Dfell
Posts posted by Dfell
  1. Hello - Ranger now completed. Sails all rigged, rope coils etc, barrels and now sitting on the Perspex stand.
    B3EB940A-6CC8-4272-A96D-E464E11E399C.thumb.jpeg.79c1c3693032ecd96d30b787aa5aec77.jpeg7F59D643-660A-4D41-A604-08CD3C06C93F.jpeg.adb6845ab3de0a927d991c7bcccc8acf.jpeg
    The name plates on the stand were difficult to fix on - very tight. One plate slightly split - not very noticeable fortunately.
    Thank you all for looking and the ‘Likes’
    Regards
    Doug
  2. Hello - small update. Main mast shaped / assembled with various eyebolts / blocks
    Must refer to plans for what blocks and where as the illustrated instructions book has blocks on all eyebolts which does get corrected later on in the book.
    Main Gaff and Boom plus Yard all shaped and ready with blocks attached etc.
    Sails next I guess. Again thank you for looking.
    Doug
  3. Hello palmerit - not sure if this would help I did mine in either 2 or 3 pieces and not one long length. This helped me to get either end good. Also sanded the top edge at an angle so it fitted neater / tighter to the one you’re butting up to. Guess you won’t know how good / bad things are until you give it a sand.
    All the best
    Doug
  4. Hello - a lot further on, various stages completed. The rudder with its 3 layers laminated and the brass hinges with brass pin heads for bolts added.
    The hull was sprayed with an undercoat with a filler and then Matt white.
    The red oxide sprayed on the lower half. Sorry missed taking a photograph of this stage. Next stage was adding the Wales having painted them black before gluing them on at the height as instructions. Same with the rails - have gone with a different colour scheme.
    Thank you looking and the ‘Likes’
    Doug
  5. Hello - small update. The outer layers of the Bulwarks added along with pieces on the Stern. The lower piece unfortunately when picking it up snapped in two so obviously not watching what I was doing.
    I found glueing this down not by what the instructions said but first clamping the piece in the centre of the top edge first and then once dry clamp either side in the middle. Again once dry glue and clamp the edges.
    The second planking next 😕
    Thank you for looking and the ‘Likes’
    Regards
    Doug
  6. Hello - further steps forward. First planking completed. Starting to feel / look like a boat now.
    The next series of photographs show the Rudder Post plus the upper Stern section (painted) having been added along with the other parts that make the outer skin of the Keel, all pegged.
    It’s good to see another Ranger being built - not many of them on this site.
    Thank you for looking.
    Regards
    Doug
  7. Hello - further steps forward.
    Extra pieces added to stern (sorry - no photo) and then the Bulkheads etc were sanded to allow a smooth run for the first planking. Then the two parts of the Keel were glued on plus the maple veneer piece at the stern.
    4 side pieces glued on / pinned into place.
    First planking next to do.
    Regards
    Doug
  8. Hello - further updates. All Bulkheads needed quite a bit of sanding so everything could be slotted together which was unlike Saucy Jack where everything slotted together with no trouble at all. Restraint had to be used so as not to break bits - patience and a bit more sanding.
    Bow and Stern Bulkheads etc were bevelled prior to attaching to Keel as instructions.
    Prior to attaching the ply Deck all joints were brushed with diluted glue.
    The ply Deck installed.
    Thanks for looking.
    Regards
    Doug
  9. Hello - small update. The Motley Crew painted and ready to go aboard, The detail is incredible given the very small size of the characters.
    Wasn't expecting the dog.
    Now all aboard.....
    Thank you for looking and the 'Likes'
    Rope coils and small rowing boat yet to do and that should be that.
    Regards
    Doug
  10. Hello - a question for Chris Watton. Cannot see on the Vanguard website that you have the crates for sale that James H mentions in the build manual for Saucy Jack. Tried going through the contact page on the website but in pressing the submit button nothing seemed to happen. If you could please let me know as have the fishermen figures in the basket awaiting to order.
    Thank you
    Doug
  11. Hello - Finish line in sight. Change of image quality as now using mobile phone 'cos camera has been sent off for repairs - but still the same dodgy build work though.
    Inner Jib in place and all tied off.
    Outer Jib
    Just remembered the Rudder Hinges needed doing.........
    Final picture
    Thank you very much for your comments - SiriusVoyager - Knocklouder - Jim Lad -AJohnson  plus the 'Likes'
    The small boat / barrels to paint plus some more rope coils to do.
    Regards
    Doug
