Posts posted by pete48
Today, before I finish the final 2 coats of Varnish on the hull, ( I decided to go with a varnished Hull no bottom paint or water line. Kate said you don't want to cover up the wood do you ? she wins ) I started by trimming the deck edge where the Cockpit coaming meets the deck, I then sanded the deck to 400 grit sandpaper ( starting with 220 ) I then applied 2 coats of semi gloss white to the deck . Here are the resultes
- Aussie048, Rao A.L.G., yvesvidal and 11 others
14
Happy Birthday Bob, the Friendship sloop is looking good
Best Regards,
Pete
- GLakie, IgorSky, captainbob and 1 other
4
She is looking Sweet Patrick, Beautiful work
Best Regards,
Pete
- Piet, Dimitris71, michael20 and 2 others
5
Wow Nils, The only thing that I would add to everyone else is Stunningly Beautiful
Best Regards,
Pete
After enough procrastination, and a lot of projects that I would like to start on I decided to finish her as a static ( less Sails ) So I started by rigging up the mast. I first made the Main Sheet traveler, then put the mast in the Mast step. Next I installed the main Sheet, and installed the Standing Rigging. I installed the Main winches for the main sheet and the jib. I then installed the steering stations, and then ran the Back Stay. Then I installed the Navigation Station. Next will be to make the 2 Rudder Blades, Cradle and install the Keel. Here are the results
- flying_dutchman2, BenF89, Krelis and 9 others
12
Hi Michael, Happy Birthday, your boat is coming together rather nicely, Looking good as always
Best Regards,
Perte
After some long contemplation, I decided that I would Varnish the Hull, With Epifanes . and rather than showing it being sanded and another coat being applied. I would show it after 4 coats have been applied sanding with 400 grit in between coats, and waiting 24 hours between coats . I will do one more coat and she should be ready to go . I will more than likely do a flat white bottom paint with a blue waterline. the slot for the tiller has been cut into the transom. Here are the results
Thank you Cap'n'Bob, I appreciate it,Your Friendship sloop is looking really good as well .
Best Regards,
Pete
- russ, druxey, Elmer Cornish and 10 others
13
Hi Michael, I am with all of the above just beautiful work
Best Regards,
Pete
Beautiful work Cap'n'Bob, She's looking really good, I would like to get in on a sail
Best Regards,
Pete
- Omega1234 and captainbob
2
- IgorSky, michael mott, Mirabell61 and 13 others
16
Absolutely incredible work Michael. nicely done
Best Regards,
Pete
- Elmer Cornish, Omega1234, druxey and 7 others
10
VOLVO OCEAN RACE Open 70 By Pete48 - FINISHED - Scale : 1/4" = 1' - 0"
Hey Patrick , how about a sloop rigged pleasure boat ?
Thank you Marc, I would like to see a rc build of a Volvo Boat
Best Regards,
Pete
