Everything posted by mtaylor
I have to agree with both the above comments. At least try both out and see which you are more comfortable with. One can find dividers at a very reasonable cost to experiment with. If you find you don't like the results, they can be sold. I have a bow compass that can be used similarly to dividers but seldom use it.
Seems in the military, when Murphy runs amok, it's usually a massive "all hands" type of problem.
- 422 replies
- minesweeper
- Cape
Harbor Freight 16" variable speed scroll saw
mtaylor replied to Dr PR's topic in Modeling tools and Workshop Equipment
I think you need to change your tooth count for the thinner woods. I;m posting al link for the Byrne's saw and it has a section for tooth counts. I've found that these are applicable to a scroll saw. -
Remains of 500 year-old shipwreck: Dated 2019
mtaylor replied to Allegheny's topic in Nautical/Naval History
For those running into paywall stop after using a given site for a time, try going into your browser cache and removing ALL of the cookies for that site. Also note that some sites leave 2 or 3 caches to go through the list carefully to get all the ones to remove. It is a toss up and sometimes it doesn't work, other times cleaning up does work. -
More coloring brass questions
mtaylor replied to bigcreekdad's topic in Metal Work, Soldering and Metal Fittings
I tend to stick with Tamiya Fine Primer. Come in some colors like white, gray, and black. -
I find car wax works well. Some also seem to use Pledge. I guess I'm just stuck in my ways. -
Harbor Freight Combination belt and 5" disc sander.
While you're at Home Depot, check out the shop vac area. I have seen and own some adaptor fittings to fit various hose and tool sizes. Been so long though I don't really remember where I bought them. Might have Lows or Home Depot.- 8 replies
- belt sander
- disc sander
Greetings from a clueless Patrick O'Brian fan
mtaylor replied to Galkar's topic in New member Introductions
I tend to agree with Tom but also perhaps is was so the pilot/crew could keep an eye out for a chimney fire?
- 732 replies
- Lula
- sternwheeler
- 732 replies
- Lula
- sternwheeler
A couple of things to try. I have a different brand saw but similar. First, apply and buff out well using some car wax to the bed surface. Then remove the foot. I removed mine pretty quick and running at way less than full speed, I usually hold down even smallest of pieces to be cut. Just have to stay alert and watch where the fingers are in relation to the blade. I've found that a slower blade speed gives me more control of the cut and if the blade snags the wood and tries to whip it up and down, less problems occur. Oh...... I make my own inserts for the saw bed. A apiece of wood with appropriate thickness and then drill a small hole just slightly larger than blade size. This also helps prevent things running amok. -
My newest Challenge
mtaylor replied to James Flynn's topic in Building, Framing, Planking and plating a ships hull and deck
I'll take a different stance.... once you have all the plans, enlarge all of them to the new size. Then as needed you can print them out. The reason I suggest enlarging all the downloaded plans is so that a) you get a good overview of everything. b) you won't have missed any while building. Also, there many print/copy shops around that will print out the enlarged plans for you. Lastly, given the way costs go up it might be less expensive to do it now than wait. At least that's my preferences, yours may be different. -
My newest Challenge
One can always take pans to a copy center and have them enlarged as needed. Also there are Harold Hahn plans available. I'm sure who's selling them at this point. They too will need enlarging. -
Hmm.. red wine. Call it the "Red Sea".
- 185 replies
- Flying Dutchman
- Black pearl
Beautiful build and also the display. The display is very unique and adds something, IMO.
- 82 replies
- half hull planking project
- half hull
