Posts posted by Beef Wellington
She looks stunning Timmo, the "small" details make such a huge difference, definitely worth the extra time and effort I'm sure it took. Combined with your precise bulkhead painting its looking wonderful. The colour combination of the wood and the blue/red/black is a real eye catcher.
So Jason with the carronades you plan to use you don,t need to fix or mount them on the sills...
Have I understood right ?
Correct, they mount on a 'deck block', maybe easiest to see in pics below. It is a half circular block that sits just below the gunport. I did add some extra wood for the sills as you can see in following picture, this was to ensure that the gunport is the correct size, but I did not include an overhang. Hope that helps.
I might be mistaken, but I am sure that would only alter the angle of the carronade and wouldn't make any difference to the gap that is left. Because the reason it does not fit is because of the distance between the gunport sill and the top of the gunport not being big enough?
Pete
Pete, you're correct. I forgot that the kit carronades sit on the gunport sill, so the distance is fixed as you point out. For what it worth, the carriages I'm using that mount on the deck give the same result, its just that they are susceptible to differences in deck-top of port measurement.
The carronades do sit up rather high, higher than cannons, and on this ship the 32lb'ers are pretty big for the ship. Its the same with the aftermarket ones as well. A lot of this gets driven right back when the gun port patterns were installed and the relative height to the deck, seems even a 1mm difference can make a huge difference with the room for the carronades.
Robert, BE, Kevin, Dave, Stergios - appreciate the kind words and great advice.
I have run into a bit of a dilemma, that I somewhat knew was likely to be a problem from the get go. I'm trying to install the chains and have found that the PE chain 'loop' is nearly 3-4mm too short - I've re-measured the wale position against the against the plans and its not that far out (<1mm), a not unreasonable tolerance. Anyway, it is what it is so I'm trying to figure out how to address, and I can't believe I'm the first to have this dilemma. Basic geometry implies each of the chains should be a slightly different length anyway given the different slope of the shrouds and all the PE pieces are the same.
Seems I have two options:
1) rework the PE piece to lengthen it, but this will mean a relative large 5mm gap in the piece which would prob look odd and stick out a mile
2) make my own loops from wire - likely most time intensive and fiddly but I suspect would give a more satisfying result
Would love to hear how others have tackled this, and other possible alternatives...
You may notice that The Carronades are fitted but I have not described their build.........
Simple "They are an absolute %#~@*!!!!"
The instructions, the quality of the parts and the final impression is superb. The size of the things is absurd: the overall finished item is app. 1.5 inches long and about .75 high (guesstimate) and has a grand total of .... wait for it.... 18 pieces: 4 wood, 5 brass etched pieces, 4 etched eyelets, 4 pieces of brass wire and the barrel itself. They take about an hour each (without the rigging, and on a good day) and would try the patience of a saint! my finished articles are ok for "stand-off" viewing but that is about it:
Skippy, looking very nice! I'm with you on the carronades, I'm currently working through building 16 of the things (albeit the larger 32lb're) so I definitely recognize the work you've put into these. If you've got it down to an hour I take my hat off to you, they're looking great. Look forward to seeing more.
Still watching quietly Andy, shes looking very nice indeed, love the way that your shrouds are looking, you've confirmed my desire to have a go at serving when I finally get to do my shrouds.
Sorry I missed the vote Timmo, the option you picked looks very sharp indeed!
2] I'm very dissapointed with those cheap materials of the standard Caldercraft's kit. I would prefer to pay more just to have the opportunity to deal with precise and of upper quality basic units of the box......
Well, Stergios, still not too late to explore other options. I took the plunge right when I bought the kit for the same reason and didn't feel I had the skill to make the white metal carronades look anywhere near acceptable.
As mentioned, I wanted to arm her with the common armament at the time and deviate from the kit. I ordered a pair of Caldercraft 9lbers which are pretty much the same size as the 6lb'ers which are commonly referenced. These still need a bit of tidying up, and I'm going to try to simulate a bracket for the cap square as well as a chain for the cotter pin that I think should go into the front hole (the instructions simply call for two round headed pins) but I think something else would look better. Not sure how to do the very small chain yet...The paint finish looks a lot smoother in person, I brushed rather than sprayed and they seemed to turn out OK.
Also wanted to see how these will likely sit on the deck. I plan to mount these in the foremost gunports as seems to be commonly described. You can see that its going to be pretty crowded up front as well. Its also interesting to see the lack of real difference in size between the 32lb'er carronade and the 6/9lb'er cannon. Its easy to see why the admiralty started to equip these ships with carronades given the increase in broadside weight and manpower reduction possible with the carronades. The fore ladders need some final shaping but its clear there is not a lot of room to position these.
- drtrap, ModelBoatMaker and Ferit
- 3
- Ferit and ModelBoatMaker
- 2
Hi Chris, she's looking very nice indeed, I've just managed to get to your log.
I 'think' you're the only Fly build here! I know you got the upgrade kit, I'm wondering if you have any idea on how the upgraded Fly kit compares to the Pegasus kit and whether there is a 'kit quality' difference between the two.
Looking forward to another update "soon"!
