mtaylor
Moderators
Everything posted by mtaylor
  1. Blocks could be attached to eyebolts or rigged to the masts/yards using rope.
  2. Hi Wahka, You'll find that double planking is only done on some kits... probably more than I can think of. This was done so that a novice builder could use the first planking to get the shape and second planking to make it look nice. Also, many of the older kits just aren't that accurate to begin with. So, use the wood you want for the second layer. If you want to bash it some more, research and add to it to improve the accuracy. But most important... enjoy yourself and the hobby.
  3. Wahka, I'll add to what Chris said and suggest you open a log. Not only will you get help, but you'll be helping others.
  4. Nice work, Denis. Came out looking the bees knees. The Brits and the US also had quite a few German aircraft also so it could go the other way as far as models.
  5. Lovely work on the Mercedes, Jack. It came out looking great.
  6. Welcome to MSW. I can't help either except to suggest that maybe you can cut a new plank from the scrap the kit left behind.
  7. Well that's only part of what a log will do. It'll also get you help from other watching the build. A win-win situation.
  8. No necromancy Denis, except the guns. The butchering concept to me is getting things to fit together. A bit of hack and paste, sanding, reshaping.... I got really bogged down with the ramp area. Still not perfect but it's close now.
  9. Looking good and I'll keep my fingers crossed for the painting.
  10. For a hundred missions, she probably went through at least 4 total crews.......
  11. I'm not at this point as I haven't checked the fit as yet. Besides it's "Bashing" for everyone else, for me it's "Butchering".
  12. Thanks for the ideas, gents. I mounted the rear ramp and door... not glued yet though as I'm sorting that part out. I'm thinking either fully closed or maybe the top panel fully open and the ramp half open or even full up. I also started filling in the gaps.... tomorrow sanding. And before I repaint the filled gaps, I need to check the fit of a few pieces just in case I need to butcher things.
  13. Discretion being the better part of valor, I won't say anything else other then to suggest you start a build log.
  14. Well... I don't think pirates would be asked to guard anything.
  15. Not intentional Lou. But I too like the way the finish looks. I may or may not add some "weathering" if I can figure out how to do it. Didn't get much done today as doc said today is physical checkup day with labs and tests scheduled. So I went. I'm still sorting how to fix seams and also put on the cargo doors on the rear. I have a feeling that the instruction book will be ignored for this step.....
  16. Don't you know that we Marines were taught the fine art of pillaging and looting and also taking over unoccupied positions? By the way, the paint job looks great. (gotta keep on topic here...).
  17. Thanks, OC. I too will have to put some filler in a few places so we're both steady as she goes.
  18. Very true, Spyglass. I've done a couple of their ship's boats and they are "different".
  19. Got the fuselage glued together and taped. I'll let it dry overnight. Somehow, I managed to not only knock off one gun but also the mount. The mount is back in place and I'll hold off doing the gun for now. The mask for the front glass area should be here tomorrow.
  20. Welcome to MSW, Gremreeper1967. I hope you'll start a build log so we can follow along.
  21. I was thinking the same as Druxey and Patrick. Leave it.. looks great.
  22. Thanks OC. I think some of the American bombers used the same or similar setup.
  23. This is probably the best bit advice for planking issues. Once one reads and absorbs the concepts, the mystery is gone.
  24. Sounds like a good plan, OC. I have a question... in the cockpit, there's an opening in the floor, is that an escape hatch?
