Old Collingwood
  1. Did that have an outside framework for the guns on them or just hand held inside the cab? OC.
  2. We try our best though mate - laughter and good banter is a good remedy and I cant think of a better place than here, OC.
  3. Hey, im still growing up - at heart 25, in body feel about 80 actual age not telling lol. OC.
  4. Plan for latter today - make up the other wing/nacelle assembly, then clean up the seams same as the other one, then couple of coats of primer (good tip to kill dust specs - use some tape to act as a tack rag) then the grey paint over the top, set to dry then mask up ready for the green paint. OC.
  5. We just have the one room with a back and front door leading off it, my work table is also in it, so any paint smells circulate around the room, no were else to build. OC.
  6. Thank you so much craig, Its very much a feeling my way as I go kind of thing, those tamiya rattle cans for model aircraft do seems very good and leave a very nice finish. OC.
  7. Will be interesting to see how the green/grey turns out, the main issue seems to be getting enough contact to stop the paint creeping, but not too much so it lifts the paint or leaves marks on the paintwork. OC.
  8. Yep thats - typing paper cut into close enough shapes, Blue tack to get a softer edge, and red painters semi low tack tape, Its a Celebration friends - My First masking job. OC.
  9. So you have traveled in a Boeing 707? I have too when I was a teenager. OC.
  10. Right then - a bit more progress, I put the primer on both sides of the one wing, then when dry - aided with the venerable hairdryer, I then moved on to the fuselage and gave it a couple of coats of Grey, I also did the same to the top of the wing. After a couple of hours I masked up both the fuselage and wing - using a combination of Blue Tack for the edges, and paper and tape for the bulk of the masking - ready for paint tomorrow (if the weather is kind) also need to work on another system so the smell from the paint does not come into the house - possibly putting the painted parts in a closed plastic box till dry - so some of the smell can go off a bit first before bringing them into the house. OC.
  11. Small update - I primed the top side of the wing and at the same time put the Grey layer over the masked section of the top fuselage - tomorrow I will start masking using blue tack/paper and tape ready for the Green, photos to follow tomorrow. OC.
  12. Thanks mate yep - wont try it though by throwing it out of the window. OC.
  13. Coming on nicely Lou, I agree with all - those figures do look good. OC.
  14. Hi all, spent some good time on the mossie today, I glued up the one wing after fitting the ailerons and flaps, then I cleaned up the seams. OC.
  15. I heard - he pinches pop corn - oh and watch your pop, but I wont tell Lou. OC.
  16. Get one of those garden hammocks you could share it with lou. OC.
  17. Like me Lou we learn more about the art in making a kit look half decent as we go along, when I was masking and spraying yesterday it struck me that it was the first time I have ever done anything like this - all my painting of models has always been with hairy sticks. OC.
