Everything posted by Some Idea
Great advice there from Jaager but I'll add a little if I may. The TX which is a fantastic motor is only available in 115V so it cannot be used in the UK without a transformer. The SR may seem the cheaper option but for ship building I have never been able to stall the motor on mine as the torque is over and above what I need. I have also found that I do not need to awl to make starter holes. The reason being is because I can put the drill bit where it needs to be and start the drill at such low RPM using the foot pedal that the bit just does not drift. This is the best thing about the foot pedal - the starting RPM is governed by the user and not the tool. As for the router made by Stewmac - goodness me how nice does that tool look!!! I've had this on my radar for quite some time but it will have to wait.
Hi Kevin I've been using a Foredom tool for quite a while now and its not comparable to any high speed drill. The torque and slow speeds just give you the accuracy and control that you want. So what have learn't from my ownership? Firstly I no longer hang my Foredom motor up like jewellers do. It's far too restricting and I've swapped to a desk mounted base as I can literally put this anywhere that I want. I have found this to be a much better solution and I would recommend the SR motor with a foot pedal control with a key drive shaft. Next the main hand piece is a H30 which takes drills up to 4.0mm and will just about do 95% of all of your tasks. Foredom also make a beautiful drill press that the H30 slides straight into and does a fantastic job. I also have another hand piece which is the H28. Its about half of the diameter of the H30 and its much smaller to hold in your hand. Foredom make some really nice micro chucks that fit nicely into the supplied collet with this hand piece. I hope this has been some help - Oh also buy from a registered Foredom dealer as there are so many rip offs out there that are not as good as the real thing Cheers Mark
Hi all - Some more done on Le Rochefort and thanks for all of the nice comments and likes. I fitted the next plank down on the port side to frame the cut outs. It was a bit tricky getting it around the stern as this plank is still 3mm x 10mm and its a very tight bend. It also has to fit into the rabbet but I'm really pleased the way its turned out. The bow was a lot easier to fit and I also placed the iron and wood nails as before Next I marked out the cut outs on the port side - Don't laugh but I've been putting cutting them out for nearly two weeks as I just couldn't do it!! Anyway I've done it now so no going back. The reason for the small opening at the bow is because there is a small deck on the inside and the beams need somewhere to sit on the frames. So the next job is to finish the ceiling which is going to take me a while as I need to plan it out first. As soon as I have something to post I'll get it on here. Cheers Mark
Just my thoughts on this and I'm new to building frames too................. Firstly accuracy is the most important thing as cumulative errors make such an impact over the entire hull. So as suggested you need some digital callipers to make your measurements exact. Secondly use a hardwood such as Costello or Pear wood as it's easier to be accurate as it holds an edge. I didn't really understand this until I used it. Thirdly the bevels that are marked on the drawings show the exact final shape and it's easy to just shape the frames to these lines......however the chances of anyone lining up 50+ frames to the exact alignment are slim. So use them as a guide and leave some on for final shaping. Forth - I use permagrit tools for rough shaping too and have found them to be excellent for this job. But they do leave deep score so again leave something to work with to make your frames look pretty. Now that I've had a go I prefer using spoke shaves. Finally - building a Pegasus as a first plank on frame build. That is one hell of an ask as it's going to be an epic build which will take years. I've started much smaller and I'm happy with the challenges my little POF build is throwing at me. Good luck and please keep us updated as I'm in on your build 😀
Jim Byrnes Thickness Sander Operation Tips
Some Idea replied to ChrisLBren's topic in Modeling tools and Workshop Equipment
Just seen this thread and I used to have the same problem when I first got my thickness sander. A few years later and I now know that it was just the way I was using it and not being familiar with its use. So here's what I do - As soon as the wood being fed through pops out on the machined side I put my thumb on it to keep it tight to the feed table. The reason I used to get dips was because I allowed the wood to raise slightly off of the bed. I feed through by hand using a constant pressure on the sanding drum and let the drum do the work. I only use a feed through stick at the very last moment - I also use the widest stick that I have to keep the piece square to the sanding drum. Also a 24" piece creates a lot of weight at the end of the sanding run as so much of it is unsupported once machined. Just use loads of thumb pressure to keep it all flat and you will get the piece that you need. Also as wood tends to cup - swap the plank around end to end and and turn it over often. I have found that this method gives me the precise results that I want time after time. I have removed 3mm in thickness with no issues at all except for the painful loss of so much great wood to saw dust!!! -
