Love this build - and the additions of the figures gets my vote. OC.
- 206 replies
- Vanguard Models
- Brixham trawler
So how will I make my faux doors? I will use Two pieces of paper layed ontop of each, I will then mark out the doors dimensions then cut through both peices creating Two doors the exact same size. Then I will cut out strips of the same paper to simulate the boards and Two cross boards, these will then be glued down using my PVA leaving a slight gap till both are completed. When dry I will paint both doors in flat Black and after I will do a bit of washes and dusting to weather them. I will also make some frame work using some of my wood stock, these will then be painted flat Black, and when dry I will glue them both sides of the wall macking sure they lign up on both sides of the wall, and when dry I will glue inside on the walls the Two doors - hey presto. OC.
I have some similar (Lolly sticks) but they will be too thick to use for the door panels, I can use them to make some thinned down frames, but the faux door needs to be a thin as possibly literally paper thin as they will be glued on the wall both sides mimicking a door, with the frame disguising the depth of the door in a kind of 3d illusion. OC.
Evening all, after doing some thinking I think I may be able to come up with a gate/door from the pond area into the orchard, I could make up a faux door from paper with some over layed pieces to mimic the planks, I could also use some wood to make a small frame - that should give a 3d look and blend in when all painted Black. OC.
Amazing work Greg - the master is in his prime - so glad we have you in our forum brother - thank you. OC.
- 200 replies
- Transport No. 103
- Hasegawa
(and 4 more)
Totally agree about Vallejo Black Surface primer - its good as it shrinks down, but it is delicate and needs a few days to harden before paint layers ontop, even then I sometimes find its surface a bit shiny - almost slippery for the paint layers to stick to, but once they are built up and a Good top coat is applied - its all Good. OC.
Eveninga all, no progress (I have been lazy lol) but just a heads up of my next move with this - the second Cuirassier will be an officer - his shoulder detail is different as he only has detail on his Left shoulder and next to nothing on his Right - and he has a silver colour not Yellow (Red I mean) like the normal ranks, so I will make another one for him. OC.