Ray, planking is looking great despite your challenges with the wood. I've read from others similar concerns over the quality of the supplied wood in CC kits, I think I just got lucky with mine, but the tanganika did need each plank to get sanded to get a decent edge. Its a shame because otherwise they seem to be high quality. You also seem to be moving on at a cracking pace
Thanks for posting the side-by-side, amazing to see the size comparison between these two frigates.
impressive work Jeff, nice to see some progress again. I'm curious where you got the wood from to make the cradles and the base, it looks great.
Thanks for kind words BE, Stregios, and Ferit KUTLU...
All channels are completed and ready to glue. I did find that the forward channels needed little bending(very minor) to ensure that they followed the line of the capping rail which was very slightly curved, again was easily achieved with a bit of steam. I've also drilled the holes for the various ringbolts that will need to be installed on these and seems to be easier to do this now than later. I've purchased a copy of 'Rigging Period Ship Models' which illustrates these nicely and without which the instructions wouldn't be totally clear as the ringbolts are look more like accidental smudges on the plans.
Main reason for adding a photo was to illustrate a very handy technique that I wish I'd tried earlier, I think I may have read this from one of DanVads posts on the old site and wanted to pass on. Attempting to show that the drillbit is set so that only 1.5mm of the bit is protruding from the pin vise, this allows the various holes to be drilled with confidence knowing that its impossible to go through the wood. Simple and effective - thanks Danny.
Hopefully next photos will show attached channels which I think is the last bit of work on the hull that will require major manhandling so I can start to work on the carronades with a vengeance. I've deliberately left a few fun items so that I will have a few productive distractions as I suspect finishing and rigging 18 carronades/cannons will be a bit monotonous.
PS: Where did you get that profile gauge?
I think I just got it on Amazon.com, but pretty sure they are available in a lot of hardware stores.
Started to work on the channels. The instructions indicate these should only require 'minor shaping', this proved to be the case for the main channels, however, the fore and aft ones needed a little more to ensure that the inner surface was flush with the hull.
To get the right curvature I used the following simple technique:
- Used a profile gauge on the hull
- Transferred the curve to some card to double check the fit
- Transferred the curve to the channel and cut/filed/sanded
- Final result after pinning, these fit very solidly even without glue
Overall, pretty pleased that this proved to be easier than I had expected.
Thanks BE - I hope they look OK as I'm not sure what the alternative is, 2mm single blocks could work and I have some just in case, will cross that bridge when I come to it!
Quick picture of the fenders and the chesstree, found these to be a real pain to paint and makes me even more impressed with the larger scale kits going with the Nelson Chequer that has a lot more ornamentation than the Snake. The relative simplicity of the Snake's lines seems to highlight even very minor mistakes. These pieces did take quite a bit to fit properly as the hull does have slight curvature and it was important to avoid any gaps as they really show with the yellow ochre.
I've also drilled the hole for the mainsheet tack as this will be made much harder by the foremast channels getting in the way. -
HMS Havick?
Here are the results of my experimentation with the block sander.
I the photos below are shown (left to right):
- Untouched Caldercraft 2mm single block (natural)
- Caldercraft 3mm double block that has been in the block sander (walnut)
- Untouched Caldercraft 3mm double block (walnut)
Apologies for the photo quality, an iPhone is not great for these small objects. The block sander definitely makes a big difference to the appearence of the blocks, and in person there is more of a difference. I could probably put this in for a little bit more time and may do that before I commit so they all end up the same. Note that both of the 3mm blocks are walnut, the sander lightens up the surface.
The block sander I used can be seen at http://www.modelexpo-online.com/product.asp?ITEMNO=MS27 . I'm sure there are better, but seems a pretty cheap and cost effective simple approach.
Dave (davyboy) - thansk for the kind comment and good tip, I need to do some thinking whether this want to tackle this (pun intended). I guess these would need to be really small diameter 1.5-2mm(?)
Dave - picture definitely helps. Its strange, the kit supplied carrondes come with white metal wheels, I had thought about trying to use these to replace the wood but the sizes don't work - the kit carronde trunnions mount on the sill of the gunport, the aftermarket ones use a deck mounting block. Even though these represent the same thing its amazing how different the sizes are. The 32lb carronades are just bohemoths as well, they barely fit underneath the top of the gunport. I need to think about the extra work on the training tackles, I'm tempted to maybe fir the rings, but not the tackles as it may just leave the deck a bit too cluttered. Need to ponder some more...
Ferit KUTLU - appreciate the kind words, I'm doing my best, you Berlin is very clean and precise, beautiful wood tone.
On a slightly different note - Did you know that the USS Enterprise has recently arrived in Newport after her last deployment. She now begins a 2 1/2 yr project to remove her core and reactors. during this project she will be towed around the horn to the Naval shipyard here in Seattle and the broken for scrap. She is the oldest warship in the US Navy currently on deployment. She is also the first atomic powered surface vessel.
Is she defintiely going to get broken up or added to battleship row over in Bremerton? I think there are more ships laid up there than there are ships in most modern navies
HMS Snake by Beef Wellington - FINISHED - Caldercraft - Scale 1: 64 - First wooden ship build
Think it was .25mm lin, it was the smallest I had at the time.
