Everything posted by UdoK
Thanks Kevin, actually I have send them an email recently. They are waiting for the printed deck layers to complete the kits, will place my order pretty soon.
- 337 replies
- finished
- mountfleet models
Congratulations to a beautiful build of a impressive and rare model. Before i was reading your buildlog I did not even know anything about Mountfleet models. When checking out their website I felt in love with their Model of the Boston Typhoon unfortunately currently unavailable, but i will keep an eye on it for sure.
- 337 replies
- finished
- mountfleet models
Thank you Antony, my intention is to have the updates coming more often again.
Hi all, It's time to do something on the Bounty again. The lower transom is planked with the supplied pear wood planks. In order to obtain the lateral bending of the planks, I made a template with the required radius of the planks, soaked the planks in water and allowed them to dry in the template. Before the first belt of the wales had been cut and attached I made some plank clamps from a brass rod, threated rod M 3 and cherry wood.
I' am probably a bit late to the Party, but here a Photo I took on the Batavia which shows the dimensions..
- 91 replies
- kolderstok
- duyfken
The positions of the gunports has been determined and the boxes have been glued in place. To add more strenght to the boxes and create a bigger lip for the surrounding planks some extra strips have been installed. In order to determine the run of the wales and position of the gunports all the bulkheads come with laser marks for each wale. Basically a good idea, but due to my decision to close the hull with plywood not many of the marks are still visible. So I had to take the dimensions off the drawings and transfer it to the hull. Before starting the installation of the wales I did plank the concave area above the transom with basswod strips 1x4 and sanded them to shape. After one coat of sanding sealer and intermediate sanding several coats of a acrylic paint (Ivory) were applied. Finally I have prepared the transom wales from a walnut strip 1,5 x 5 and glued them into position.
Thank you for your Likes, construction continues! After planking the stern and closing the gun ports with walnut strips the last remaining bulkheads got filled with plywood and sanded to create the largest possible surface to fix the single planking. Unfortunately a few of the very fragile bulkhead stubs broke off during sanding the hull, but not major issue, will be a easy fix. The lasercut parts for the keel are cleaned up and glued together along with a basswood strip to form the false keel. As the hull below the waterline will be painted the keel is made from basswood, the upper stem and stern parts are walnut. While waiting on the glue to set I have constructed already the gunport boxes for the canon dummis from the lasercut parts.
Thank you Piet and Robin. In the museum shop of the Batavia warf I had the opportunity to inspect the kit of the Duyfken, it is also a very interesting ship. I am already very excited about the Kolderstok kit of the Zeven Provincien which is supposed to be released at the end of the year. The pictures show the model of the Zeven provincien at a scale of 1/10 in the warf Workshop, it's huge!
Thank you Scott, this glue is my favorite too. Before the construction goes on a short look inside the Kits box. The wood is of very good Quality troughout, the Accuracy of the Laser cut parts like Bulkheads, Keel, Stem and Stern parts is excellent. Walnut strips are included for the single Planking and Furniture. The figures and carvings are casted from resin and obviously also very well done. The Assembling guide consists of 6 sheets of Drawings plus a photo-illustrated booklet.
Hi all, Because of the fact that I lost my interest and the enthusiasm for some of my started models, these were canceled and the corresponding build logs deleted. Other projects such as the build of the Bounty, Gunboat William and the HMS Endeavor take a break. After a visit to the Batavia shipyard in Lelystad / Netherlands, I finally started to realize my long-standing desire to build a model. The Kolderstok kit was ordered and the construction began, this was in July already. Unfotunately I didn't take pictures from the beginning, so the Photos below show the Status as of today.
Almost one year since the last upate, time goes by but the build is still alive. Hull fairing has been completed, all the low frames are filled and sanded again. I have installed one another transom wing and a Piece of wood to support the planking around the rudder opening. Now on to the wales..... In the last Picture you can see some damge on the false keel caused by the 'heavy sanding equipment' during hull sanding. I will probably replace the after part of the false keel after planking is completed.
Hi Ron, you are walkng down the road pretty fast. Your copper plates are looking fantastic!
- 56 replies
- Charles W Morgan
- Whaling Bark
Thank you Nils. Window framing completed and I made some good progress on the hull fairing last weekend.
