Old Collingwood
  1. So how will I make my faux doors? I will use Two pieces of paper layed ontop of each, I will then mark out the doors dimensions then cut through both peices creating Two doors the exact same size. Then I will cut out strips of the same paper to simulate the boards and Two cross boards, these will then be glued down using my PVA leaving a slight gap till both are completed. When dry I will paint both doors in flat Black and after I will do a bit of washes and dusting to weather them. I will also make some frame work using some of my wood stock, these will then be painted flat Black, and when dry I will glue them both sides of the wall macking sure they lign up on both sides of the wall, and when dry I will glue inside on the walls the Two doors - hey presto. OC.
  2. Excellent start Alan, this has all the potential to be a fascinating build into a real star item - loving it mate. OC.
  3. I have some similar (Lolly sticks) but they will be too thick to use for the door panels, I can use them to make some thinned down frames, but the faux door needs to be a thin as possibly literally paper thin as they will be glued on the wall both sides mimicking a door, with the frame disguising the depth of the door in a kind of 3d illusion. OC.
  4. Thank you Alan, I think it will bug me if I don't try to make one. OC.
  5. Would you have the flexibility to make it diifferent scales? I know you said its 1/200 scale. OC.
  6. Thank you kindly Mark, I did have the gate included in the wall section - but I had to remove it when I reduced the length of the wall, and forgot to work it into the smaller wall - kind of got distracted by the other areas of the build. OC.
  7. Evening all, after doing some thinking I think I may be able to come up with a gate/door from the pond area into the orchard, I could make up a faux door from paper with some over layed pieces to mimic the planks, I could also use some wood to make a small frame - that should give a 3d look and blend in when all painted Black. OC.
  8. Morning all, I have discovered a Boo boo with my build ( I wanted it as historic accurate as possible) when I cut back the wall near the pond I cut out the gate leading from the pond into the orchard - "Yep I should have cut out and fitted the gate" so guess I have to take this one on the chin. OC.
  9. Amazing work Greg - the master is in his prime - so glad we have you in our forum brother - thank you. OC.
  10. Thought you might find this interesting Alan - http://castillodeloarre.es/en/the-castle/ OC.
  11. How could I not follow this - I have all my comfy things to the ready - I can feel a seige coming on........ OC.
  12. Evening/morning all, bit of a re-think about the Cuirassier officers epaulette - he had it shot off in action (well to be honest I could not get a good one to look ok - so I chickend out) so I will show a bit of it on both sides with Silver paint. OC.
  13. All sounds Good Alan, will watch with interest what ever you make. OC.
  14. Sorry to hear about your chilly calamity - hope you have a speedy recovery - never tried it myself - I preferred to hurt myself by Mountain biking Yep once Fractured my femur that way. Loving your Hurricane - its coming a long really nicely. OC.
  15. Totally agree about Vallejo Black Surface primer - its good as it shrinks down, but it is delicate and needs a few days to harden before paint layers ontop, even then I sometimes find its surface a bit shiny - almost slippery for the paint layers to stick to, but once they are built up and a Good top coat is applied - its all Good. OC.
  16. Thanks Ken, lots of research and internet studying - so perhaps not so lazy lol. OC.
  17. Eveninga all, no progress (I have been lazy lol) but just a heads up of my next move with this - the second Cuirassier will be an officer - his shoulder detail is different as he only has detail on his Left shoulder and next to nothing on his Right - and he has a silver colour not Yellow (Red I mean) like the normal ranks, so I will make another one for him. OC.
  18. Excellent work Alan - what a lovely dio you have made there - it shows all the elements that tells a story great work my friend. OC.
