist, although I have built a few because of the novelty aspect they possessed. you buy a model and look up the subject, only to find not a shred of evidence that there was an actual plane or vessel. I did that with the Nordkap........I found squat on her. but I was told here on the site, that there was such a vessel....a person who is quite knowledgeable.......I had no cause to disbelieve him after looking up the Buffalo Bill........I quickly found that it was nothing more than B.S. the assembly ship is interesting.....there is a creative value to it. the planes themselves aren't from military blueprint........they are painted by the squadrons they represent........'field paint'. the planes are older planes that through repeated repairs and age, are given an entirely new use instead of scrapped or cannibalized. strange to hear that after a war's end, the military would destroy pieces that they don't intend to bring home. from what I've read about PT boats, very few were actually brought home....the rest were scuttled or burned. these planes were stripped of armament and other equipment {which I may have stated earlier}, but a few of them possessed just enough to get home on. there are times that the mission took them close to the action {I'll have a few guns on mine}. I'm almost ready to get some of these parts assembled.......just a bit more to go thanks again all........thanks to Lou for pointing them out
  3. these wooden kits are interesting though.........although sheeting hulls takes some getting used to I have the Hasegawa kit of the Missouri in 1:450 scale. plastic, but likely not as much fun, as your having I subbed wood sheeting for the plastic stuff Dumas supplies in their PT boat........I found it a lot more malleable. perhaps pictures online may help you form a more perfect keesta. {stern looks from the audience}
  4. after a bit of 'do this and do that', I finally got to remove the masking. I can say that covering over some of the imperfections with these colors is a bit on the hard side, especially if they are darker than the paint covering them. I need to wait anyway.......all this needs to fully dry before trying anything. I did in a couple of areas and the paint became active........ if I can't touch it up with a brush, I'll need to remask and spray. where I masked over the gray on the fuselage, there were a few spots that showed the base plastic.....I've already touched these areas up. the main thought was how the stripes will run.........either differently on the fuselage and wings, or all in the same direction. I think the latter will look better. when I was removing the rudder parts from the masking, a tip on one of the rudders almost broke off........I patched it with cement and will let it dry. I also painted the gray areas on the inner rudder parts. ....and here are the rest of the parts to complete the color scheme still a lot more painting to go
  5. glad you mad it through OK........I've been seeing the news and it don't look good down there. we got a lot of rain up here from her, but it wasn't nothing compared to what you folks endured! now lets hope that help comes as fast as the storm did
  6. not so much a stranger this time...........catching up was a lot quicker really nice job with the dio.........the pool looks great and your small set up shows how good it's gonna look! I got back into airbrushing when I started to build wood ships........too much surface area for a brush alone! yup...practice will make all the difference. the more you do, the better your gonna get! fantastic job so far my friend.......keep up the good work!
  7. I've seen those solid wood model kits........scared to pull the trigger but then again, I was daunted with wooden boats....and that was silly. the person who I got the Nordkap from also gave me a PT boat kit by Marine Model Co.......solid wood hull. I haven't started it yet, but the hull is already precarved. love to see the 1:28 B 17....bet she is a monster! looking forward in seeing your next project...the A 10 sounds cool
  8. thanks Phil for the kind comment and thanks to all for the likes more has been done in the paint dept. I had a though to paint the top surface in front of the cockpit.........I was going to do flat black for this, but I decided to do it in the bomber green. then I moved on to the rudders and stabilizer. I was reminded that I only painted one side of the rudder flaps.....so I still gotta do that. the stabilizer is now masked for painting. this tape that I'm using is Testor's pin striping tape........comes in three different widths. it is a trustworthy tape for me the outside surfaces of the rudders will not be striped, since they are now flat blue....just the inside surfaces. the bottom sections under the stabilizer, will be done in light gray, like the underbelly of the fuselage and wings. the fuselage halves were next to get the masking job. the cowls will be done in flat white, later to get their decoration, yet to be see ...and then it came to the paint by this time, I had to leave to take the admiral to her doctor's appointment. now that I'm back, I can remove all the masking and see what it all looks like. more on the process soon........reminds me of the scene where the doctor remove the bandages from Joker's face, in the first Batman
