Old Collingwood
  1. Thank you James, I will start a build log when It arrives - would be great if you follows along. OC.
  2. I have a replacement sorted now - its an Eduard Mk IX (Late Version) it comes with a bit of Bressin/Eduard PE and a canopy mask and decals for six models, it should arrive some time this week. OC.
  3. Hi all, a good day today I did the kind of work where you feel your not getting very far - but in fairness a fair bit was actually done, starting with the undercarriage units I painted therm flat alum then I put them aside to dry - then I added a couple of coats of paint to the wheels, after drying with a hairdryer I then highlighted them to bring out the tread details - after I painted the hubs flat alum. I then studied my idea for extending the front units as the Revell ones sit to low, I dry fitted the two engine cowl units and worked out how the undercarriage sits in place, its is a tight space in there and the legs needed to go in at an angle to fit, I then worked out if I used a 1-2mm strip glued it it and bored a couple of holes - it kind of did the trick. They are not fitted yet just dry fitted as there is a system where the whole wing needs assembling first - but the flaps also need assembling and fitting as they are movable surfaces, this all needs doing before the engine cowl/undercarriage units can be fitted together. I also worked on the inside section of the wing that will be in view - like the inner groves when the flaps are dropped - also the rads in the wings were painted then fitted inside the one section of the wing. OC.
  4. Yep I have my eyes on one - been doing proper research this time and found a kit by a company called Eduard they are renowned for doing resin and brass stuff - didn't know they did kits, anyway they do a very good Mk IX in the same 1/48 scale - might have some good news in a day or so - will report back, might be starting a new build put it that way. OC.
  5. Its ok mark, this and my Mossie have to be right (my farther watches me over my shoulder) so I want to do my very best for him, and I didn't know the ICM kit was going to be such a pig to build or be in such bad shape after closer inspection - and like I said the instructions were total rubbish most of what I was doing was guess work but look where that got me.... OC.
  6. A little trick I found out for myself - to stiffen the spindle parts of the leg assemblies, I work some CA along them with a fine stick/fuse wire then heat it fast with a hair dryer to set the glue quicker, this really seems to make the thin plastic parts a lot stronger. OC.
  7. Yep, PE bendy boxes - I remember them form my HMS Warpy kit at 1/350 scale hard enough to see them let alone bend them - and yes you are right - its a "one time only go at bending the walls in to make boxes - what I found useful was bending one face at a time against something flat of square then gently do the remaining faces - then if there is an opening dab some CA on a fine stick or fuse wire inside the box to glue the edges. OC.
  8. More added to the undercarriage units including the mud guards and oil tanks. OC.
  9. While the fuselage is drying I checked the instructions - they call for the main undercarriage units to be made - they are made up from two side units and a few other smaller sections - its a case of gluing then supporting while they glue, then when complete again support and put on one side. OC.
  10. Hi all, with the Spit no resigned to the spares department - its given me more time to work on the Mossie, firstly I attacked that nose detailing that I had done before - I took the masking of the nose and carefully re taped it level with start of the frame nearest the fuselage, then I used a very narrow piece of light sanding stick - and sanded the strip I had put on, this went quite well with the sanding stick piece being only very narrow - I was able to control where I was sanding, after I tacked it with tape to get rid of any dust - then I went out side and sprayed a couple of coats of surface primer just over the front area - job done. OC.
  11. This build is definitely scrapped just too many errors and some bad parts - and the instructions are just so hard to follow, its not a disaster as it was only a the price of a Mcdonalds burger. OC.
  12. I'm going to scrap this and wait for a better kit. OC.
  13. Just been down to the table took the engine with me into the kitchen (good light) then tried under not the best conditions to alter the angle on both - one side moved upwards (result) and the other side came away clean, so I class that as a good outcome. OC.
  14. Glaring problem number two thats just come to me - I have put the manifolds on the wrong way as they are angled to compensate for the angled cylinder heads - but mine point down to much when they should be pointing upwards ........can I swear. OC.
  15. Sorry for the confusion - I put the wrong box artwork pic up off the net, call it one of those moments... Its corrected now. OC.
  16. The clipped wing was done as an effort to compete with the FW-190 that was killing a lot of normal spits, so I understand they tested a few with clipped wings, they also put in a more powerful Merlin and that became the IX, this Spitfire had at last the power to deal with the Germans best, they continued to make clipped wing version though as they gave short dash speed improvements at lower altitudes. OC.
  17. After spraying the primer - its made it obvious that I made a mess of the nose, so tomorrow I will take the tape off the nose glazing then I will put a fresh couple of straight line masking tape runs around the circumference of the glazing where the frame ends, then I will gently sand around the area to get a smooth transition from the glazing back onto the forward fuselage. OC.
  18. I had to bevel the edges where the manifold sticks out the fuselage to allow the engine to drop down into place while dry fitting. OC.
  19. More work today starting by cleaning up both fuselage sides - there was quite a bit to trim/sand off, next I glued the front engine bay firewall bulkhead (I decided to remove the engine mount from the Merlin as it was going to foul the fuselage) I will still fit the engine as it has the exhaust manifolds attached to it. I also had some small fitting to add inside the cockpit - I have to say the quality of the moldings and engraving is very high and frankly wouldn't really benefit form PE - this is the status before I add some paint. OC.
  20. So -a brief spell with no rain this gave me the chance to spray the Tamiya Surface Primer - seemed to go ok. The stick was for me to hold it by the way...... OC.