ancre Belle Poule 1765 by j.guydal
Some Idea replied to j.guydal's topic in - Build logs for subjects built 1751 - 1800
Hi I'm very late to your build but I've just read through your whole post. What beautiful work you do - I'll be following from now on and congratulations on such a lovely ship. -
NAIAD 1797 by Bitao - 1:60
Some Idea replied to Bitao's topic in - Build logs for subjects built 1751 - 1800
Beautiful work mate and I have to agree - this ship deserves to be displayed in a museum! -
Just a small update The last plank is now in so the strake below the whale is complete. I've also placed the iron nails and tree nails in each strake too. The iron nails should be 0.75mm to be at exact scale but I downsized them to 0.7mm as this was the only size carbon rod that I could get. I did try a test piece using the 0.8mm rod that I already had but they looked way too big. The tree nails are 0.9mm and were made using vaddoc's technique utilising a needle and drill press - although I used a mill. The reason that the carbon looks a bit battered is because it is. I like to use a small hammer to make sure that they are correctly home. The results are ok - The nails look blacker than they will as the sanding makes them shiny. Once the matt shellack is applied the nails will go dull and the wood a darker shade. The tree nails just blend in really well and once again the shellack will make them just slightly more visible. So now the hull is much stronger I can proceed with cutting the frames away on the port side to make the interior visible. Its not something that I'm looking forward too but its got to be done. I'm also going to run another strake on the port side which will just frame the cut outs. I think that this addition will look nice! Mark
I'm still breathing - I never realised that building model ships came with a care package - but I'm grateful 🤣
- 1,132 replies
Fantastic video Kevin 👍 I just mentioned to my wife that from now on I'm going to be sitting in front of the TV making tree nails.........she mentioned something about "over my dead body" but I think she really meant - no problem Mark you just carry on fella 😜
- 1,132 replies
ancre Le Gros Ventre by ChrisLBren - 1/36
Some Idea replied to ChrisLBren's topic in - Build logs for subjects built 1751 - 1800
Hi Chris I've just been reading your thread and your work looks really nice and accurate. Good luck with the restart and I'll follow along too 👍 -
As they say - if at first you don't succeed 👍 Take two - I marked out both port and starboard sides this time as I was feeling a bit more confident. I also started by using the more accurate angles that I learnt from my first attempt. I also found it a lot easier to make them if I cut them to near enough their final size. Here's a comparison for my first go against the second attempt. Having less material to remove and a smaller contact area made the job a bit easier to see. And now both sides are on!! When you look at the results it doesn't actually look like much of a job but I bet there's about 6 hours of gentle sanding to get these to fit. They are a bit rough at the moment as I need to fit the plank below to get the final shape. Another job completed Cheers Mark
La Palme by Tobias - 1:36 - POF
Some Idea replied to Tobias's topic in - Build logs for subjects built 1501 - 1750
That really is lovely work - I agree this is going to be a great model 👍 -
Hi Kevin - I don't know if this is what you and Gary are looking for but here is a link that gives you the OD and ID of needles. I guess that this is a good starting point. It's only a guide as in practice I have found that using a 16g needle gives me 0.9mm tree nails? https://www.hamiltoncompany.com/laboratory-products/needles-knowledge/needle-gauge-chart I also run my mill at about 1000 rpm and have found this to be the optimal speed. If you get burning try dropping the wood into water for 5 mins before cutting the tree nails as this has also worked for me too. Cheers Mark
- 1,132 replies
Hi Kevin - I'm also trying this needle method and I'm getting great results thanks to the thread on here originally started by vaddoc. I have found that by taking his advice and using body piercing needles instead of hypodermic needle's the results are much better. Just google body piercing needles and you will see what I mean. Here's and example - Also I have found that just putting a 30 degree angle or there abouts on the end of the needles works great. https://www.ebay.co.uk/itm/252808332323?hash=item3adc8d0423:g:gfgAAOSwxEpYxC5Y&amdata=enc%3AAQAHAAAA8E%2BnzGprgTxciozHiEvBmvsFdXyWpfpBmyGeotGRlNuJL6v0ubwGUBsM%2B86sfQUiUGWDaSqhoMIFOErXTy86WmaGG%2BLBXBPfVNStypmSOx87Es3o%2BU2q5X0f9jl96uW9SC0AWN%2FYSlGTjcld34grvzItmoirt2gN60BKo%2FmDIAGZAKLqDLH7LgqBa2CM%2F7XXjCe%2BpOjBGVVSYfQRoym5X1d9mRoPY8vx%2Bm1pJn4AuNpNKqC%2B42hROWHrlxUTY%2BbK3VjJ9IhlGBuEMIxxBc31VapuRIjfopXurPuQWeQYA9wxg7A4TGyOZFRLWO3KC0%2Bz0g%3D%3D|tkp%3ABFBM9vSkytdg
- 1,132 replies