  9. it's been a busy couple of weeks.........work has been a bear.........celebrated my birthday on the 31st.......replaced the right front axle and lower control arm in my son's car, as well as all the lug studs on the left front. he took it to a dealer to have the transmission replaced {a month ago} and they over torqued the wheel lugs, ruining the left front rim. he bought a replacement rim the other day, per my suggestion. I went to take it off and two of them were loose again, as well as one of them being seized. I got the tire off by snapping the lug with a breaker bar and length of pipe, for more leverage it's bad when you can look at the lug holes and actually see the damage! the right front was over torqued as well, but he hasn't had to retighten them {he stopped by the house one day complaining of a noise in the left front........that is what we found}. it's a long story.........sigh all the rain we've had.......I also got to mow the lawns finally........the jungle had returned. one issue I've run into with this project, is that when I repainted the bottom pan, I removed the masking, only to find that the adhesive had stuck to the part and not on the tape . true, I left it on for a couple of days, but the other masking tapes I have hasn't done this. I'm not sure, but I think this is Tamiya tape. so now I want to remove the adhesive so I can repaint the undercarriage. once I get it off, the black can be touched up and I can move on with it. I am in the process of testing the tape. I stuck some on a wing and will leave it a couple of days, to see if it is just a time thing.........but I think the introduction of paint and paint thinner may have caused it. we'll see.
  10. WOW! you've made some really good progress ! very nice indeed ! a couple of comments I'd like to add is that the fuel tank is where it is for a good reason. fuel systems relied on suction for mechanical fuel pumps.......pressure for today's cars. the early systems likely relied on gravity feed for fuel delivery.....putting the tank over the engine would certainly accomplish that. ....and yes.....most batteries were located under the driver's seat of floor board. the master cylinder is probably there as well. my brother knew a guy that had an old American staff car, and that was how it was set up.....except it had a mechanical fuel pump...the tank was located in the rear undercarriage. good you held off on some of the rust and dirt....now that the body is in place, you can go mental but it does matter though on how long it's been out in the 'wild' ....could have been a new addition to the pool. great job......looking spectacular!
  11. great idea with the spoons.........never though to use such things love the sheen factor of the paint........the metallic colors especially .
  12. awesome job! has the look of burnished aluminum looks good on the stand too! got any others?
  13. ohhhhh, I dunno, I'm just a wingman something about those big birds......... hey.........whilst I'm here, I may as well post a few update pictures. I went a bit further on the paint work. first I masked and painted the blue areas on the wings, fuselage and rudders. one thing I noticed is that the wings don't possess the same panel texture and rivet detail. odd given the fact that the Atlantis and the other Revell kit are identical....then again, they come from the same molds. there are some minor flaws with the paint, but I will go over them once all the colors are on. after I gave the blue some time to dry, I began masking the wings. I just followed the panel lines as a guide. the ailerons were taped in place, so they could get their portion of the striping. I did the other wing by eye, keeping with the spacing of the above wing. I didn't do too badly.......I think this is some pretty good tape.......comes in three different widths. the tape I wanted to use.....I can't. I used it on the Futura....and I guess the thinner is the culprit.......but it left the adhesive on the part I masked up. it's been a task to remove it.....still more to go. once I made sure that the tape was firmly pressed down, it was off to the paint booth. the admiral wanted to go to the store.........so I had to hold off on further work. when we got back, I removed the tape to see how much {if any} crept underneath {I get mixed results}. I was happy to see that only a few visible imperfections occurred. real tiny ones I'm not concerned with....but there are some I will touch up. the rudders and stabilizer will be next. more soon
  14. thanks! I still have the Atlantis B 25........ hoping that it comes out as well......surprising cutting out the side windows was good too.....adds more to the model. the window maker worked well in that respect. thanks again everyone.......glad you enjoyed the log, given the confusion
  15. no different than automotive........I've got tool that I've only used a couple of times. stuff I'll probably never use again. learned plumbing from my dad..... ..came in handy when we owned our own home. ....and if our landlord keeps dragging his feet, I may have to do something here {pipes down cellar are look'in scary } congratz on 44 years!
