Kevin
MSW Social Media Moderator
Everything posted by Kevin
  1. Laps Can you please post a picture of yr build into the following thread please, and invite anyone else to do the same, the opening page gives the reason why i ask http://modelshipworld.com/index.php?/topic/1589-latest-full-profile-photograph-of-your-build/ all the best
  2. Grant thank you for answering Keith, i have been trying to find a photo for you, found this, its not exactly what i wanted, but my plans are to big to scan , however it shows the small dead eyes and corresponding ropes going it different direction to those supporting the shrouds
  3. Securing Chain Plates to the Hull i have found that if the bottom of the chain plate is bent to approx the angle required, then you are able to mark the position with a Map pin. Using a 0.5mm drill i have made a hole for the pin and tapped it in with a toffee hammer, worked so far. Continually checking with the plans to ensure that the gun ports are kept clear
  4. Gil what colour did you use on the captains entrance canopy, i have used a light grey (intact grey primer) to simulate what i guess must be lead.
  5. http://en.wikipedia.org/wiki/French_ship_Montebello_(1812) slagoon - well done
  6. it is The French Montebello
  7. not the She looks like the Mahmudiye ... (Ottoman Empire)
  8. no not HMS Duke of Wellington
  9. no - not victory
  10. what's this one
  11. yes it's a trick of the light but i have spent quite a lot of time trying to keep it tidy, but it starting to cause me problems, mainly with the black, the wale's and down to the waterline were done in Halfords spray matt black, when it comes to touch-ups i am finding the pots are very glossy, as you can see on the upper black areas. i lost a few more tiles last night, i dropped one of the captains entrance sides into the hull, and it bounced (laughing at me) all the way down to the keel. it's a big hull for turning upside down getting the dam thing out.
  12. http://en.wikipedia.org/wiki/Russian_battleship_Gangut_(1888)
  13. Cat heads As i continue working the stbd side, these were ok to build, but i either made a big fuss about nothing or they were just a pain to get the decorative strip under it, using the brass profile, it requires to be recessed into the upper wale, as well as running in all angles Stbd side decorative strips most of the brass profiles are now fitted between the upper gun ports, channels/allready fitted with dead eyes after repainting the ships side where necessary, i hope to have the stbd side fitted this weekend Captains access access hatch - stbd side ready to fit ladder - stbd side being worked on
  14. Gil would you like to put a photo into this topic for me please http://modelshipworld.com/index.php?/topic/1589-latest-full-profile-photograph-of-your-build/
  15. wow Gil Thats going to give me something to look at properly, when i get the chance
  16. but i am looking for it
  17. oh another target, in the mist/haze
  18. i wonder that the outlay would be to put a release out like that, even though they will make it back
  19. i continued last night to get the bow decoration right, - lol unsucsessfully, was hoping to work backwacks towards finishing the decorative strips that run from the steps, also nearly ready to fix the fore mast chain plates
  20. well i have had my two minutes of fame, so i will spend the next 6 months waiting to see if i can get another one right, and then give it away
