Jeronimo
Everything posted by Jeronimo
  1. Thanks to all for the comments. The window openings and gun ports 4mm shifted to the bow. It was important to me that the carvings have been preserved throughout. Karl
  2. Final assembly of the carvings after the reconstruction work on the window openings and gun ports. Karl Part 13
  3. The dimensions of the carvings made a modification of the window openings and gunports are absolutely necessary. My mistake in the frame construction or the finished size of the carvings, no matterit müsst be changed. Karl Part 12 Google Translator
  4. The mirror, as well as on both sides window bay window with its carvings I have already finished, with the oriels still missing carvings / figures attached later. I have decided not or color this model, or only black/brown wood stain for the moldings and golg color for the numeros crowns. The model will look a bit different from really beautiful and colorful models of Maarten or Doris, etc. First off all, I will start with the interior design of the model. Karl Part 11
  5. Many thanks to all for the kind comments and likes. Karl
  6. Hello Guy. The original Italian editional of the book with the plan drawings is better than the AoS book. Karl
  7. Small update. Openings of windows and gun ports in the side walls. Karl Part 9
  8. WOW!!!! Model building at its finest. Karl
  9. " LE CENTAURE 1782" Scale 1/36 April 2015 I started with the construction of the model and soon realized, "that is a big think". I wanted to present it as a cross-section model with complete interior design, in the style of my model BONHOMME RICHARD 1779. On some whim I finished the construction Oktober 2016, all nicely packed and mothballed. I still want to show the images of the construction protocol, and have the hope that it will eventually be built further. The sequence of images extends over a period of eighteen month in the time-lapse mode. Karl (Google Translator)
  10. With 0,6 mmdrill holes drilled in the wood, filled with darl wax and rub with a soft cloth. Finished Karl
  11. Hello Johann. Perfect work. Gratulation zu solch einer Arbeit. Karl
  12. Hi AMALIO, very good and beautiful work. Karl
  13. PART 6 Hawse Timbers installed, frame scaffold ground inside. Karl
  14. HAWSE TIMBERS / CANT FRAMES after several attempst I was able to produce and install the Cant Frames. Karl