  16. thank you all.......it is an interesting rabbit hole. surprising that the kit built into as nice a model as it did, considering. I still wouldn't put the 'dinty' on it though...........unless your looking for a good challenge, or you just want something to practice paint methods. I think it would have looked better if the glass frames were painted, but I didn't care for the raised framing being on the inside of the glass. on the outside, it makes it easier to mask off. when you see how the landing gear is set up on the Warbirds kit, you will see the reason why I modeled them like this. the way I have them on this model is perfect in showing the gear in the up position......gear doors are closed and all you can see are the wheels. I'll have to look around and see if I can find another book on the subject. having such an obscure timeline shows just how secret the KG 200 was. the book has more information on B 17's.........the majority of the captured planes didn't survive. a few did get retaken. I did look into the Atlantis site, at the Pacific Raiders kit.........they had only the decal sheet to offer. to me, the Buffalo Bill decals sheet didn't look that good......chances are the Pacific Raiders decal sheet would look equally as bad.......cartoonish like I should have something on that model soon.....thanks for the kind comments and glad that you found this interesting to follow I'll see what I can come up with for #3.
  17. it would be easy to come up with a sheet of dot decals the paint work would be enormous though.........not to say that what I have planned isn't. I'm giving the white a chance to dry more, before I go to the other colors. there are quite a few to choose from, but finding decal sets for some of them might be tough. there is.....still the MPC kit, cheap enough to toy around with.............I might still be able to get one glad your looking in
  18. after the props were touched up, they were added to the model. this was the last thing to be done......the model is finished. as mentioned, I had to make a couple of things to accommodate the decals to a smaller scale, but I'm happy with the way it looks. I'm even happy with the wheels and how they are tucked into the wells........if I do this with the Pacific Raiders model, I will need to make a stand for her. the pictures do speak for themselves, so here they are. here's where I noticed the decal error...... I saw pictures where the area under the wing root was painted out........they supplied the decal, but didn't show it in their diagrams. the fate of Sunshine is not really known. she lost two engines and landed in Venegono in 1944, only to be detained by the Italians. the plane and crew were later handed over to the Germans. the crew was sent to Stalag Luft I, and the plane received two new engines and was flown to Germany for testing. it was then delivered to the KG 200 and possibly given the code numbers A3+FK. the plane would latter be used to infiltrate and monitor RAF nocturnal bomber chatter. at some paint the marking did change a little, but the nose art was kept intact. the plane seemed to disappear, until Jan of 1945, when a plane with the numbers A3+FK was shown to have logged in at Wiener-Neustadt air base. no further information was found until the end of the war, when forces stumbled on the wreckage of a B 24. there were no discernable markings on the plane to say either way, if it was Sunshine, but the fact that she was never recovered, would suggest that she didn't survive the war. Sunshine was the second B 24 to fall into German hands....the B 24, Blonde Bomber II was the first. information points that she never entered service with the KG 200. thanks to all for sitting through the debacle for my second installment....I'm sure you folks were confused. the KG 200 book lists many planes that were used by the Germans. from Mustangs and P 38's {only two were known of}, to aircraft of the British and French air forces.........one never can rule out that there may be another installment.......#3 thanks again for your interest and support
  19. I shouldn't bother to show them........but I took them while I was decaling her, and there is sort of a candid value to them minimal trimming was done to the decals........for the rudders, the decal set supplies patches in which gives the impression that some markings have been painted over. I wasn't going to use them........I was simply going to paint the areas over with a lighter olive drab, making them as large as needed. I later opted to just overlay the swastika partially over the lower decal patch { the upper patch, the number, and the swastika is one complete decal in itself}. I did note that the port side was a little crooked....I have since fixed it. yea.........I vowed not to do anymore at my desk........old habits are hard to break the plane was supported by the lamp.....propped by the tail guns. all this while the glue was drying. the stand really doesn't do what it was intended to do. the prop job under way
