Kevin
MSW Social Media Moderator
Everything posted by Kevin
  1. Derek , good morning The dead eye strop started as a pain, what i did was make a small hole using a 1mm drill bit where the pronges of the strops are fitted in the channel, then push the fixture into position with a pair of thin long nose pliers, worked a treat, to keep them in place a little dab of c/a glue, and covered with the outside strip
  2. Patrick thanks for the reply, that's the point i was try to make, the plans don't show the tabs and the instructions don't mention having to cut the tabs out, im sure Gil would have mentioned this in MSW 1.0 , but i guess we are having to learn all the same mistakes again, Anyway, i am at present sorting the problem, channels are removable from the hull, and the glued link on the bottom of the dead eye strop is easily unglued, - no damage done,
  3. i made a mistake, but is not to drastic to put right and LOL it has nothing to do with no glass in the 1/4 gallery The chain plates the instructions with the kit are to say poor is an understatement, it basicly shows you the advantage of being able to close the loop like a nappy pin what is fails to tell you is the process for making them up it was not until i studied Keith Julliers explanation and looking at Gils photo's that i noticed that the actual plates then self s have to be separated into two or three parts, good god nearly had Murphy visiting my new workshop i have posted a photo to try and explain, the flashing between the links has to be removed and then build them in a link form i can see that there maybe builds that have incorrectly completed this task, and understand why
  4. afternoon everyone Took the build out into daylight, channels, dead eyes and chain-plates continue
  5. total build time 737 hours Good evening everyone very little progress today, but did get time to understand the Jotika way of fitting Dead-eyes with their new strops, the Deadeye is pushed into the open ended strop and the two little side bars hook into the wood of the channels, it is such a tight fit that it would take quite an effort to pull then out when it come to rigging this leaves a closed loop to attach the chain plates to the assembly please excuse the pathetic drawing
  6. Good evening every one - and happy Easter, as it already Sunday in some places a lot of work done on the build - not much to show for it stbd aft chain channels have been dry fitted and all the decorative strips in-between then have been cut and fitted into place, then primed and painted black, i took some photos, but need to redo them again, not good enough to post, my new workshop has no natural light, so no detail showed up i am trying to best work out how to paint the stips as they pass through different colour bands
  7. dont invite me to go fly fishing with you, i get cold walking 10 feet from the front door to the garage,, lol i will go to ASDA to get my salmon, oh and by the way, no wain today or snow, just a wind that goes straight through you, or maybe its just me, my body is getting used to loosing weight as part of my new years resolution 19 kg so far
  8. Prep work to secure the channels to the hull, using 1mm drill bits
  9. Akula (Russian: Акула - Shark) was a submarine built for the Imperial Russian Navy. The boat was designed by Ivan Bubnov and was an amalgam of the previous Minoga and the Kasatka class submarine designs. The design was presented to the Marine technical committee in late 1905. Initially the boat was to use petrol engines but these were replaced by safer diesels. The boat's design was a single hull/ saddle tank type with a diving depth of 25 fathoms (45 m). Significant initial problems were experienced and the electric motor and propellers which needed to be replaced. Akula was the first Russian submarine able to cruise long distances. In 1912 Akula made the world's first multi-torpedo volley with five torpedoes. She subsequently served in the Baltic Fleet during World War I making 16 patrols and unsuccessfully attacked the German battleship SMS Beowulf. She struck a mine and sank near Ventspils in November 1915 on her 17th patrol. Displacement: 370 long tons (380 t) surfaced 475 tons (471 m³) submerged Length: 56 m Beam: 3.7 m (12 ft 2 in) Draft: 3.4 m (11 ft 2 in) Propulsion: 3 shaft Diesel electric 3 diesel engines 1,900 hp (1.4 MW) 1 electric motor 300 hp (220 kW) Speed: 10.6 knots (19.6 km/h) surfaced 4.6 knots (9 km/h) submerged Range: 1,900 nautical miles (3,500 km) surfaced, 38 nmi (70 km) submerged Complement: 34 Armament: 4 x 18-inch (457 mm) torpedo tubes (bow) and 4 drop collars
  10. beat me to it patrick
  11. Hello everyone i have some straight lines on the upper black/yellow ocrhe banding, every book i have put the lines above the upper gun ports in a slightly different position, so gave it my best shot the 1/4 galleries, and the fitting of the window was quite fiddly but is starting to look ok, the tamiya tape is in the position to line out the decorative strips and the rear most channels its good to be back in the workshop all the best
  12. lol - can someone please pm when there is a vessel I can answer- or we have a submarine one on
  13. I like the idea of drill bits being used a a spacer, that could do with going into the jigs topic
  14. some thing strange about the bowspit on photo were the lower yards turned in when along side
  15. Augie i love the last couple of phots you posted, she looks very nice. i think it is about time we all posted whole build phots so in a year or so time we came see what stage we were at now, i have hardly answered any of my posts, still back now sorry i have not been so active for the last 6 months or so, all the RL things getting in the way,
  16. Keith Jullier used enamels through out his build http://www.amazon.co.uk/New-Period-Ship-Handbook/dp/1854862332/ref=sr_1_3?s=books&ie=UTF8&qid=1364287458&sr=1-3
  17. Mort good point and i dont have an answer i have to remind myself sometimes when i look at my photos and see things about my build i dont like (about 90% at present) and think of ways i could have improved it, i had a thought that replacing my Gun-port linings in plastic - might have been better - on reflection i would not do that - lol - wish i had not said it now have you seen the price of these plastic strips - how on earth they need to charge that amount
  18. http://www3.towerhobbies.com/cgi-bin/WTI0001P?I=LXDYE9&P=8 This works very well and comes in different sizes - i used 6mm Disclaimer lol - its the tape i am showing - not where to buy it from, or price to pay
  19. lol - it's nice to see Murphy is visiting someone else for a change, if i do another 1st rate i will close all the gun-port lids and do away with the linings altogether, or use Evergreen plastic strips the hull is looking great
