mgdawson
Everything posted by mgdawson
  1. Another alternative would be a bar gauge, you could knock one up in a size to suit mostly from scrap. Similar function as the telescopic gauges shown by tmj. An internet search will find a number of commercial & diy versions, too big for a model ship but different design ideas to make your own. I found a take down rifle cleaning rod on one of the chinese websites with 90mm sections to make one for the workshop, that'll measure from about 100mm to 1m when I screw all the sections together but after reading this thread I might cut down a couple of the pieces and make a mini one for models.
  2. This one ? https://www.thingiverse.com/thing:4980160
  3. Just in case people stumble across this old post, Model Expo is now selling "Planking the Built Up Ship Model" by Jim Roberts as a PDF $US7:99.
  4. Hey Mark, nice job, I picked up a couple of those, one for my mill & one for the drill press. Everyone, if you're looking for these, search for 'Angel Eyes' on the chinese stores, there are all different sizes, they're actually sold as car headlight surrounds. Mark D
  5. Which club ? Gotta say the old varnished timber boats were much prettier than the modern plastic ones. Mark
  6. Hi James The diagrams on the left are called the body plan, as mentioned above the left side of the body plan show the contours of the hull from midships to the stern and the right side shows midships to the bow. If you look carefully at the left side the midships curves on the 2 body plans are slightly different, the lower one has 11 curves drawn and the upper only has 10 and if you overlaid them you may find other differences. Perhaps try putting the text between the 2 body plans into google translate it may give you a clue as to what's going on. As Jim mentioned check out the article on reading ship lines plans, if you don't already, you really have to have your head around those concepts. Mark
  7. I have a couple of gas powered soldering irons which come with a knife tip for cutting synthetic ropes etc. Probably a bit clumsy for model work but a small flat or chisel tip, say 1mm, should do the job nicely and you've got a multipurpose tool into the bargain.
  8. I noticed these a little while back, the description says they're for cutting plastic sprues but they look like they'd be good for rigging, I haven't used them so can't comment further. $US19:99 each. Fine Precision Trimmer Ultra Fine Precision Trimmer
  9. Hmm ChatGPT says pretty much the same thing, maybe it's the bosuns belaying pin for giving slackers the hurry up 😂
  10. Had a look in Anatomy of the Ship - Diana, it lists 8' 18 pounders on the upper deck, 7'6" 9 pounders as chase guns on the f'cstle & 7' 9 pounders on the quarterdeck plus 32 lb carronades on the f'cstle & quarterdeck, unfortunately it only has carriage drawings for the 18 pounder & carronades. Perhaps one of the other AotS books has the requisite drawings.
  11. Google translation :- Zapon varnishes are thin, transparent nitro varnishes based on highly viscous cellulose nitrates (collodion wool), which are dissolved in highly volatile solvents such as amyl acetate, ethanol and ethyl acetate. They are usually colorless, but can also contain dyes.[1] They are usually used to protect metals such as brass, bronze or silver from oxidation (to prevent tarnishing). Zapon varnishes are unsuitable for use on iron or steel as they have no rust-protecting effect. They are also used as a varnish and for painting wood, glass and leather. The process of treating with zapon varnish is called zaponing. Zapon varnishes can be harmful to health and are usually highly flammable. A similar product is nail polish. Mark
  12. I seem to recall reading somewhere that the tallow was more a cream colour perhaps with a hint of yellow. Mark
  13. Hi Greg Just wondering what paints you used on the collins, particularly the bronzy colour on the topsides, it looks like a good starting point for a project I'm considering. Mark
  14. Perhaps this might be of some use. From 'China Tea Clippers', George Campbell, 1974
  15. Hi Allan Understand your preference for a book but at the rate F360 evolves any book would quickly be out of date, somewhat of a disincentive for any prospective author. WhiIe I saw the articles referenced by Kevin-the-lubber when they were published, I never worked though them so I can't make any specific comment but the diyode articles I have read seem to be of good quality, keep in mind those articles are almost 4 years old. There was a major change to the interface around that time so I'm not sure which interface those articles use, I know I got totally lost at the time when I was using tutorials based on the old interface with the new interface. If you haven't already found it I'd suggest youtube channel 'Product Design Online' hosted by Kevin Kennedy, if you search the videos for 'interface' Kevin has a few specifically on the interface and it's updates. Kevin is also building a 'Learn F360 in 30 days' course which he started 9 months ago, he's up to day 12 so far, looks like life got in the way of him producing the series for a while but appears he's back on it now. Mark
  16. Speaking from my limited experience of drydocking ships, I just don't see how that could have happened unless there was a serious error in the blocking. It'll be interesting to see what conclusions the investigation comes to.
  17. Hi Les, If I was faced with that option I think I'd go all or nothing for the running rigging, ie all one colour as she was originally rigged or ½ doz shades to show that lines had been replaced at different times. I'd perhaps also consider the same approach for the standing rigging, some not quite as dark as others, although the stockholnm tar would tend to quickly even things out fairly quickly there could be some subtle differences. Mark
  18. Hi Glomar I see you have a couple of double block purchases there which the plan is not clear as to how to reeve them, you may have already worked that out but if not this pic might help.
  19. Hi Dave, As 'Endeavour' was built as a collier, 'Earl of Pembroke', not as a warship for the Admiralty I'm not sure Lees book would be relevant. When the navy bought her they refitted her below decks for her new role but they may have left the masting and rigging as is if it was in good condition and there was no good reason to change it. Presumably the 'Earl' would have been rigged for a much smaller crew than the navy would carry for a ship of that size and a smaller crew would also suit the planned voyage. Mark
  20. Hi, Don't know about the name on the stern but she would have had draft marks aft and midships, you can see the midships draft marks in your 2nd photo.
  21. Damn, tried to paste the image and it pasted the url, see if this works.
  22. Hi Mark That looks like one of the pond boats they used to sail in Sydney around 1900, I know there was a 2 foot class, not sure what other classes there were. I see you're in Sydney, I'd suggest a visit to the Sydney Flying Squadron at Kiribilli, in the bar upstairs restaurant area they have a 2 footer on display along with a lot of other memorabilia. I believe the photo below is the same model but it's now rigged. The restaurant is called Foys after Mark Foys who founded the SFS, yes that Mark Foys. If you go down about lunchtime on a Saturday you'll also see the classic 18' skiff replicas rigging up, most of them are modern molded construction but the Brittania replica uses the original batten-seam construction. (Last race of the season, 25th March) http://www.openboat.com.au/uploads/8/1/9/7/81975644/img-1003-2_orig.jpeg I picked up some white cotton 2mm rope from Rope Galore, bit thicker than you're after but it may suffice if you can't get any smaller. They do mail order or they're right next to Bankstown airport. I see they also do coloured 2mm polyester vb cord.
  23. And potentially make her very stiff, I wonder if that's why they re-sheathed her with wood only 2 years later.