  20. I have seen B 24's that still had the armament, as well as the B 17 pictured above. I might just add them so the parts aren't added to my spare parts box.......I seem to be massing quite an array. just the nose {if any}, the tail and maybe the dorsal. they do fly reasonably close to the action before turning around.......be good to have some teeth, just in case I've book marked a few more sites pertaining to the B 24, even one that gives out free plans for large scale models. you have to become a member to get them, and I'm sure there is a fee in there somewhere. I did take a few pictures of where this model is at the moment.......you've seen the Chromate green on the visible inside surfaces.....I've done a bit more. the bottom part of the fuselage was painted with the med gray, and then later masked off to paint the white upper section. I had to do two coats of flat White...gosh darn ghosting was quite abundant. I will then mask off for the blue.......and then for the red striping. the upper tail parts and the ailerons........the rudders you see are waiting to be painted blue. the other halves are as follows........only the rudders themselves will be totally white, but I think I should do the lower part of the inner surfaces with the med gray, which won't be striped. I may have to correct one of the rudders......they are both facing the same way....kind of like painting two lefts >correction noted< the fuselage and upper wing surfaces have also been painted......the white was so stubborn. I just hope I didn't lay the paint on too thick. the field on the wings that will be blue is fairly large.......it will fit in conjunction with the roots of the fuselage, which will also be masked off for the blue. I'm either going to order some stars, or I'm going to have link my computer with the home printer....I think I just need to make it the default printer, now that mine has been uninstalled from my computer. I have other images that I need to look up. white decal paper is going to be the rule, since most generic printers don't print white. more to come
  21. so.......the trilogy of Sunshine has been resolved. the props on the original kit I started with are being painted, and that will finish the model. the Pacific Raiders plane will be move over to the Atlantic log and will be done as a generic bomber, unless I get other ideas {I usually do }. this log will be devoted to the Warbirds kit........which led me to wonder.......what to do with this model. there were no decals with the model when I got it, and even if there were, they might be junk......just like the Pacific Raiders kit. I thought of two possibilities.........one choice would be a coastal patrol plane for the RAF.....the other alternative would be an assembly plane. both of these choices would be a pleaser for Lou {yes.....I do like the ideas you've given me in the past. I leaned more towards the assembly plane though, even though I have decals for both ideas { I should by now, don't you think?!?!?!} there are a few decal sets out there for assembly ships.......but I want to stay low budget and some of the paint schemes are a real daunter. one in particular came to mind..........sort of an American Flag motif. first.......I thought of a white upper fuselage and wings, med gray bottom. red stripes will run along the upper fuselage, with stripes from wing tips to fuselage. starting from a section of wing to the root and the area of the fuselage, will be blue w/ stars. the outer rudders will be blue....inside will be white and med gray.......rudder flaps will be white and red stripe. the stabilizer{s} will be white and red stripe, running the same as the wings second .......will be basically the same, but all stripes will run on the same direction as the fuselage. a third choice......... will be the same, but the fuselage is done in stripe bands around it, rather than along it. sounds like a head bender.........I believe there is a B 17 done in pretty much the same way.......the B24 I saw though looked like the stripes were like lightening bolts { a little too crazed}. I've seen the red 'n gray stripe in drab and yellow too... it will look somewhat like that...... good that I looked at these........I was wondering about the nacelles. from what I've read, assembly ships didn't have armament.....the planes were stripped of unneeded equipment. this one has them though , although I don't see the presence of belly guns. I will call her " 'ole Glory" and will likely be making the decals myself, if I don't have anything on hand. I won't be specific on a bomb group, unless I can cobble something together. I already started the paint trilogy............oh, did I say that I hate white!!!!!!
  22. actually, the more critical time was landing. the pilot had to be steady, because too much pitching from side to side, would allow the wing to hit the ground.........and that could be very bad. some did not end well. there were structural issues down the road with the top wing strut mounts rotting. this would cause the plane to lose the top wing in flight. I think it happened to Lothar, the baron's brother. head injuries and engine problems added to the cons of this aircraft, and when the D VII rolled off the assembly line, all orders for the Dr 1 was canceled.
