HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
kiwiron
  • Gender
  • Location
    Christchurch,New Zealand
2,401 profile views
  1. I had a broken decoration, no response from Jotika at all after 4 emails, very poor service. I got hold of the retailer I purchased the kit from and they got the part I wanted in a few days ready to send to me.
  2. Not very clear, aft holes of #406 then I presume past each side of bowsprit through round hole near rear of stem possibly.
  3. Thanks a lot Chris, also thanks for all your photos and advice.
  4. Masts done, now for the yards and booms. Just one mistake I managed to get around. Make sure you match the mast tops to the correct masts and lower or upper position.
  5. Much easier using pin striping tape for the bands. Just wrapped fully around cheeks and mast twice then just trim tape so it looks like the band goes under the cheeks.
  6. Things I learnt on the foremast. When trimming the mast for the Cheeks to fit make sure you trim for them in line with the 8mm square above vertically. I will try pin striping tape for the bands after the styrene kept breaking. Add blocks to the Platform after painting black. I did'nt so got some black paint on the blocks so had to paint the blocks black. For the mast top cut a small v under it to allow for thread to fit between that and Top Gallant mast. Fit the boarding pikes last, easy to damage. I used styrene for the battens instead of trying to cut 0.5 x 3mm walnut into 0.5 x 1.5mm. Hope that makes some sense.
  7. Thanks Chris, I'm onto the masts now after a break. I finally know what I'm supposed to do now studying your photo's over and over for the masts. Between fids, sheaves and bolsters I did'nt have a clue what most were. In the second photo I think I was supposed to take off the small end piece. This now matches the cheeks length on the plan sheet. Mock up of Bowsprit and lower foremast.
  8. Looking very nice, mine looks o.k from about 20 feet away. I know where every mistake is I've made but hopefully anyone looking at it won't be able to tell. Keep up the great work, Nice to get to the end of the hammock nets.
  9. Great work, your photo's are a great help to me as I flounder along. I'm onto my Foremast now. I lined up my Bowsprit Gammoning the best I could but found it lined up even better sliding the Bowsprit out a couple of mm.
  10. Thanks Graham, The yacht had 952 pieces and good instructions. I had to re do a couple of things but not too major. As per the Victory it pays to look ahead a few pages if things are a bit vague. You're doing a great job on your shed, very nice lining job. Ron.
  11. Train layout nearly done. Just painting of cars & trucks to go. With New Zealand winning the America's cup for the third time in a row I had to buy the lego yacht. Putting off the mast tapering for a while over our summer with overseas and N.Z. motorcycle riding to come.
  12. Nice work Chris, coming along real well. I was glad when I finished my cannons.
